Results 1 to 9 of 9
    I hate you, head tube
    so i have been searching for a couple of days now, tried seeing if i could call the manufac., and went to a couple of bike shops to see what size headset fits my orbea sport frame. I am getting so frustrated with the fact that no one can help me and I just want to ride my bike. Does anyone here know about orbea bikes? please lend a helping hand...
    this doesnt really help without any type of explanation...
    Reputation: Eric Malcolm's Avatar
    Dec 2011
    You could dismantle the bike, removing fork and bars, to remove the headset.
    Its not a time consuming job and you have to do this anyway to fit a replacement headset.
    If you cannot get the info you are looking for, what option do you have?
    This is a Framebuilding Forum, having knowledge of frame construction, not what is coming out of factories and can advise on there many models. This is a question for a LBS who sells your bike.
    Eric
    If I don't make an attempt, how will I know if it will work?
    There's basicly 4 that fits. 1 1/8 standard, 1 1/8 inset/zerostack, 1.5 oversize, 1 1/8 top with 1.5 bottom tapered.
    Just by glancing at their prebuilt bikes, it looks to be 1 1/8 inset/zerostack.
    its not being replaced. i have a bare frame and have bought two headset already that dont fit. also i know for a fact its not a bottom tapered, 1 and 1/8 standard, or a 1.5 oversize. but from what ive searched there are many different types of other 1 1/8 headsets...is there something i need to search for more specifically? I meandsured the head tube and its 2in OD and 1.75 ID...
    Who turned out the lights
    Reputation: Francis Buxton's Avatar
    Do they not list anything on the Orbea website stating what kind of headset the frame uses?
    Going Here:
    http://www.orbea.com/us-us/bicis/mod...pecificaciones
    I see that the 2012 G10 uses a 1 1/8 semi-integrated, which would then allow me to purchase the correct Cane Creek headset.
    You haven't listed what frame you have, etc. You should also look on their website to find a local dealer, who should be able to give you advice also.
    For intents and purpose the measurements are roughly:
    ~1.75 = 44mm = 1 1/8 zerostack
    2in = ~50mm
    1 1/8 zerostack is for a 1 1/8 fork, but the whole cup/bearing sits inside the head tube.
    Check out the Zero Stack or "Low Profile" section.
    www.cyclingnews.com news and analysis
    semi-integrated=zerostack=inset
    All my frame says is that it's an orbea sport...so I will prolly be needing a semi integrated 44mm...
