Results 1 to 7 of 7
    biggest cassette I can use.
    Building my first cx style bike for commuting and pulling the kids in the burley. It's rather billing our area so I want the biggest cassette I can get. I'll be building the bike with shimano 105 components and a 46/38 crank. What is the largest 10 speed cassette the 105 rear derailleur will take?
    lamer
    Reputation: llamma's Avatar
    Re: biggest cassette I can use.
    According to Shimano the RD-5700-GS can do 32T. I ran this and an 11-32 cassette on my Surly without a problem. A month or so ago I posted a link to a Shimano doc that has these limits listed. It might be in my gallery, but I can't check from my phone right now.
    Thanks! 36 would be nice but 32 will get the job done.
    just put a 12x30 on my durace
    worked fine, great for a 17% hill we have, i felt like i was able to spin rather than just grind up it.
    the idler did rumble a little even with B screw fully in, but not noticeable over the screams from my legs!
    spez roubaix
    fantom cross - stolen -
    crux
    moonlander
    Mar 2011
    I have run an 11-36 XT 10 speed cassette and RD-M772 SGS 9 speed RD with an Ultegra 6700 crank, 10 speed chain, STI's and FD on my Soma Double Cross - worked fine. I would run a 50/36 compact crank or get a 52/39/30 triple - that way you can match the FD to a crank it's designed for.
    lamer
    Looks like it wasn't in my gallery, but I did find my old post. Let's see if pasting the quote tags will work
    Quote Originally Posted by llamma View Post
    Did a little more digging, and for those of you that are curious I found this:
    ST-4600 is compat with RD-5701-GS with a cassette that has a max 27 to 32T cog
    source: http://www.celebrazio.net/bicycling/...no_jp_2014.pdf
    Honestly, the B screw wasn't all the way in with the 32T on my Straggler, so if you wanted to get adventurous you could try a 32T if you had one laying around.
    Mar 2012
    have you considered using the sram apex/force shifters&front and x9 rear?
    50/34 with 12/36 rear gives a pretty wide range of gears.
  1. New Hope Pro 2 Evo SS cassette body + shimano cassette = play?
    By marlonpants in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-26-2014, 02:59 AM
  2. cassette/freehub friction when I spin cassette
    By Gabe3 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-23-2014, 08:15 PM
  3. Shimano cassette a bit loose on rear cassette hub
    By anymore in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-04-2013, 03:50 AM
  4. Cassette making noise on biggest cogs.
    By Daemon[CRO] in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-06-2012, 11:26 AM
  5. biggest tire?
    By vqdriver in forum Titus
    Last Post: 09-22-2011, 04:02 PM
