Results 1 to 7 of 7
    Feb 2007
    Seven Sola Gold: the light one
    http://www.sevencycles.be/seven_goes_gold.html
    in Dutch: but the numbers count !!!!!!
    well, that weight
    ordered one:
    Feb 2007
    Feb 2005
    wow, got any more pictures? Did you buy the frame only or was it a complete bike?
    Feb 2007
    hi,
    this is the complet bike:
    9kg560
    with pedals/computer/noTubes/bar-ends
    (and heavy stem/shims/ti-bar)
    ToDo
    stem needs to be changed (2cm to long, and lower angle)
    MightDo
    rotor stem
    rotor 2Xcranck
    crankbro 4Ti
    easton bar without bar/ends
    pic doesn't do the bike justice, it seems cramped
    bought most of it new,
    driveline+cockpit from old bike
    if i had to do it again: 80mm fork in stead of 100mm, suits this "small" frame better
    Nice bike. Did you end up changing out the stem and your suggestions above?
    Feb 2007
    yep, seven ti is on its way
    I used the bike on the Grand Raid Cristalp (Swiss) and it performed greatly,
    only the oil of the fork heated up and the fork performed poorly for a while,
    afterwards the oil cooled down it functioned normally
    (as it does today)
    the bike is as agile and stable as it felt on the first rides
    glad i bought it, it's definitly worth it
    Reputation: Dr Saw's Avatar
    Jan 2005
    Good job! Seven Sola Pic and question
    I like your Gold! Question: What is your height and inseam, and what stem did you end up with?
    I am dealing with dom fit issues now.
    Note: Saddle has been swapped out and moved foward since this pic
    What Hill?
