Cyclocross Rim Width
Printable View
  • 12-25-2012
    Wheeliewheel
    What is a good rim width for a cyclocross rim?
    I am thinking of getting a narrow cross country tims and build up a wheel myself.
    21.4 outer width and hor to horn 16.3mm.
    Do you think this would be suitable for a cyclocross wheels set?
  • 12-25-2012
    Sheepo5669
    19-21mm inner width is preferred.
    You can get by with narrower or wider rims too.
    You may get some casing flex on 16mm rims at lower pressures.
  • 12-26-2012
    ms6073
    Based on my experiences racing with a set of Enve Twenty9 XC tubulars (25mm wide) and training rides on a set of Chinese XC carbon clinchers (19.5mm inner diamter), I agree that 19mm should be the minimum inner width.
  • 12-26-2012
    Sheepo5669
    Those Enves are 18mm inner width right?
  • 12-27-2012
    jrm
    Im rolling on A23's
    absolutely love the additional widths affect on handling.:thumbsup:
  • 12-27-2012
    ms6073
    The Yes, the Twenty9 XC tubeless rims are 18mm Internal and 24mm external width.
  • 12-28-2012
    AndrewTO
    lol It depends.
    What frame/fork? What do you weigh? Did you have a preference for spoke selection (bladed)? We need to know who/what we're dealing with.
    I put my Kenda SB8 700x35s on a Salsa Semi 29er rim. Dude that tire was friggin HUGE! ... for a 35. ;)
  • 12-28-2012
    Polk
    Most cyclocross racers use road rims. That means about 19-20mm outer width, and 13-14mm inner width. For example, a classic road rim, the Mavic Open Pro is 19.5mm outer and 13.8mm inner. Those are the rims I use on my 'cross bike. I have also used 'cross tires on Salsa Deldago Cross rims, which was fine. They are 22.5mm outer, and 18mm inner.
  • 12-29-2012
    FarNRTHFatty
    Hmm, I'm sorta in the same boat. I can get Easton carbon Haven's for a good price...but my concerns are that the Havens are to wide for 700x35 tires...thoughts?
  • 12-29-2012
    franza
    Take the Easton!
    I ride my Crest tubeless with 700x32 tyres. Inner wide is 21 mm - with the new BST itīs like 22 mm on traditionel rims.The wider rim makes the tyre more stable by low pressure.
  • 12-29-2012
    AndrewTO
    Originally Posted by franza View Post
    Take the Easton!
    @ AKxc - ^^ what he said. According to Easton the Haven 29er rims have an internal width of 21mm - very common size for mtn rims. I've run mine on Alex DA rims and have had no problems. I would say the only thing to keep an eye open for is if you have enough clearance in the frame and fork.
  • 12-31-2012
    mnyquist
    I am using the American Classic Race 29 with an internal width of 24mm. I should add that I only race/ride this bike on gravel roads and run a 40c tire tubeless. Works great, though.
