• 09-03-2013
    JasonL
    Originally Posted by adumb View Post
    awesome thanks for the info.
    one last silly question. the internal cable routing for the shifters makes complete sense to me I just fish those cables through the frame and hook them up like usual. how does the hydraulic rear brake line fit through the frames holes. it has fittings on both ends so I am guessing it won't fit. do I need snip the end of and put another new fitting back on? or is that brake hole only for cable actuated brakes?
    thanks,
    adam
    Nope. All you have to do is unhook the cable from the rear brake lever put it through the frame and install a new olive and barb. This can usually be done without even bleeding the brakes. If you're not comfortable just have your LBS do it for you. The internal routing makes total sense and makes the bike look really clean.
  • 09-04-2013
    adumb
    thanks you have been a great help... this is my least question. hopefully I will buy the frame tonight and still get the discount they are having. but first, how much steerer tube do you think I would need. I noticed my head tube is going to be 15mm longer and it looks like the bearing race cap takes up another little bit. I am not sure if I have that much available. I have four spacers in there and I think they are 5mm each so I only have around 20mm of space to work with.
  • 10-29-2013
    Armando75
    My Razzo build
    Attachment 842820
    Here's my build.
    19in Frame
    1x10 XT with Raceface 33th chainring
    Fox 100mm with remote CTD
    Avid elixir 7 brakes
    Time pedals
    Ritchey cockpit
    San Marco seat
    DT Swiss wheels
    Bathroom scale 22 lbs
  • 11-01-2013
    adumb
    Originally Posted by Armando75 View Post
    Attachment 842820
    Here's my build.
    19in Frame
    Time pedals
    Ritchey cockpit
    San Marco seat
    DT Swiss wheels
    Sharp looking bike. What size stem and how tall are you?
    Any idea on how much steerer tube you ended up using? I want to get the carbon frame but fear the steerer from my al razzo will leave me a hair short
  • 11-01-2013
    Armando75
    It's 5'11 and I currently have a 100mm stem with a flat bar. I'm going to change the bar to a 1in rise carbon bar.
  • 05-24-2014
    itsthebikeguy
    My custom carbon Razzo
    I also have a question i do not like the FSA headset it came with any other riders recommend a headset that's good and I also do not know the dimensions of the headset i should get as well.
  • 07-20-2014
    seat_boy
    I picked up a Razzo SC frame off ebay, and finally got it built up and test ridden:
    I'm pretty impressed by how good the ride quality is on this. I demo'd a Trek Superfly last fall, and while it's dangerous to make comparisons so far apart, I think the Razzo ride pretty similarly.
    You can see more details and pics here.
