Results 1 to 14 of 14
Thread: Building an EVO
    Reputation: scoholofo's Avatar
    Building an EVO
    I am getting ready to order parts to build up an EVO. Any suggestions aon parts to order? I live in Colorado and need it to be able to climb but still be beefy enough for light downhill at some of the local ski resorts. Not too worried about weight but would like to keep it under 35 lbs.
    Flying Goat
    Reputation: mrpercussive's Avatar
    How about.........
    Totem, Deity Dirty30, Twenty6 50mm stem, Shimano XT Servo, 2.5 Minion DHF 3C, 2.35 Highroller 60D, Hope Pro II laced to Syncros DS28 with DT Comp spokes. SRAM XO shifting...
    yarrrp
    This should be called how to make a bike suck at climbing
    Quote Originally Posted by mrpercussive
    How about.........
    short stem is good. 2.35 highrollers at the most. fox 36 talas or lyrik two step. save your money on the xo shite and get x9 and the best wheels you can afford to wreck that way you are only focusing on the ride and not if you are going to ding your overbling wheels. azonic outlaws are okay but heavy. The trick is going tubeless. I run the syncros ds 28s and they are okay for tubless but the dt 5.1ds are much better. You will destroy these rims in a season but they are light and fast and hold tubeless perfectly. The mavic 721's are also very good.
    this is where i am at right now but willing to take suggestions as this is the first bike i have built from the ground up.
    Fox talas 36
    xtr shifters
    xt crank
    xt FD
    XT shadow RD
    sram 990 cassette
    sram 991 non-hollow pin chain
    FSA Gravity carbon DH bars
    Hope tech m4 203 front 185 rear
    Mavic 819 rims laced to hadley hubs
    thomson 50mm 0 degree stem
    Crank Bros Joplin seatpost
    schwalbe fat albert 2.4 front and rear UST tires
    probably an E13 drs bashguard chainguide. Nver run a dual ring setup could use some advice
    sounds to me like you already made up your mind!
    go with the xtr rear derailleur and switch the shifter to xt
    yarrrp
    that sounds good!
    go for sapim cx ray spokes!
    ride hard take risks
    Reputation: dogonfr's Avatar
    Jan 2005
    Quote Originally Posted by scoholofo
    Dual ring is awesome, 22X34 or 36 with a bash. Front derailleur is adjusted so it stops at the middle ring using the adjusting screw.
    If you decide to go 3 ring and will be riding aggressive I would suggest a bash to protect your leg.
    Formotion Products
    http://www.formot
    Any recomendations for what works well for a chainguide on the EVO or any chainguides people have had problems with? Also I thought about the xtr rear derailleur but thought i will be too rough for it.
    Reputation: bullcrew's Avatar
    Jan 2005
    That should come in nice, Im specing out mine right now. Should be done by March.
    07 Evo (got a smokin deal)
    X0 rear der
    XT front der
    X9 shifters
    fox 36rc
    I9s laced to 5.1s
    xt hollow tech cranks
    e-13 drs
    Xpedo mag pedals
    thomson stem 50mm
    dirty thirty bars
    SDG Ibeam and Ifly saddle
    I do more freeride than anything but still want a fairly light build but beefy enough to hold 230lbs of aggression!
    Look forward to seeing your build! Pics!!!!
    My Sponsor House
    "I dont make memories, I make History."
    CANFIELD - AVALANCHE SUSPENSION - SCHWALBE - TLD
    yarrrp
    I run a short cage x9 with a super short chain length that only lets me shift into the 24 rear from a 32t ring with a front derail and a bash guard. I ripped miles of wicked downhill and have only ever droped my chain a couple of times. It works perfect!!
    Reputation: CHUMBAevo's Avatar
    For chainguides I would go with e.13 - the EVO runs ISCG 05.
    Simple | Proven | Reliable
    http://chumbaracing.blogspot.com/
    What duel ring guide for a pre ISCG mount Evo
    I'm building up a 2007 Evo which has no ISCG mount. I ran an E13 DRS on an old Bullit and it worked great but the Evo has the E-Type front deraileur added into the mix. I am wondering if they will work together or if there is another type that would be better like a LRP, Blackspire Stinger or Heim Guide. Feel free to chime in Chumba!
    Quote Originally Posted by 67degrees
    You will need one of these if you use an e-thirteen drs system.
    http://www.treefortbikes.com/463_333...RS-Guides.html
