Results 1 to 14 of 14
Thread: Brake Help.
    Cleavage Of The Tetons
    Brake Help.
    So, I have been riding my xc bike for 20 years with brakes that SUCK. They are some dia compe cantis...(I have tried Pauls, SRP, no improvement.)
    Looking for a linear pull brake that will work with ultegra brake levers...any such good brakes out there?
    I am spoiled by discs on all of my other bikes!
    "We LOVE cows! They make trails for us.....
    And then we eat them."
    These look too cheap...
    https://online2.qbp.com/qbponlinesto...=tektro+mini+v
    But i don't care if they work!
    Anyone try these AND travel agents with V-brakes?
    Feb 2013
    I've got Cane Creek SCX-5s with 9sp Ultegra, and they work good enough, similar to XT or XTR v-brakes on my old 26ers, - but nothing like a modern disc.
    In my experience Cantis are all about setup and pad, I've had good luck with Kool Stop Salmon. I started mtb riding in '88, and we had cantis and U-brakes, my brother was an engineering student and a good mechanic (still a very good mechanic), he could get cantis working great, I didn't have quite the touch but I do ok. We generally preferred Kool Stop Eagle Claw iirc grey pads, we could do front wheel stands and pivot the bike around (or at least try to), I remember them working quite well. Those were either Shimano or Dia Compe.
    Now I've got my cx brakes setup pretty good, and I don't have to mess with the setup because when the lever starts getting a little low I just put in new pad inserts, - much better than the old days.
    You've probably tried a bunch of different pads?, have your brakes ever worked well? Maybe find an older mechanic who knows cantis for a setup? Any good cx mechanics near you?, most of those should still be current on cantis.
    carry clippers! cut something off the trail every time you ride.
    Well, to give a little background, I have been a mechanic for 25 years, and owned a bike shop for ten.
    I have tried just about every pad combo out there.
    XT v brakes with a travel agent worked the best out of all of the options, I might try that after trying out the tektro mini-v's.
    Just curious what other people have run with drop bars.
    Feb 2013
    Given your experience, I think it's time to move to discs.
    Frame is Scandium...no retrofit/welding available.
    I LOVE this frame.
    Jan 2005
    I'm happy with my cheap and happy Tektro Mini-Vs with Campy Veloce levers. I originally set them up using a Travel Agent up front as just a roller and that worked pretty well. Then found that if I used it to increase cable pull I could get more clearance and got excellent grip up front.
    Got all the stopping power I can use now.
    z1r
    z1r is offline
    Apr 2014
    I use the Tektro mini V's on my Ridley which I use as my "road" bike. No complaints. They work better than the 22 year old Altus canti's on my commuter.
    Kilted Cyclist
    I used Tektro mini-V with 105 sti lever before and they worked very well. They survived a season of racing in dirt, mud, and rain. They will slow you down and stop the bike as well.
    but, if you race, I highly suggest you to upgrade to a bike with disc brakes.
    Norco Threshold Single Speed
    Trek X-Calibur 7
    Bianchi San Jose with riser bar
    Trek Madone
    Kona Dew
    Tomac Taos
    Jan 2009
    To ask a question I think I know the answer to... Have you been using compressionless housing? That has made all the difference between terrible mush and firm braking for me.
    Sent from my MotoG3 using Tapatalk
    Reputation: MRMOLE's Avatar
    Agree with all who said setup is key with canti brakes. Best thing I remember helping improve power on my mtn. bikes with canti brakes was adding
    these triangular cable hangers and running them as low as possible to the tire for improved leverage.
    Mole
    https://www.bikewagon.com/part/brake...ier-black-pair
    NEVER going back to Canti's. EVER.
    I used to ride trials...the most perfectly set up cantis have about 1/4 the power of crappy V's.
    Jan 2005
    Then there's the other thing with Canti's that hasn't been mentioned here - Brake Shudder.
    My ancient Redline with the 1" steerer aluminum fork was absolutely terrifying on a downhill. That was one of the situations where there was nothing you could do with the brake setup to fix it, either. V-brakes don't do that.
    jrm
    jrm is offline
    Reputation: jrm's Avatar
    shimano makes a road specific v brake that should work with ultegra levers
    https://www.bikewagon.com/shimano-br...xoCCVIQAvD_BwE
  1. Rohloff rim brake to Disc brake conversion. Help guide ?
    By punchy in forum Internal Gear Hubs
    Last Post: 08-21-2013, 08:43 AM
  2. V Brake Lever Brake Help
    By Viva Borracho in forum Families and Riding with Kids
    Last Post: 11-28-2012, 12:30 PM
  3. Replies: 1
    Last Post: 11-06-2012, 06:47 PM
  4. Replies: 7
    Last Post: 06-08-2012, 06:26 AM
  5. Replies: 11
    Last Post: 01-11-2011, 06:15 PM
Members who have read this thread: 40
