Results 1 to 30 of 30
    Reputation: markskee's Avatar
    Caution;  Merge;  Workers Ahead! New Dog Bone Out Now!
    Hello everyone just wanted to let you all know that we currently have a new "dogbone" out. What does this mean you ask? Well basically if you would like your F5 lower to the ground and are currently having stand over issues this would be your winning ticket.
    Bellow I will show you all how to replace a (dogbone) in the first installment of "CHUMBA University" and in the process you will see how our drive side goes together (for those that have had problems with chain guides).
    The process is fairly simple and can be done with one set of hands, the difficulty level is 2 out of a possible 5.
    So lets drop'em like their hot!
    DB's can be ordered @ 714-986-9100 operators are standing by
    1. The new dogbone looks very nice!
    2. The bike to be worked on.
    3. The rocker assembly drive side.
    4. Bottom Bracket/dogbone non-drive side.
    5. Remove rocker shock mount screw.
    6. Screw is out (wow that was easy).
    7. Swing shock up and out of the way.
    8. Time to remove the chain guide lower pulley.
    9. Lower pulley off (simple).
    10. Remove upper chain guide taco (makes me hungry).
    Steps 11-18
    11. Slide it back to the end of the bike.
    12. Wow look A naked chain ring (close your eyes if you are under 18).
    13. Remove your drive side crank.
    14. Put your back into it.
    15. Crank and chain ring off (wow your good at this).
    14. The bottom bracket axel exposed.
    15. Remove the chain guide boomerang.
    16. Boomerang off.
    17. CHUMBA chain guide mount exposed.
    18. Remove upper dogbone screw.
    19-29
    19. Screw is out.
    20. Remove lower dogbone screw non-drive side.
    21.Screw is out.
    22. Tap swing link upper mount.
    23. Lift tire and tap a few more times to pop out upper dogbone pivot.
    24. Use a leaver and wedge out lower dogbone mount.
    25. Almost there.
    26. Ahhhhh at last it's out.
    27. Now replace with new dogbone in reverse order.
    28.The new and the old (note that the lower DB mount non-drive side has a thinner screw and the upper mount to the swing link has a thicker screw the holes on the dogbone correspond to this large to large thin to thin).
    29. Go have fun and enjoy your bike!
    nerfherder
    Reputation: scruffylooking's Avatar
    Wow, that is one comprehensive "how-to". Well done. So, I don't own and F5, but I'm sure others are wondering, too. What are the new geo numbers? Lower BB, slacker HA, slacker SA, and longer WB?
    Flying Goat
    Reputation: mrpercussive's Avatar
    aaaaaaaaaaahhhh... the long awaited dog bone... XD
    Will definitely be get one when i pick my bike up on my trip to Fontana end of this month... hehe
    Does it shorten the travel a little?
    Flying Goat
    Quote Originally Posted by t-boner
    from the looks of it.. it shouldnt...
    Quote Originally Posted by mrpercussive
    Please take some before and after measurements.
    Pretty cool to see the pics of the swingarm and linkage torn down like that, don't have an F5 but def on the short list. Does it ride like a KTM?
    Reputation: edray's Avatar
    Will this work on the F4 too?
    Cheers
    Reputation: rollertoaster's Avatar
    +1 for update geometry specs. I'm not even sure I could have a lower BB with all the rocks on the East Coast.
    Team _________
    Not too bad
    Flying Goat
    Quote Originally Posted by supercub
    not going to be 2 weeks til i hit Fontana and get one on my bike... but i'll definitely get some measurements for you... Does it ride like a KTM??? No idea, never rode moto... it definitely is prettier though...
    yarrrp
    can i also get a sealed bearing pivot as well when I order?
    got mine!!
    now hurry up and make some more fixed brake mounts, and jerseys!!
    braap!
    yarrrp
    I am very very happy with my new fixed brake mount. There of course is a trade off, but worth it I think.
    Flying Goat
    Quote Originally Posted by Connor
    got mine!!
    braap!
    very sick... was at the Fontana Nationals today and was hoping Walter had a few on hand... oh well... will be seeing the Chumba van at Sea Otter again
    Reputation: 360shuvit's Avatar
    BB and HA measurements with new dogbone
    Has anyone compared actual BB and HA measurements with the new DB? I would like to know. Thanks.
    Flying Goat
    got mine last week. Original BB was at like 14.6". New BB height is at about 14". Not too sure about the HA but it's definitely slacker...
    I can confirm the just over a half inch lower BB and I measured 1.4 degrees slacker HA.
    Reputation: kona kid's Avatar
    I can't get the upper dog bone bolt out. The nut threaded itself out but the bolt isn't going anywhere. Apply some penetrating lube and bash it?
    steep fast and loose :)
    excellent write up - can we get something similar for vf2 bearing service ?
    Reputation: bigcrs's Avatar
    Excellent writeup!
    Does anyone know if the lowering link mods are available for the XCL yet??
    MV Rider
    They have been out for sometime. I got my links several months ago directly from Chumba.
    Oct 2011
    Quote Originally Posted by kona kid View Post
    yep. the same thing happened to me and i had to hammer it out
    Looking for longer dogbone.
    Does anyone have the longer dogbone or rigid brake mount they would like to sell?
    Reputation: danmtchl's Avatar
    Sep 2004
    So is this through Chumba? So they still are in business? Will they actually answer the phone? I would be mighty skeptical buying anything from them due to past issues.
    Double-metric mtb man
    Reputation: Psycho Mike's Avatar
    The tread was started in '09 and was dead for over a year old before it was resurected...Chumba went silent on the boards (this one and theirs) ~3 months ago now.
    I still keep hearing the tone of a cardiac monitor in flat-line ("beeeeeeeeeeeeeeeeeee....") every time I think of Chumba...
    As if four times wasn't enough-> Psycho Mike's 2013 Ride to Conquer Cancer Page
    Moran? Let your opinion be free -> F88me
    May 2012
    Hi guys, there is a email address to order the dogbone 3.5?
    The phone number will help me unfortunately, since I'm from Germany.
    Chumba responded to my emails, unfortunately not,but I would like to have the 3.5 dogbone for my bike for sure.
    Tomek...a lot of people here have been trying to get a hold of Chumba for a while. They have basically vanished and it's been extremely difficult for anyone to get a hold of them.
    I wouldn't hold out much hope of getting a Dogbone 3.5...ride what you have, enjoy it until it breaks is about the best I can tell you for now.
    Nov 2008
    Want a 3.5 dogbone
    Anyone have one for sale or know where I can get one ?
