Results 1 to 5 of 5
    CS2
    CS2 is offline
    Reputation: CS2's Avatar
    Crankset Fit Help
    I was seriously thinking about picking up one of the unbranded Moto cross frames. Problem is they said external bearing BB's won't fit.
    NOTE: Due to the width of this frames chain stays external bearing road/ cross crank sets will not work. This frame will need at least a 113mm bottom bracket spindle for the crank arms to clear
    Personally I don't see a problem. I was planning on using parts from my stash for the build. This would mean I have to get a new crank and BB.
    A garage full of steel frames means happiness.
    Fat-tired Roadie
    Nov 2007
    Was there a question?
    If you have the crank on hand, just try it and see for yourself.
    If it won't fit, piecing together a set on a three-piece crank can probably be done for under $100.
    Mantis, Paramount, Campy
    Reputation: Shayne's Avatar
    That disclaimer makes no sense on so many levels.
    Outboard BB's give a wider stance. I've got a frame (that unknown to me when I bought it) will only work with external BBs.
    113mm isn't that long. Lots of square taper cranks require longer spindles.
    It must be designed for single ring application. If a crank with its correct matching BB won't fit there's no way a f derailleur will be able to cover it.
    CS2
    CS2 is offline
    Quote Originally Posted by Shayne View Post
    That's what I thought too. There looks like a lot of room.
    CS2
    CS2 is offline
    After an email inquiry it seems they are leftover KHS frames.
    KHS Bicycles :: CX200
  1. Differences in strength between XT 780 triple crankset and the 785 double crankset??
    By zoro in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-15-2013, 03:11 AM
  2. Xt vs x9 crankset
    By Teigansdad in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-21-2012, 07:48 AM
  3. Tallboy with XT crankset to XTR crankset?
    By Rev. 14 in forum 29er Components
    Last Post: 04-15-2012, 06:11 PM
  4. Can I put the small ring (22) from an M542 Crankset onto a Deore XT M781 crankset?
    By bobonker in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-09-2012, 12:04 AM
  5. Chainline difference in a 2x crankset vs a 3x crankset?
    By fire_strom in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-09-2011, 06:50 PM
