Results 1 to 3 of 3
    Reputation: LJ0913's Avatar
    Bike Nashbar CX-1 crankset swap
    Hello,
    I just picked up cx-1 cross bike. It came with 34/50 and 25 (9speed). I swapped out the rear cassette for a 34 and it's better but I'd like to swap the front to make my knees happier, however it's a 110 so I need to swap out the crankset. I can't find any info on making the change on this bike. Their website doesn't list the specs.
    Anyone know what I can swap the front crankset too?
    Thanks.
    You only live once, but if you work it right, once is enough.
    -Joe Louis
    You can swap to basically any 68mm shell crank, but you may need to swap the bottom bracket as well if your new crack isn't the same standard a the old. Of the crank is a Shimano, the model number should be stamped on the inside of the crank arm. If you don't know how to id various bb standards from the outside, this is the easiest way to go.
    Sent from a one-finger keyboard...pardon my autocorrect
    Gives me a place to start. Thank you for the info.
    -Joe Louis
  1. FSA SL-K Crankset for $149.99 at Nashbar today
    By peteer01 in forum Where are the Best Deals?
    Last Post: 05-07-2014, 08:54 AM
  2. Crankset/bb swap 2x10 to 3x10?
    By jlight317 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-04-2014, 01:37 PM
  3. So I want to swap my crankset...
    By big terry in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 10-18-2012, 07:52 PM
  4. Superfly AL Elite FS Crankset swap
    By Ranger Pride in forum Trek
    Last Post: 10-13-2011, 03:27 PM
  5. Crankset swap options
    By brilehnhof in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-26-2011, 08:06 AM
