Hi folks I've got a problem.. the equallink bolt has worn through the hole on the main frame. The bearings have not stopped it from eating away at the frame and now there is about 1mm play and it makes a slight clicking noise when i peddle from the gap! Has anyone had this problem before? Aan it be fixed by a specialist cnc engineer or something along those lines? your help would be greatly appreciated
Help! Worn bolt hole in frame! can it be fixed?-untitled6.jpgHelp! Worn bolt hole in frame! can it be fixed?-untitled5.jpgHelp! Worn bolt hole in frame! can it be fixed?-untitled4.jpgHelp! Worn bolt hole in frame! can it be fixed?-untitled3.jpgHelp! Worn bolt hole in frame! can it be fixed?-untitled2.jpgHelp! Worn bolt hole in frame! can it be fixed?-untitled1.jpg
