Results 1 to 12 of 12
    Cyclocross Rim Width
    What is a good rim width for a cyclocross rim?
    I am thinking of getting a narrow cross country tims and build up a wheel myself.
    21.4 outer width and hor to horn 16.3mm.
    Do you think this would be suitable for a cyclocross wheels set?
    Bro Mountainbiker
    Reputation: Sheepo5669's Avatar
    May 2010
    19-21mm inner width is preferred.
    You can get by with narrower or wider rims too.
    You may get some casing flex on 16mm rims at lower pressures.
    Raised in a Chicken-Coop by Chickens
    Reputation: ms6073's Avatar
    Based on my experiences racing with a set of Enve Twenty9 XC tubulars (25mm wide) and training rides on a set of Chinese XC carbon clinchers (19.5mm inner diamter), I agree that 19mm should be the minimum inner width.
    Bro Mountainbiker
    May 2010
    Quote Originally Posted by ms6073 View Post
    Those Enves are 18mm inner width right?
    jrm
    jrm is offline
    Reputation: jrm's Avatar
    Im rolling on A23's
    absolutely love the additional widths affect on handling.
    "Neo cracker"
    Quote Originally Posted by Sheepo5669 View Post
    The Yes, the Twenty9 XC tubeless rims are 18mm Internal and 24mm external width.
    I <3 29ers
    Reputation: AndrewTO's Avatar
    Mar 2005
    Quote Originally Posted by Wheeliewheel View Post
    lol It depends.
    What frame/fork? What do you weigh? Did you have a preference for spoke selection (bladed)? We need to know who/what we're dealing with.
    I put my Kenda SB8 700x35s on a Salsa Semi 29er rim. Dude that tire was friggin HUGE! ... for a 35.
    I ..... need ..... DIRT!!!!!
    ... and cookies. :D
    Reputation: Polk's Avatar
    Most cyclocross racers use road rims. That means about 19-20mm outer width, and 13-14mm inner width. For example, a classic road rim, the Mavic Open Pro is 19.5mm outer and 13.8mm inner. Those are the rims I use on my 'cross bike. I have also used 'cross tires on Salsa Deldago Cross rims, which was fine. They are 22.5mm outer, and 18mm inner.
    Reputation: AKxc's Avatar
    Hmm, I'm sorta in the same boat. I can get Easton carbon Haven's for a good price...but my concerns are that the Havens are to wide for 700x35 tires...thoughts?
    Take the Easton!
    I ride my Crest tubeless with 700x32 tyres. Inner wide is 21 mm - with the new BST itīs like 22 mm on traditionel rims.The wider rim makes the tyre more stable by low pressure.
    I <3 29ers
    Mar 2005
    Quote Originally Posted by franza View Post
    Take the Easton!
    @ AKxc - ^^ what he said. According to Easton the Haven 29er rims have an internal width of 21mm - very common size for mtn rims. I've run mine on Alex DA rims and have had no problems. I would say the only thing to keep an eye open for is if you have enough clearance in the frame and fork.
    ... and cookies. :D
    I am using the American Classic Race 29 with an internal width of 24mm. I should add that I only race/ride this bike on gravel roads and run a 40c tire tubeless. Works great, though.
Hot Deals
Contests
Latest Mountain Bike Articles
