Results 1 to 5 of 5
    May 2005
    XCL Geometry data?
    Looks like website is broken. Geometry link is not active (no clicky) and on the catalog pdf resolution is so bad, so its impossible to read the numbers.
    Any pointers to the right place?
    Thanks.
    I used to run tubes like you are, but then I got thorn in my wheel.
    Reputation: GhisalloWheels's Avatar
    Oct 2007
    working for me. I click the yellow box nest to where is says geometry and full build kit options. It fades in right next to that.
    Cycle tracks will abound in Utopia. ~H.G. Wells
    Reputation: CHUMBAevo's Avatar
    We do have some bugs on the current website - we will have a new website ready before interbike - if you have any questions e-mail me at alan@chumbaracing.com and I'll get you what you need; or better yet, call me at 1-800-706-0760.
    A.
    Simple | Proven | Reliable
    http://chumbaracing.blogspot.com/
    Reputation: dubjay's Avatar
    Not sure if this will display correctly or not, but here goes:
    Frame Size Small Medium Large
    Top Tube Length 22.5" 23.5" 24"
    Head Tube Angle 69 69 69
    Head Tube Length 4.5" 5.0" 5.5"
    Head Tube Diameter 1 1/8" 1 1/8" 1 1/8"
    Seat Tube Angle 73 73 73
    Seat Post Diameter 31.6mm 31.6mm 31.6mm
    Seat Tube Center-to-Top 16.8" 19" 21"
    Seat Tube Center-to-Center 13.2" 14.5" 14.5"
    Chainstay Length 16.75" 16.75" 16.75"
    Wheelbase 42.5" 43" 44"
    Bottom Bracket Height 13.5" 13.5" 13.5"
    Bottom Bracket Width 73mm 73mm 73mm
    Disc Brake Mount I.S. I.S. I.S.
    Travel 5" 5" 5"
    May 2005
    Thanks. Seems like small there is like Med for most other brands.
    Nice to see that for 2008 it's offered with Fox Float.
