Results 1 to 7 of 7
    unrooted
    Reputation: unrooted's Avatar
    Gearing for SS CX for flat-sandy course
    The CX courses where I live tend to be flat and sandy.
    I have a Motobecane Phantom 29 frame wasting space in my garage and I am thinking about turning her/it into a ss cx bike.
    What gearing do you you think I should go with for flat and sandy riding?
    Any suggestions on tires? I'm thinking I'll just use my wife's Stans Crest wheels with Maxxis igniter 2.1 tires.
    Who makes a really wide, cheap aluminum cx bar? I'm 6'4" tall if that matters.
    menace to myself & others
    Aug 2005
    Generally, a good starting gear is 2.3:1. Maybe a little bigger if your races are flat. So, depending on what crank choices you have, you could go with a 34x15, 39x17 or 42x18 to start.
    There is some preference involved, so if you're a spinner, you'll wanna go a little lower, if you're a masher, a little higher.
    Reputation: stevland's Avatar
    I'm assuming you want to run drops? I was able to pick up a ritchey off ebay for like 25 shipped for my cx bargain build .
    unrooted
    Yes, I need drop bars, I'm thinking that what would work best is something with a super deep drop so that when I'm in the sand I can get my hands up high and my wieght onto my back tire, but on the road I can get aero.
    Is 46 the widest cx bar width?
    I think Nitto makes some wider stuff. Salsa and Soma make a bar where the drops are wider than the hoods. I've never ridden any of it though.
    unrooted
    To me what would make more sense is a wide flat but narrower drop, which would be impossible! But I don't think most cx races are in sand.
    What's your brake setup? I have to run discs, and ill probably use a set of avids I have. That means no brakes in the drops!
    v brakes
  1. Here comes Sandy!
    By rob1035 in forum Virginia, WV, Maryland, DC, Delaware
    Last Post: 11-13-2012, 12:45 PM
  2. 32X14 gearing, only urban paved riding, flat ground=good?
    By LittleBuddy in forum Singlespeed
    Last Post: 10-05-2011, 11:33 AM
  3. Flat Night at Sandy Ridge
    By kayakerjim in forum Oregon
    Last Post: 09-10-2011, 06:37 PM
  4. Flat Rock Ranch & Flat Rock Creek
    By Aplusent in forum Site Feedback/Issues
    Last Post: 08-13-2011, 08:19 PM
  5. What type of bike works best on flat, rooty, sandy terrain?
    By DoinkMobb in forum Southeast/Midsouth - GA, TN, AL, FL, MS, LA, AR
    Last Post: 03-25-2011, 03:01 PM
