Results 1 to 8 of 8
    CS2
    CS2 is offline
    Reputation: CS2's Avatar
    Campagnolo Zonda Wheel Question
    For anyone who uses a Zonda wheelset, what is the biggest tire you can mount on it? I'd like to go 36C - 37C if possible.
    A garage full of steel frames means happiness.
    Reputation: Nater's Avatar
    I'm guessing the Zondas have a "standard" 19mm wide rim. I'm running tires that are marked 40mm (measure about 37-38mm) on 19mm wide rims without problems.
    CS2
    CS2 is offline
    Quote Originally Posted by Nater View Post
    I had no idea you could run anything that wide.
    Re: Campagnolo Zonda Wheel Question
    As a ratio of tire width to rim width, it's not much different than running a 2.4" MTB tire on a 28mm wide rim. We do that all the time.
    Sent from my SCH-I500 using Tapatalk 2
    jrm
    jrm is offline
    Reputation: jrm's Avatar
    It can be done but performance wise it could be better to use a wider rim. Especially if your airing down
    CS2
    CS2 is offline
    Quote Originally Posted by jrm View Post
    So a 35mm tire should work even on a 19mm rim.
    I run 35mm rocket Ron's on a Zonda/Ksyrium Elite wheelset with 23mm latex tubes at 35psi with no problems. 140lb race weight.
    CS2
    CS2 is offline
    Quote Originally Posted by Kris View Post
    Thanks for the input. I'm about 10 lbs heavier so weight shouldn't be an issue.
