Results 1 to 7 of 7
    Reputation: markskee's Avatar
    Hope Hub conversion kit info?
    I have a F5 and a set of rims built on hope hubs that were on another bike, right now the rear rim has a hope hub set up for QR. What I want to do is convert the rear hub/rim to work with the F5 axle, does anyone know which conversion kit I need from Hope? Thanks for the help and here is where I was looking for the solution just dont know if what I need is listed here.
    http://www.jensonusa.com/store/produ...sion+Kits.aspx
    Reputation: Mar-deeb's Avatar
    Give Hope a call, I have always found them friendly and always keen to help, perhaps this is why I have been riding Hope hubs for 14 years!
    Reputation: dubjay's Avatar
    The F5 has a 135x12 rear axle, so from the link you had, you'd need to get the Pro 2 Rear Hub qr-to-12mm Kit - which happens to be out of stock.
    Quote Originally Posted by dubjay
    Thank you for the input.
    Flying Goat
    Reputation: mrpercussive's Avatar
    look what i found while browsing for hubs...
    http://www.pinkbike.com/buysell/338379/
    It's very useful to use the Hope Hub Tool Kit for the conversion.
    Got it all taken care of I just called Hope the part is on it's way.
