Results 1 to 3 of 3
    Ska
    Ska is offline
    Steel is real.
    Reputation: Ska's Avatar
    Help needed. (x-post from brakes)
    I've currently got a Cross bike built up in Campagnolo Chorus/Record and after looking through my spare parts boxes I noticed I have a brand new unused set of Avid BB7's (they were supposed to go on my fatbike but I ended up going with something else).
    The BB7's were a sweet find as I've been kinda plannin' on going to a disc equipped cross bike. Problem is (at least I think it's going to be a problem) that these are mtn calipers. Do mtn calipers work with Campy road shifters?
    I'm guessing no due to ratio issues and the levers ultimately bottoming out on the bars.
    Am I right.
    Here's my crummy, slow-going blog The Slow Spoke if you're interested.
    You are right. However, problem solvers makes a pull ratio adjuster that makes long pull brakes (mtn disc and linear pull) compatible worth short pull levers (cantilever, road caliper, road disc). I don't know if they are worth it price-wise, though, since you can get bb7s pretty cheap through jenson (though I am not positive they have the road bb7 for cheap).
    Edit: the pull ratio adjusters are called travel agents. Clever, no?
    Sent from a one-finger keyboard...pardon my autocorrect
    jrm
    jrm is offline
    Reputation: jrm's Avatar
    Cool-blue Rhythm
    You could probably rig it up using something to regulate the cable pull but it's not going to work the same or as well as a road specific caliper matched with a STI shifter. Looking back on using mtn bb7s and all kinds of shifter combos i'd suggest doing it right the first time and suggest selling the bb7s and put the $$ towards some Sklyer(sp?) TRB road discs and not look back.
  1. Brakes on Norco Fluid 9.1 - Help needed
    By simple_man in forum 29er Bikes
    Last Post: 02-17-2014, 09:56 PM
  2. advice needed on upgrading brakes
    By tomjan18 in forum Brake Time
    Last Post: 11-30-2013, 11:24 AM
  3. Pro stop disk brakes needed
    By EarthquakeJakeWatson31299 in forum Brake Time
    Last Post: 07-07-2013, 07:52 AM
  4. HOPE Brakes Expert Needed
    By trojans1993 in forum Brake Time
    Last Post: 02-05-2013, 07:35 PM
  5. Brakes on my Tallboy C - Advice needed!
    By BLUR'b in forum Santa Cruz
    Last Post: 12-30-2011, 05:59 PM
