Results 1 to 14 of 14
    ~ B A D A S S ~
    Reputation: car bone's Avatar
    Lynskey cooper cx questions
    Hi I'm getting ready to order a new frame and I want to know if the Cooper cx is a good option.
    I see it has a huge fat downtube and snakestays, as compared to the Viale model that has non oversized downtube and
    straight stays.
    I would be using these as disc roadbikes/summer commuters (since none of them will fit good studded tires).
    Comfort difference between these: is the cooper cx a harsh ride?
    I see the Viale has straight gauge tubing. Does it matter?
    "Efficiency": will there be any difference?
    Speed on the road: will there be any difference?
    Does anyone who has either of these or at least seen or tried one care to comment?
    The way I see it: the Cooper cx is beefed up and should be stiffer and possibly less comfortable and it takes slightly wider tires.
    I cant post pics from lynskey site it appears.
    frame pics
    https://www.lynskeyperformance.com/s...ross-bike.html
    https://www.lynskeyperformance.com/s...rake-bike.html
    complete pics
    https://www.lynskeyperformance.com/s...yclocross.html
    https://www.lynskeyperformance.com/s...imano-105.html
    Rule #9 // If you are out riding in bad weather, it means you are a badass. Period.
    Quote Originally Posted by iheartbicycles View Post
    Specialized sucks ass.
    Oct 2007
    I just built up a Cooper CX to use on and offroad. It is replacing a carbon road bike, so I can only compare it to that. It is much smoother riding than my carbon bike. It isn't as stiff, but I wouldn't call it flexy. Overall it is a very nice riding frame and plenty stiff and quick. I would assume that the Viale would be heavier since it is using straight gauge tubing and likely flex more due to the smaller tubing diameter. As far as speed, I would guess that unless you are a pro racer then you wouldn't notice much difference. I would say go with the Cooper though since larger tires can do more for comfort than any frame design can.
    2013 Santa Cruz TRc 650b
    2015 Lynskey Cooper CX
    2010 Soma Groove
    1987 Haro RS1
    ~ B A D A S S ~
    Thanks probably gonna go with the cooper. It seems to have gotten good reviews too.
    ~ B A D A S S ~
    here it is Mine came in at 1700g
    Oct 2007
    Nice. Is that an older clearance model? I noticed it doesn't have the tapered headtube.
    2010 Soma Groove
    1987 Haro RS1
    ~ B A D A S S ~
    Quote Originally Posted by ljsmith View Post
    Its a 2014 model. It was 40% off. I actually wanted a regular non tapered headtube, so it was now or never.
    ~ B A D A S S ~
    Btw does your frame have an alu insert in the seat tube?? My frame has at least. Can this be removed?
    Oct 2007
    Mine does not have an aluminum insert. The seat tube is very thick, it is a 34.9 but because the tubing is so thick it takes a 27.2 seatpost. Maybe yours came with a shim to allow use of a smaller seatpost? If it is just a shim then theres no reason you couldn't take it out.
    2010 Soma Groove
    1987 Haro RS1
    ~ B A D A S S ~
    There is some kind of shim in mine, it looks threaded where it interfaces with the seatpost (I'm guessing for friction). I can clearly see there are 2 different colors/metals. I don't know if it will be easy to get out.
    I removed the decals on mine. They came off easily with acetone and paper. Took me 5 minutes.
    Oct 2007
    I inspected my frame closer and it does have an aluminum shim.
    2010 Soma Groove
    1987 Haro RS1
    What kind of weights are you Cooper CX owner getting. Can they be built in the 19-20 lb range without resorting to super expensive components?
    Oct 2007
    Quote Originally Posted by pisgahrider View Post
    I guess it depends what you mean by "super expensive" components. The frame certainly is not what I would call light, definitely heavier than an aluminum frame. Mine weighs 18.9 lbs as set up in the photo.
    2010 Soma Groove
    1987 Haro RS1
    Nice.
    Dura-Ace, Force, XTR level components are budget busters for me.
    Champagne tastes with a PBR beer income.
    Oct 2007
    Nice.
    I would guess with a Rival or 105 build kit the Cooper CX would build up to 20-22 pounds depending on the wheels and tires.
    2010 Soma Groove
    1987 Haro RS1
  1. Replies: 12
    Last Post: 09-26-2014, 12:58 PM
  2. Lynskey Got It Right This Time 2011 Lynskey PRO29 SS
    By Superlight2003 in forum Lynskey
    Last Post: 03-30-2014, 07:42 PM
  3. Mini Cooper and 1UP?
    By onepivot in forum Car & Biker
    Last Post: 06-12-2013, 04:25 PM
  4. Lynskey XL frame questions
    By Arek in forum 29er Bikes
    Last Post: 01-31-2013, 07:34 AM
  5. Questions For Lynskey Pro 29 Owners
    By Mojo Man in forum 29er Bikes
    Last Post: 08-11-2011, 03:06 AM
