Results 1 to 7 of 7
Thread: Barend Drops
    unrooted
    Reputation: unrooted's Avatar
    Barend Drops
    Anyone used these:Amazon.com: Origin 8 Bicycle Drop Bar Ends, Black: Sports & Outdoors
    Do you think it would be a problem using these in conjunction with normal mountain bike brakes & shifters? If I use these it would save me a lot of money while allowing me to try out CX and upgrade my mountain bike (buy new brakes for it and put the avid discs on the "cross" bike.
    Reputation: Nakedbabytoes's Avatar
    I don't think it would a problem per sey, but you wouldn't be able to brake or shift from the drops like a normal curl handlebar. But as far as seeing how much you'd use such a setup or it being temporary, why not? I would just be aware that you won't get the full benefit since it is self limiting on the lack of braking & shifting from that position.
    2014 Big Dummy
    2015 Salsa Beargrease Carbon 1
    2015 Ice Cream Truck
    unrooted
    Would you say that you would brake more on the road than on the dirt?
    I probably would skip those drops and just ride a flat bar setup. Cross is not high-speed, so aerodynamics really aren't that big of a deal. Plus a race is short enough that you really don't need multiple hand positions, just a high tolerance for pain & pushing yourself.
    Quote Originally Posted by unrooted View Post
    Not necessarily but I wouldn't want to run curls that way. Personal comfort level thing. Probably why I wasn't fond of aero bars. Mine didn't have brakes on them. I like to be able to grab a brake or feather off speed without moving my hands a lot. And I tend to ride CX in the drops, so brakes are a must in that position for me(not gears since I ride SS).
    2014 Big Dummy
    Reputation: shenny88's Avatar
    Those drop-bar-ends are not going to replicate a proper drop bar very well. Assuming you have a modern width handlebar on your mtn bike, those drops will be way too wide (apart) to be comfortable. A road/cross drop bar is only 42-46 cm wide (roughly). Most modern mtn bike flat/riser handlebars are more like 65+ cm wide... its a big difference.
    Long story shot, i'd strongly suggest against them...
    Oct 2013
    yeah those look a little janky to me. I would not get those. they are cool and could be something that would be fine for a time but I think you would just end up going the road bar route anyways. I think you'd be better looking for an old rigid mountain bike that is your size on craigs and to put some newer shifters on it or something....
    I would probably just either do that or get road drops and shifters
  1. 142 drops to 135?
    By dropmachine.com in forum GT
    Last Post: 09-20-2013, 11:51 AM
  2. Shimano SL-BS78 (10sp) barend shifters compatible w/ 9sp in indexed mode?
    By zanq in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-26-2013, 07:08 PM
  3. New to flats, help me with drops?
    By Jwind in forum General Discussion
    Last Post: 06-21-2013, 05:20 AM
  4. OK to hit drops on an ST?
    By lernr in forum Litespeed
    Last Post: 09-11-2012, 12:42 AM
  5. Barend Shootout Volume 1
    By Axis II in forum Weight Weenies
    Last Post: 01-09-2012, 10:04 PM
