Results 1 to 37 of 37
    Unfit Norwegian
    Reputation: Dazed's Avatar
    Dirty Disco frame sizing?
    I'm getting a On-One Dirty Disco frameset, but am not sure about what size.
    I'm 5'8" (173 cm) and sort of between the manufacturers recommended sizes. I don't know whether I should go for a small (535 mm ETT) with a 100mm stem or a medium (547 mm ETT) with a 90mm stem. ...or shorter, if I'll need a shorter cockpit for cx (gravel and road. Not racing.) than for a road bike.
    I have a 31.5" (80 cm) inseam, which is shorter than average, so normally I'd choose the longer frame, but I'm concerned that 90 (or 80) mm stems and maybe a little less visible seatpost (my saddle height is 72cm from the center of the BB to the top of the saddle, and the small and medium frames have seattubes with lengths of 51,5 and 53 cm. respectively.) will look stupid and/or mess up the handling.
    I'm leaning towards medium, but would appreciate any insight.
    Jan 2011
    80mm on a road bike (cx) will result in a very twitchy bike. So I would go for a small.
    Reputation: mnyquist's Avatar
    I am 5'8" as well and would lean towards the small. I have a short inseam as well. I figure I would need an 80mm stem with the medium.
    Unfit Norwegian
    Thanks. I really think I'd be good with 90mm on the medium and 100mm on the small, but I guess there's not really any problems with going for a small, except maybe a shorter headtube and more aggressive riding position which I no longer need.
    Good point, you may need a few spacers on the small. Did you pull the trigger? Post some pics if you get it....sweet bike.
    Unfit Norwegian
    Not yet. It's still a few weeks away, I think.
    I ran a 90 mm stem on my last road bike which also had a 547mm ETT, and that wasn't twitchy. I really don't know which size to get this time.
    jrm
    jrm is offline
    Reputation: jrm's Avatar
    Same height as you
    with about the same inseam. I'd end up riding either a 54 but most likely a 56 in order to get the 561 effective top tube. My current 55 CX frame has a 565 effective top tube.
    Buy the frame based on the top tube lenght/reach and NOT standover.
    Unfit Norwegian
    Quote Originally Posted by jrm View Post
    That is exactly what I'm trying to do.
    Small/535mm ETT and a 100mm stem sounds good, except the low front end, but a lot of spacers might be better than a short stem. ...But then again 90 mm might not be too short after all.
    Dec 2009
    I'm 5'8" also and I got the medium size. But have longer legs than you - 33". I have a stretched out position and use a 13cm stem. I use the same position I used for years on my road bikes. Like you I do gravel and dirt but don't race. Sorry this may not help. My daughter (a physical therapist and bike fitter) tells me I'm way too long in front.
    One other thing to keep in mind: the Med DD has a steep seat angle: 74 deg. If this is steeper than your old road bike it has the effect of giving the DD a longer front center than the old bike ( if you base your seat position on KOPS, that is).
    <a href="http://www.flickr.com/photos/alexmurdock/7498758940/" title="DSC04133 by alexmurdock, on Flickr"><img src="http://farm9.staticflickr.com/8152/7498758940_cf315c6278.jpg" width="500" height="375" alt="DSC04133"></a>
    Unfit Norwegian
    Thanks. Seeing your bike helps a bit. Do you know your seat height? From the center of the BB to the top of the seat, along the seat tube?
    Good point about the seat angle. My last bike was 74 degrees as well.
    Dec 2009
    Center of BB to top of saddle is 29.5" (75.25cm). Tip of saddle to where stem intersects bar, 22"(56cm).
    Unfit Norwegian
    Thanks! That's helpful.
    Bro Mountainbiker
    Reputation: Sheepo5669's Avatar
    May 2010
    Im coming from a bike with a 73* seat tube. Both of these bikes have the same top tube 565mm.
    How much more effective reach will the disco have beacuse of the 1* steeper ST? Are we talking mms? or like .5cms?
    Raised in a Chicken-Coop by Chickens
    Bro Mountainbiker
    May 2010
    I did the math about the 73* ---> 74* change in seattube angle.
    In my case of having the seat in its certain position, 1* of seat tube angle changed the effective reach by about 13.5mms. This is if I kept my saddle in the exact same position in relation to the BB.
    Just FYI!
    I had to use some serious math that I never learned in Highschool. Cosine Ratios and whatnot.
    Dec 2009
    I'm glad someone did that. Saw your question and made a halfhearted look for an answer. I had a 73 on my own road bike and wondered the same thing. 13.5mm is a lot!
    I'm 5'9" and ride a 56cm road frame...think the medium will work for me?
    Bro Mountainbiker
    May 2010
    Quote Originally Posted by mudrock View Post
    No problem. I ride a 56 and have about 5 inches of seatpost hanging out.
    If my frame was larger or smaller or my seat was higher or lower that number (13.5mm) would change a bit.
    Dec 2009
    Quote Originally Posted by EdPharmD View Post
    That seems to be the general consensus of posters on this thread. look at my set-up above. I'm a bit over 5'8" w a 33" inseam. I like a stretched out position, more than most, w a 13cm stem.
    Bro Mountainbiker
    May 2010
    Anyone else having trouble getting their saddle back far enough? even with a 25mm setback post my saddle is slammed back.
    May upgrade to a FSA 32mm setback...
    " width="549">
    Its actually about 5mms further back now because I was getting knee pain with my knee slightly forward of the pedal spindle
    Dec 2009
    I didn't have that problem. I used to use the KOPS formula on my road bike but gave that up when I went to cross. I'm definitely forward of that now with no pain. When moving your position forward, you would have to raise your saddle slightly to get the same extension. Did you try that?
    Bro Mountainbiker
    May 2010
    Yeah I tried it about 5mm further forward than KOPS. Got knee pain but I was also dialing in my saddle height at the time, so the one or two rides where it was off could have been the culprit for the pain.
    I probably need to pony up for a real fit. Kops is probably just a good starting place...
    roadie
    Reputation: modbog's Avatar
    fwiw, and it's probably not worth much, i'm 6' and got the 54. no setback. i normally ride a 56 on road (565mm TT) i've also ridden 57 and 58, but found them more stretched out than i like. i like the compact fit. if you really want to know how it will fit you should check out a shop with a fit cycle and have them dial it in.
    but for $550 you could just buy both sizes and A/B them
    Bro Mountainbiker
    May 2010
    Yeah, I got my saddle slammed back but Im loving the bike.
    May not be as great as mu old steel frame for gravel grinding, but for singletrack, road, and racing, this frame is awesome!
    I've been waiting on a 56, but now I'm concerned about the size. I assume the 56 is a large, 54 medium ect? I am 5'10", long arms and legs, and am comfortable on my Jamis 56 CX bike. The DD geo is pretty different- 74 ST is 1 degree slacker than the Jamis (73) and the HT length is taller by 15 MM. I'm confused as to whether this will make the ETT to long, even though they are measured within 2 MM (DD 562, Jamis 560). Any help would be appreciated.
    Bro Mountainbiker
    May 2010
    Refer to post #14. You could ride a 54 or a 56 its up to you.
    Dec 2009
    Quote Originally Posted by deuxdiesel View Post
    Yes the 56 is the large. A 1 deg steeper ST pitches the effective TT 13.5 mm forward acc to sheepo. So if you don't change your saddle position relative to your cranks you will have a longer reach and stack. My dilemma was similar, but I use a more forward position relative to my road bike so it worked out for me. My bike (medium) is post #9.
    Unfit Norwegian
    Here's the end result, btw:
    Post your 'cross bike
    Medium, w/100mm stem.
    Dec 2009
    So did that size work out?
    Unfit Norwegian
    Seems right so far.
    Sizing help needed on bad EBay purchase
    Hi,
    I am 5'10 with a 31" inseam. I bought (what I thought) was a 56cm disco on EBay. Turns out it is a 54cm. I am worried it is too small. I ride an All-city Nature Boy (55cm...the geometry is slightly larger than a Disco 56cm frame) which is perfect for me, but they tend to run big. Should I stick with the 54cm or wait until the 56cm is available (On-one USA is sold out for another two months). ?????
    Dec 2009
    I'm 5'9' w a 32" inseam. I ride a 54 and it fits me well. I like a long stem tho - 12 or 13cm.
    Thanks. I have also looked at the 58cm DD...it has an effective top tube only 10mm longer than my nature boy. The head tube, however, is 30mm longer (although they have different types of headsets). I am wondering if the 58 would work for me?
    Dec 2009
    I think a 58 is a stretch. I would go towards the smaller frame and fine tune it with your stem length.
    Is it possible to run full hydros on these frames? Or, do the guides not allow it?
    Bro Mountainbiker
    May 2010
    Quote Originally Posted by Mountain Cycle Shawn View Post
    The guides will allow it. I had hydros on mine for a month or so.
    Jul 2013
    Hydros on Dirty Disco?
    Quote Originally Posted by Sheepo5669 View Post
    Sheepo, what type of hydros do you use?
    Bro Mountainbiker
    May 2010
    Quote Originally Posted by DeIcer View Post
    I had m785 xts on it with flat bars last cross season
