Results 1 to 6 of 6
    Oct 2011
    Converting a Surly Cross Check from bar ends to STI
    I just purchased a Surly Cross Check complete and I am not liking the bar end shifters for trail riding. It is a 2x9 drive train with a Shimano Deore rear derailleur and a Sora front.
    What components do I need to switch this to STI shifters?
    If you want to keep it 9 speed, which is the cheapest option, you will need 9 speed shifters (shimano), new bar tape, and likely new cables and housing for at least shifters/derailleurs, if not brakes as well (these depend on what generation shifters you get). Current sora is 9 speed, or you can go to previous generation tiagra; they can be found nos on Ebay.
    If you want higher end, current generation stuff, you are looking at 10 speed for tiagra out 105. To do that, you would also need a cassette in addition to the other supplies.
    Sent from a one-finger keyboard...pardon my autocorrect
    powered by peanut butter.
    Reputation: heartland's Avatar
    Quote Originally Posted by fotooutdoors View Post
    Yep. I put Tiagra shifters on my CC (w/ an SLX rear and Deore front). They work very well, I think. My Tiagras worked just fine with two pairs of canti brakes and now with TRP's.
    "Never trust a man in a blue trench coat. Never drive a car when you're dead." -- Tom Waits
    jrm
    jrm is offline
    Reputation: jrm's Avatar
    Brakes. Pauls and shimano make v brakes that work with STI. Just out, is the 2013 Shimano V-Brakes for Road Bikes to work with Road Levers:
    BR-R573 - 105 V-Brake
    BR-R463 - Tiagra V-Brake
    BR-R353 - Sora V-Brake
    Only thing is that you cant get um in the US.
    Rakuten: SHIMANO Shimano TIAGRA BR-R463-S front rear set V brakes Tiagra components ?- Shopping Japanese products from Japan
    There is no need to change brakes; the stock ones are fine and compatible with short-pull (road calipers/cantilevers/road disc) levers. Set up right, cantilever brakes work great. Sorry if My initial post was confusing; I was referring to the brake cables/housing, not the mechanism.
    Oct 2011
    You might have a look at the RetroShift setup. Use the bar end shifters on new brake levers:
    - Home Page - Retroshift CX
    I've been running those on my cross bike (link in signature line) for almost 2 years now.
  1. Help with fitting a Surly Cross Check
    By Blue_Alien in forum Cyclocross
    Last Post: 04-06-2014, 07:10 AM
  2. Review of the Surly Cross Check
    By dirtdan in forum Cyclocross
    Last Post: 09-08-2012, 12:16 PM
  3. Surly Cross Check?
    By surf2summit in forum Surly
    Last Post: 09-05-2012, 07:40 PM
  4. Possible stolen Surly Cross Check
    By snigs in forum Colorado - Front Range
    Last Post: 03-22-2012, 07:06 AM
  5. Surly Cross Check bars...
    By clayman29 in forum Surly
    Last Post: 05-16-2011, 08:27 PM
