Results 1 to 3 of 3
    66rc2x on a Preston?
    Want to put a 66rc2x on my '05 Preston , which I run in 4" mode, but a little worried about tweaking the geo too much. Currently have a Van 36 on there but don't like it cause keep bottoming on bigger hits (have the x-firm spring in there and BO adjust maxed). 66 is a little taller than 36 but I think the bike will kill with the 66. Want to keep it coil so no 66sl. Anyone running their Preston with a 66? Thanks
    Deadhead
    I run mine with the 66 SL and a buddy has a RCX2 on his. I usually run mine around 150mm and can't really tell a difference between mine and my friends. The cockpit spec is essentially the same on the two bikes and I would say the ride difference is negligible whether running 150 or 170mm up front.
    "If you can get both wheels sliding with no brakes, that's when you really know that you're cookin." Nathan Rennie
    conjoinicorned
    Reputation: ferday's Avatar
    fwiw, my friend runs his preston with a super T 170mm, works good.
    what would rainbow unicorn do?
