    Gringo the magnificent
    Reputation: bgmtbiker's Avatar
    Mar 2006
    preston problem-cable housings
    For some reason the cable housing wires have been coming out of the housing(see pics)
    I was wondering if anyone else had this problem.
    Not sure what's going on with them. It looks like the cables were partially damaged an inch or two past the first cable guide causing them to fray. I've never had a problem with the cableing on my Preston in the year i've had it. I'd say it's a result of the cable and not the cable guide on the bike but without seeing it who knows.
    Here's a shot of my cables though i'm not running a front derailluer. My brake line isn't completly straight since i used the same cable off a previous bike.
    preston problems
    Quote Originally Posted by bgmtbiker
    Hey,
    thats not a problem from the transition frame, change your endcaps and you have no problem with the cables.
    Deadhead
    Lose the metal ferrules and make sure the cables are seated all the way when you re-cable the bike.
    "If you can get both wheels sliding with no brakes, that's when you really know that you're cookin." Nathan Rennie
