Results 1 to 9 of 9
    I Tried Them ALL... Moderator
    Reputation: Zachariah's Avatar
    Light Cross Clincher Tire that grips?
    Turning to Cross tires, between 30-35c. What are the best brands for grip and weight? Cost is NO object...
    "The mind will quit....well before the body does"
    I have really been happy with the Clement PDX. Supposed to be a mud tire, but it is a decent all arounder that corners very well.
    It really depends what you mean by grip and what surfaces you ride. Most of our races in Wisconsin are in city parks, so lots of grass. Re reading your op, it sounds like this might not be for cross? Straight line grip its different from how a tire behaves in a turn. Both depend a lot on your riding surface.
    My wife and I use the Clement PDX and it does work well on grass, especially slippery wet grass. But in dry grass and hard pack nothing touches the Schwalbe Racing Ralph, un freaking believable grip, no drift. Have used them in tubular and tubeless.. cat on carpet.
    Nov 2014
    I like Challenge's "open tubulars." Light, supple, grippy as hell. There have been minor QC issues at times, but no more than I'd expect from any handmade tire. Add latex tubes (Always latex. Always.) and you're golden.
    What type of tread are you looking for?
    Mar 2012
    Michelin mud 2 are always good, though don't try and ride on pavement much on them, a little narrow but tall and fairly supple for a clincher, works better on softer ground. Hear the PDX is good and popular around here in Western WA as well.
    Quote Originally Posted by jstonebarger View Post
    Looking for a file tread center, with side knobs. Must be under 33c, due to fork/chainstay clearance. I'd like weight to be lighter than 400g a tire.
    Nov 2013
    Specailized triggers are my favorite so far. I think they make a 33 c. The center is filed but the very center 5 mm strip is up a bit. Really nice on pavement on mountain trails at 31 psi with the 38c tires. I have that on front but will go to back when I find slightly more aggressive 40-43 tubeless. Because the trigger rolls fast and I have room
    Thanks, all.....went with Clement LAS 700c x 33 and it rocks, tubeless.
    hispanic mechanic
    Reputation: sslos's Avatar
    The LAS is a nice tire. If you like it but have any issues with it burping, take a look at the Specialized Trigger 2bliss.
    Los
    "Shut up body and do what I tell you."
    Jens Voight
    http://teamjva.com/jens-voigt-soundboard/
  1. TR tire ok on standard clincher rim?
    By HuffyMan in forum Wheels and Tires
    Last Post: 08-08-2014, 06:34 AM
  2. Replies: 3
    Last Post: 05-01-2014, 09:26 AM
  3. Replies: 7
    Last Post: 08-05-2013, 11:57 AM
  4. Light ergo grips?
    By 2fargon in forum Weight Weenies
    Last Post: 11-09-2012, 07:44 AM
  5. Clincher Tire Recommendations for CX?
    By lawfarm in forum Cyclocross
    Last Post: 09-04-2011, 11:17 AM
Can't find it? Just search our site!
