Results 1 to 20 of 20
    Reputation: 2002maniac's Avatar
    Nov 2008
    Convert BB7 to BB7 Road
    Cross-posting this from the brake forum as I figured it might get a bit more attention here.
    I'm planning a CX disc build and have a pair of BB7 MTB calipers I'd like to use. Any reason I couldnt use THIS to change the leverage ratio to work with road levers?
    AZ
    AZ is offline
    Reputation: AZ's Avatar
    I looked at doing the same myself, I cannot verify it works though. Would be interested in knowing myself.
    Nov 2008
    Seems like it should work, one disadvantage would be no barrel adjuster at the caliper.
    Before you start buying stuff.....I suggest you try the mtb brakes with the road levers.
    I rented a tandem that had the mtb BB7's and they worked great....
    The shop mechanic claimed this was the hot set up.....and quite a few tandem folks agree.
    I'd say give it a shot with the road levers unmodified, and then try the caliper conversion...it can't be much money.
    I assume you planning on shifting with the levers too....if not, just get some long pull drop levers from Tektro.
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by 2002maniac View Post
    Will not work. The only difference between the road and mtb arm is the color.
    The internals are where they differ.
    mtbtires.com
    Nov 2008
    Well I just ordered these arms...we'll see.
    Dec 1998
    Quote Originally Posted by hunttofu View Post
    Wasted your money. You need the internals.
    http://cdn.sram.com/cdn/farfuture/-V..._spc_rev_c.pdf
    mtbtires.com
    Nov 2008
    ahh bummer. Thanks for the info Shiggy
    jrm
    jrm is offline
    Reputation: jrm's Avatar
    "road internals kit"?
    on pg 13
    So #4 for the 08-12 and 2 & 4 for the 05-07? Thanks man
    I have a brand new set of BB7 roads I would be willing to swap for BB7 mountains, as long as the mountain one's are in great shape with new pads. Just the caliper gets swapped, we each keep our own adapters. PM if you are interested.
    Did you have any luck with the arms?? I can't tell from the Avid web page if the length is different.
    Quote Originally Posted by shiggy View Post
    Wow. Useful parts page for SRAM equipment. Thanks for posting Shiggy.
    urmb
    “Nothing compares to the simple pleasure of riding a \mountain or fat/ bike.” ~ John F. Kennedy
    Reputation: ms6073's Avatar
    Quote Originally Posted by betteron2wheels View Post
    Although it may be due to differences in anodizing, the referenced catalog lists different part numbers for the Torque Arm kit for road and mtb as well as different part numbers for the BB7 internals kit. My take is that the torque arms are the same length just the road is anodized silver and mtb is a darker grey but you definitely need the correct BB7 internals kit parts.
    Mar 2013
    Could you use Travel Agents to make this work?
    Dec 1998
    Quote Originally Posted by Lee C. View Post
    Theoretically, but IME Travel Agents are too fussy and come out of adjustment too easily. Their cost is as much as a pair of long pull levers and nearly as much as discounted BB7 Road calipers.
    mtbtires.com
    since 4/10/2009
    Reputation: Harold's Avatar
    Quote Originally Posted by gearwhine View Post
    I have a set of the long pull Tektro levers on BB7 mtn calipers. Works pretty well.
    If you already have a favorite set of rotors, you might want to consider Shimano CX75, the stock calipers are a lot less $$ than the Avids and even with stock hardware, ~10-grams lighter than the BB7 Road SL with Ti hardware.
    Dec 1998
    Quote Originally Posted by ms6073 View Post
    Needing tools to adjust the pads of the Shimano is a deal killer for me.
    mtbtires.com
    I have rival shifters and bb7 mtb going to try this 1st and see how i go, but does anyone have an ideas how much the replacement internals are?
    In the end for me here in australia it might just be easier to but new calipers
    29er you just know when ur ready!!!!
Members who have read this thread: 4
