Results 1 to 23 of 23
    My First Cross Build!
    Frame: 2012 Salsa Chili Con Crosso (56)...
    Striping the paint off and going with the polished bare aluminum look.
    Components are on the way! More Pictures to come
    Attached Thumbnails Attached Thumbnails My First Cross Build!-526330_10201109648356770_1999644567_n.jpg
    Supplies for stripping paint and DIY Tubeless
    Attached Thumbnails Attached Thumbnails My First Cross Build!-1185287_10201120189260286_862930694_n.jpg
    Sram Rival RD for 1x10
    PF30 BB
    fi'zi:k Ardea Saddle
    Midge On-One Dirt Drop bars
    Attached Thumbnails Attached Thumbnails My First Cross Build!-526530_10201109662397121_1444107457_n.jpg
    TRP RRL Brake Levers
    TRP CX8.4 Mini-V Brakes
    Sram TT-900 10-speed Bar End shifter. (only using the right one)
    Kenda Happy Medium 700x35 Tires (tubeless)
    KMC X10.93 Chain
    Attached Thumbnails Attached Thumbnails My First Cross Build!-1262781_10201137774179898_1130095336_o.jpg
    FSA Energy BB30 172.5 Triple Cranks (Only using the 39t ring)
    FSA 42t 130mm Chain Guard
    N-gear Jump Stop 34.9mm Chain guide
    Attached Thumbnails Attached Thumbnails My First Cross Build!-1293060_10201143246836711_832817496_o.jpg
    Shimano 105 11-28 Cassette
    Salsa 32.0mm Lip Lock Seat Collar Red
    Niner YAWYD Top Cap (w/Stone IPA Bottle cap)
    Attached Thumbnails Attached Thumbnails My First Cross Build!-1263046_10201180936018917_449764873_o.jpg
    That Aircraft Paint Remover is some nasty stuff!!
    Attached Thumbnails Attached Thumbnails My First Cross Build!-1229951_10201143250036791_1455492676_n.jpg
    Feb 2013
    Nice! I would consider leaving the small ring on the front just as a 'chain guard' of sorts, even though you don't intend to use it, the chain will not fall off and get stuck on the inside. Unless of course, you're confident that your chain will not fall off on the inside (bouncing your bike on your back as you carry it up a run-up sometimes makes the chain go where it's not supposed to).
    Time to polish!!
    Attached Thumbnails Attached Thumbnails My First Cross Build!-1262952_10201154684082635_665998753_o.jpg
    39 ring in the middle.. The 42t bash guard on the outside will keep the chain from falling off the outside (and my pants clean when I ride it to the bar), and the N-Gear Jump Stop will keep it from falling off on the inside.
    Feb 2013
    That gear stop looks cool, I've got a cheaper one on the 1x9 cx bike, but one of those might work better.
    Quote Originally Posted by jimPacNW View Post
    Its pretty cheap, only costs like $10.. After a little research i learned allot of pro's use it... Was originally planing on going with K-edge or Paul chain keepers, but for the price I figured this was worth a shot.
    Amazon.com: N-Gear Jump Stop Chain Guide/Watcher 34.9mm: Sports & Outdoors
    Eli Broccoli
    Reputation: 123elizxcvbnm's Avatar
    Love the Con Crosso. Wonder why they stopped selling it... Seemed like a great bike to me.
    Don't be a sheep
    Sep 2004
    Quote Originally Posted by Cyco Pirate View Post
    Been using an N-Gear jumpstop for 3 years on my race bike without issue. In that time I know a handful of people who've run the K-Edge and Paul and they were both a PITA to keep working correctly.
    "Do not touch the trim"
    Polishing took forever!! 300 grit > 600 > 800 > 1200 > 2000 > Mothers aluminum polish.
    Details not yet done are: Headtube badge, Red flames on the fork covering the blue, and new Chili Con Crosso stickers
    Dec 2012
    That's turning out pretty nice.
    Reputation: StuntmanMike's Avatar
    Looks great! I really like the look of those bars too.
    '15 Charge Cooker Maxi 2
    '13 Salsa Horsethief 2
    '12 Trek 6000
    '11 Ridley X-Ride
    '11 Santa Cruz Driver 8
    Thanks guys! I'm pretty happy with it. Pics with the vinyl are coming up next...
    I had a few setbacks and lessons learned:
    Kenda Happy Mediums wouldn't seal tubeless on my Easton Circuts. The bead has ridges all the way around, the gorilla tape did a good job filling them in but the tire was so tight that I damaged some of the tape (and broke all my levers) while mounting. I was loosing about 15psi by the end of the day.
    KMC chain ordered from amazon only had half of the "Missing Link" connector
    Jagwire cables and housing ordered on ebay directly from Hong Kong did not include shift cables and the rear brake cable was too short.
    Custom vinyl, The Con Crosso is now a Con Cuoco!! That's my last name.
    Salsa Headtube Badge is back on, and I did a vinyl wrap on the fork to cover up that last little bit of blue.
    MY FIRST CROSS RACE IS IN 2 WEEKS!!!
    cmorrow001
    Looks awesome. Nice work
    fool goin up, joker down
    Jan 2009
    So nooooobody wants to mention the badass Stone bottlecap headset top??
    Mamma speed I'm back!!!
  1. Trying to build monster cross
    By nini101 in forum Beginner's Corner
    Last Post: 11-28-2012, 10:34 PM
  2. rear wheel build: 3-cross vs 2/3 cross
    By FishMan473 in forum Wheels and Tires
    Last Post: 08-26-2012, 03:34 PM
  3. Charge Filter Cross Build
    By davesauvageau in forum Cyclocross
    Last Post: 06-25-2012, 09:00 PM
  4. Help with cross check build
    By SteveJfromtheSwitch in forum Surly
    Last Post: 06-14-2012, 02:40 PM
  5. New Cross Check Singlespeed Build - Need Help
    By tenacean in forum Cyclocross
    Last Post: 04-05-2012, 06:09 AM
