Originally Posted by ghashmi
I'm soliciting suggestions on set up for bigger hits with the Romic; even the most basic info would be great.
ghashmi:
Glad to hear that you (& your Saber) had a good trip to Whistler. (Actually Whistler was where I broke my rocker pin, hahah...
Anyway, I agree with nhodge about your coil spring being way too light, I'm afraid. So, before you break something...
Here's a
very userful coil-spring weight calculator (thanks to FireDog46) that I've always used, and so far it's always spot-on for me.
Mountain Bike Spring Rate Calculator V4.0
You can play around with the numbers, but - entering your figures - basically you need a 800lbs spring for your weight in 6" mode. Actually 900lbs, if you change the Rear Weight Bias % to "70" from default "60". When I
tried to measure my 17" Saber's rear bias, I seem to recall it was about 70 instead. (These figures per using default "25" % sag punched into the calculator.)
Just FYI, I'm only 165lbs (incl. gear) and
I would be using a 550lbs spring, if in 6" mode (3:1 ratio). I actually used a 450lbs spring since I stayed in 5" mode (2.5:1 ratio), though. (These figures per using "70" % rear bias and "30" % sag punched into the calculator. I always left the Preload Adjuster to default "1.0" and End Coil Effect to default "60".)
I hope that this (especially the calculator) helps, and have fun tuning!
- PiroChu
