Results 1 to 6 of 6
    Reputation: helimech's Avatar
    Mar 2006
    Reducer bushing for a R9
    Does anybody know where to get new shock rear reducer bushings, not the DU bush the steel one where your mount bolt goes thru. Thanks, later.
    SHITBIRD
    Reputation: zahgurim's Avatar
    Aug 2005
    I think contacting Sinister directly would be your best bet.
    Eating Hot Pockets
    Reputation: A. Nony Moose's Avatar
    Sinister might be able to help you, depending on what shock you're using. Your best bet is to go thru the shock manufacturer... you just need to know the bolt size (8mm on the R9) and the overall spacing width at the mounts. (i forget what that is exactly)
    Mar 2006
    Ya thanks guys, I've checked with sinister and they have none in stock. Marzo, Progressive and fox have none either. So I've taken mine to a local macine shop to get some made. The size is 8mm / 39mm. I was hoping to get some that were allready made up instead of going to the machine shop to make some (more $$). Thanks, later.
    SHITBIRD
    Reputation: JRA925's Avatar
    Contact btf95 here on the mtbr forum, might be able to help out.
    Reputation: SuspectDevice's Avatar
    The body end is 40mm not 39mm. Any shop could order you one. Have them order RS8358 from QBP. Should be about $20 at most.
