Results 1 to 5 of 5
Thread: 160mm on XCL ?
    160mm on XCL ?
    I'm sure the frame could take it, but how will the bike handle ?
    Got a Pike right now, and it's nice, but curious to try a 160mm fork ...
    Anyone try this ?
    the train keeps rollin
    Reputation: snowdrifter's Avatar
    try searching this forum, it's been discussed here.
    beaver hunt
    Quote Originally Posted by PizzaMan
    Anyone try this ?
    I had a TALAS 36 on my XCL. At 160 it climbed ok. The front end would wander. The bike descended real nice at 160. Ideally, I kept the travel at 130 for flats and climbing and I would increase the travel to 160 for descents. The TALAS 36 matches up nice with the XCL
    Reputation: Scottandhisdog's Avatar
    Feb 2005
    I am running a Lyric travel adjusts between 160-115mm and it is nice. It also helps tighten up the wheelbase when it's wound down to mount on my friend's roof rack. At 160 it's too long for the rack.
    I posted my review of my XCL somewhere on here. The Lyric is really nice, but I usually ride it around 145-150mm, so you might not see a huge difference from the Pike. I think that the Pike is a bit lighter, and maybe not as stiff. Overall, I love the bike the way it is, not lightest, but I never worry about riding an area because she won't brake.
    Compulsive Bike Builder
    Reputation: DirtDad's Avatar
    May 2002
    As long as you can lower it
    I agree, I thought the Talas 36 worked real nice on my XCL, but I used the 130mm setting a lot, esp for climbs and tight singletrack. The only time I did not care for it was on steep loose tight singletrack descends. In that specific case I wanted longer travel and slacker front angle than 130, but the 160 was too slack and tended to wash out in corners.
    Disclaimer: ComCycle USA
