Results 1 to 7 of 7
    Need help finding the right size rigid fork
    I'm wanting to switch out my Manitou Axel Platinum Front Shock 100mm travel on my 26" 06 gf tass for a rigid fork. I have measured the axle to crown at 488mm (static no compression). I'm confused on what size rigid fork I should buy.
    Thanks for the help in advance.
    Reputation: Eric Malcolm's Avatar
    Dec 2011
    You need to sit on your bike and get someone to measure actual A/C. Rigid means rigid, no change, so to get an accurate A/C. it must be as you ride it before bump compression. Static is not how the bike sits before you ride your bike.
    Eric
    If I don't make an attempt, how will I know if it will work?
    Quote Originally Posted by Eric Malcolm View Post
    Eric
    Eric, I ride my bike with the shocks locked out. Does that make a difference in the measurements?
    The rigid fork you want should be the A-C with 20% sag on your suspension fork. Your fork is 100mm. For a 26" wheel you want ~450mm A-C for the rigid fork. A cheap steel one would be the Surly 1x1 that's corrected for 100mm. It has a 40mm offset (your stock one is 38mm) and an A-C of 453mm. It has both disc and canti studs. QBP P/N: FK0002
    Quote Originally Posted by Schmucker View Post
    That is great to hear and thanks. What does the 100mm correction mean on the Surly 1x1?
    Just wondering if this is to become a cyclocross bike.
    Quote Originally Posted by Saddle Up View Post
    Yes that would eventually be my goal.
  1. Replies: 5
    Last Post: 05-08-2013, 03:53 PM
  2. Replies: 21
    Last Post: 03-18-2013, 11:44 AM
  3. What size rigid fork to use 26 or 29?
    By kitts21j in forum 27.5
    Last Post: 07-16-2012, 03:41 PM
  4. 5mm in rigid fork size, a problem??
    By Ozrocker13 in forum Niner Bikes
    Last Post: 10-18-2011, 01:35 PM
  5. How do I measure or find out what size rigid fork?
    By roc865 in forum Shocks and Suspension
    Last Post: 07-15-2011, 05:44 AM
