Page 1 of 8 12345 ... LastLast
Results 1 to 100 of 717
    sapienti sat est
    Reputation: BikeBert's Avatar
    Caution;  Merge;  Workers Ahead! Thomson Elite Dropper Post Thread
    Thomson says they'll work on a "stealth" version once the initial release is dialed.
    • Telescoping seat post
    • 5''/125mm drop (internally adj. to 4'')
    • Infinitely adjustable travel
    • Hydraulic internals
    • Nitrogen return spring (not adjustable)
    • Lever-adjustable return speed
    • Weight: 450g (prototype) 592g (final version)
    Update 29.08.2012
    Quote Originally Posted by pinkbike.com
    Thomson stirred up a hornet's nest of activity when they teased riders with a few quick photos of their upcoming telescoping seat post on their Facebook page a few months back, but no other information was available at the time. Fast forward to Eurobike and they were showing off the new post, dubbed the 'Elite Dropper', in their booth, which we made our first stop of the show. The post is still in the early prototyping stage, with only a few functioning samples in the wild at this point.
    The Elite Dropper offers 5"/127mm of infinitely adjustable travel, meaning that it can be positioned anywhere between and full extension fully lowered . The travel is controlled with a sealed cartridge (it can be worked on by a service center, though) that separates the post's hydraulic oil from the non-adjustable nitrogen return spring that is set at 135psi. Thomson has employed a clever second check valve within the cartridge that keeps the post from pulling up through its travel when lifting the bike by the saddle, thereby remedying a somewhat annoying trait of some other hydraulically controlled posts.
    While it looks as if Thomson has refined existing dropper post technology rather than reinventing it, they have done something completely different to eliminate any side to side saddle wiggle from the Elite Dropper. Rather than use multiple keyways to keep the round stanchion from rotating, an interesting sixteen-point shaft - that fits within a matching sixteen-point profile within the outer tube - is attached to the bottom of the stanchion. This requires assembly to involve sliding in the stanchion from above, then threading the sixteen-point section into place through the bottom of the outer tube, followed by screwing the silver bottom cap onto the bottom. This layout allows Thomson to utilize traditional round bushings from Norglide to keep the post's travel smooth, although the upper, stationary bushing sports a custom finish to further enhance the post's movement.
    Thomson is being very clear about one thing: reliability is the focus of the new dropper post. They are aiming to have the Elite Dropper trump everything else on the market when it comes to longevity, a goal that will likely make the Thomson post a favorite among riders if fulfilled given how unreliable most current designs are.
    Head-mounted actuation The Elite Dropper's actuation arm is located on the side of its two-bolt head (that features the very same rail clamp as used on their standard seat posts), with a bolt-on cable stop and arm that is pulled on by a standard shift cable. Hidden from view within the post's head, the actuation arm pushes down on a plunger located at the top of the cartridge, thereby opening the oil port and allowing the post to stroke through its travel. Interestingly, Thomson allows riders to choose from varying rebound speeds despite its shift cable actuation thanks to a cam design on the plunger that determines the amount of oil flow allowed when engaged - pushing the lever completely through its travel will result in a faster return speed than if the rider only depresses it partway. While we didn't get to try the system on a bike, it should allow riders to easily find those partially dropped positions.
    Remote or under seat Two activation options will be available, allowing riders to pick from either a remote or under-the-seat lever. While still likely to receive some minor changes before production begins, the lever employs an ultra-slim footprint that easily fits between the other controls on your bar, as well as being hinged for simple installation and removal. The under-the-seat lever is likely going to be less popular than the remote, but using it will reduce bar clutter, if that is a concern. It is bolted to the same mounting location as the remote actuation arm, and pushes the cartridge's plunger down in the same way when pulled.
    Hydraulic cartridge Thomson isn't shy about admitting that the Elite Dropper's cartridge is outsourced to another company; they wanted to focus on the machined structure and design of the post and let a team with experience in hydraulics design take care of the internals. The hydraulic oil is held within the upper section of the cartridge (right), with the activation plunger at the very top. At the bottom is the nitrogen chamber that is pressurized to 135psi. This pressure is not adjustable, something that many riders have used in the past to adjust their seat post's return speed, simply because the cam design on the plunger allows the user to select rebound speed by how far the lever is pushed.
    Non-adjustable nitrogen The Elite Dropper's outsourced internals are laser etched at the bottom of the post (left), including the nod to its Norglide bushings and Motul oil. The threaded silver bottom cap (right) allows access to the post's internals, while a specially-shaped plug at its center keeps users from letting the nitrogen gas escape accidentally.
    More info at pinkbike and Thomson
    update 30.08.2012
    Quote Originally Posted by BikeRumor.com
    LH Thomson’s in a comfortably tough position. Riders generally just assume their stuff will be flawless, but that means it needs to be flawless before it ships. That’s part of the reason this thing’s been in the pipeline and rumor mill for so long. Now, it’s come out of vaporware.
    Dropper seatpost will ship with both the lever and the remote. It’s a simple single bolt swap using a suicide bolt that’ll snap on impact to save the post if you wreck. The slider uses a 12-sided star shaped lower section (think Torx but with more V’s) under the hood to prevent rotation. That provides a ton of surface area to bear the load. It slides on Norglide bearing/bushings with Motul oil and Trelleburg o-rings and upper bushings. Once the bushings are made, then they’re finished to provide a tight seal but keep moving easy.
    The cartridge is nitrogen charged and not user adjustable. The lever can be pushed anywhere in the range to control both depression and rebound speed. Floor it and it’ll drop at one foot per second, but it can go much slower than that for those of us that like to hover on it to drop slowly until it’s at the right spot. So, yes, it’ll stop anywhere in the travel range and lock there. It uses a second check valve that keeps it from pulling up when depressed, so you can lift the saddle without yanking the post up. Available in 30.9 and 31.6 with 125mm travel. Fully extended, it’s 400mm tall. Cable management is a closed loop, so it won’t pop out and get in the way.
    David Parrett says the internal spring is strong enough to support the rider, so the post should be very durable. The top bushing is pretty tall and the bearing-bushing is 125mm long, the length of the travel. Their goal was to make it last in the worst snowy, sandy conditions for two years before needing to be serviced. When the time comes, you’ll have to send it in for work. They decided to make it a completely sealed, non user serviceable system to reduce headaches.
    Retail will be $379, available Spring. Weight is 450g with the lever, a bit more if you add the remote and its 60″ of cable. The housing and cable will be automotive grade materials, so they recommend not swapping it out as it should last the life of the product.
    More info at bikerumor
    ____________________
    | Picasa | YouTube | Pinkbike |
    absolutely beautiful!
    Reputation: Steve.E's Avatar
    It looks solid, as to be expecting being a Thmoson!
    As a UK user I find the biggest weakness of my i950 is the cable system under the seat, it's constantly clagged up with mud, for this reason I hope the cable clamp and system has some sort of appropriate shilelding from the elements.
    Looks stunning. Now show a pic of the internals. Or rebuild instructions.
    Reputation: 'size's Avatar
    Quote Originally Posted by the-one1 View Post
    non user serviceable cart.
    link to where OP got his info : Thomson Dropper Post - Eurobike 2012 - Pinkbike
    Mar 2012
    They all look awesome before anyone has ridden them. I'll start paying attention after people have been abusing them for a couple months.
    I'm interested on what method is used to stop the post from twisting.
    sapienti sat est
    From pinkbike:
    Reputation: Calhoun's Avatar
    Nov 2008
    Love Thomson, but this is a fail. Just like the Fox.
    Need more collar mounted actuators.
    "Mi amor Nuevo Miércoles!"
    -cabra cadabra
    Reputation: 006_007's Avatar
    Agreed - attachment at the head of the units is not gonna win people over. Collar actuated is what will make people stand up and take notice. And 150mm drop is much more appealing as well.
    I also think KS has continued to do a better job with the bar mounted actuation lever (although hopefully the Thomson one feels better then it looks?)
    I had really high hopes for this post - am admitting a bit disappointed. Looks like I will be going the KS LEV route to replace my KS i950.
    Reputation: Trail_Blazer's Avatar
    May 2012
    looks sexy!
    #THELEGEND
    Reputation: Guy.Ford's Avatar
    IMO,non stationary cable = fail. Resolve that nuisance and 5 stars!
    #THELEGEND
    2016 RSD Mayor
    2018 Diamondback Release 5C
    2017 Diamondback Haanjo Trail
    May 2012
    Quote Originally Posted by Guy.Ford View Post
    good point!
    Reputation: Whip Chop!'s Avatar
    So, it's either failure or 5 stars? No middle ground? This is hilarious as a few years ago Gravity Dropper was still the only one with a fixed cable. If you read the press release, Thomson feels the design favors durability and that a fixed cable design would compromise this. I'm sure they will have a fixed design in the future.
    GAME ON!
    at this point in the game, it's hard to understand why a stationary cable ISN'T the de facto standard. it is what the majority of the public wants and there are already several non-stationary models that work well. if a company wants to set itself apart, make a reliable, beautiful, lightweight post that has a stationary cable.
    i love the look of this post, i love the quality of thomson products and i love the weight, however, i'll wait until the cable actuator is moved to the bottom. that is the only selling feature to me that puts one post above another (among posts that work well, of course). the ks lev is waiting to take my money.
    RIP Adam Yauch
    "M.C. for what I AM and do, the A is for Adam and the lyrics; true"
    screamer
    Reputation: budgie's Avatar
    Stationary cable? Cables work by moving, don't they? Not following what the gripe is...
    Looke like a winner from where I'm sitting.
    On heavy rotation: White Lung: Deep Fantasy
    so it has an under-the-seat lever option. or maybe that's the default, as their website lists a separate price for the remote? having the actuation mechanism at the bottom will exclude this option. whether they thought there's a significant market for this, or whatever the reason is, is another matter though..
    Quote Originally Posted by budgie View Post
    i believe the gripe is that there's an "extra" cable length dangling when the post is at the dropped position if the actuation mechanism is at the head of the seat post. this won't be the case if the actuation mechanism is at the bottom.
    Reputation: anvil_den's Avatar
    Nov 2007
    Yes, given that its already been so many years, I would have believe that the "technology" and all should really be able to make posts with an actuation lowered so they wont be a moving cable. Otherwise looks like "just another of those" in the market...
    Plus from the pics, the whole actuation shebang rear facing-- clogging up, smoothness in operating over time and the usual problems plaguing many of these adjustable post are still all there so far as i can see. Fancy cnc work (yes they are nice) do not detract from the issues.
    Still cant wait to get my hands on a LEV... seems to be the only one right now that is the most well thought out.
    > /dev/null 2&>1
    Reputation: Procter's Avatar
    Feb 2012
    Moving cable? I have a joplin, I never notice the cable when in the fully squat position. If you zip tie it to frame somewhere around the top tube/seat tube joint, then all it will do is stick out a little bit on the back of the bike it, and really won't get in the way, unless you are doing some serious jumping and trying a Can Can or a double grab, which would mean you're on a DIRT BIKE.
    But seriously, what is the objection to the cable sticking out a little in full squat? I hope its not just out of aesthetic purity
    To me these new posts are almost all infinitely adjustable, have about the same feel (damping vs. spring), have a remote, etc. So the decision for me comes down first to long term durability (since many have had issues) and second, weight.
    Reputation: Shalom's Avatar
    Nov 2008
    I am not too fazed about the cable, personally. I will be using the under-seat-lever myself. I prefer my bar to be uncluttered, and most of the time I am able to see far enough ahead to have plenty of time to lower the seat. If not, I have ridden non-dropper posts for long enough to be able to get through most anything the trail can throw at me. So for me, this looks fantastic!
    Nov 2008
    Quote Originally Posted by ddprocter View Post
    Not all frame designs favor your method. Several frames have linkages where the cable droops. The cable droop can also cause some unnecessary frame wear. Sure it is just paint and it can be covered, but why not eliminate the excessive cable and make the post actuate from the collar area?
    -cabra cadabra
    Reputation: Joules's Avatar
    Quote Originally Posted by Calhoun View Post
    the 2 reasons that come to mind immediately are, I believe Thomson said they felt this design was more reliable than what they could do for the cable attaching to the fixed portion - which IMO is huge because at present there isn't a post on the market that I would call reliable, at that matters more to me than a little paint wear.
    and second, looking at posts like kronolog, it means a lot more minimum exposed post. Which isn't that much of an issue for me personally, but I could see why they'd want it to work on more frames for more riders.
    A fixed cable would be nice, but not if it means sacrificing reliability.
    What I'd really like to see is more frame manufacturers including provisions for internal cables, like reverb stealth, and the KS LEV with the internal cable. From the looks of the cartridge, I'd guess Thomson could make a "cable out the bottom" model pretty easily by flipping the cartridge upside down.
    Nov 2008
    Quote Originally Posted by Joules View Post
    not trying to flame here, but where did you read that? I read through the Pinkbike article and did not see that mentioned. Is there another article available?
    non-issue if the travel is adjustable IMO, but also this does not effect me so maybe I am missing something.
    couldn't agree more
    -cabra cadabra
    Dec 2011
    I like it, looks badazz like the krono but Im sure it will work better. A little silicon/rubber hood for the cable end would keep any dirt out.
    Flyboy
    Reputation: pilotmandan's Avatar
    I will for sure be getting one. Will be using the lever too... no cables! If it follows the same quality as other Thomson items, it will be a winner for sure.
    Pivot Mach 5.7c
    Jamis Dakar XC Pro
    Sette CX-1
    I will second that like the idea of a dropper post but for the amount of use I prefer the lack of messy cabling. Any idea on weight , price, availability etc?
    Nov 2008
    dog
    dog is offline
    sit! stay!
    Reputation: dog's Avatar
    i was hoping for a good post with an under-seat lever... i know KS makes one that i could get now... choices...
    i need to develop my crashing skills...
    Reputation: jgusta's Avatar
    Quote Originally Posted by 006_007 View Post
    Ditto this as I am looking for a reliable external 6" post to replace my KS Supernatural that is just too finicky and maintenance intensive for me, but I came off years of using GD posts that would keep on running no matter what (If you could get past all the play at the seat clamp within a few months of replacement of course).
    Ride On!
    Reputation: playdead's Avatar
    Quote Originally Posted by EmbudoMatt View Post
    I agree. They all look very cool, but lets see someone throw it on a hard tail on some techy trails.
    "Bound to cover just a little more ground"
    Bicyclochondriac.
    the 2 reasons that come to mind immediately are, I believe Thomson said they felt this design was more reliable than what they could do for the cable attaching to the fixed portion - which IMO is huge because at present there isn't a post on the market that I would call reliable, at that matters more to me than a little paint wear. .
    I would definitely call the Gravity Dropper reliable.
    sapienti sat est
    stealth mode ON
    RideDirt
    Reputation: aedubber's Avatar
    Their handlebars look pretty nice !
    Oct 2007
    Quote Originally Posted by BikeBert View Post
    Where did you hear that? If that is the case then that is great news. I will probably buy the KS LEV now and when the Elite Dropper stealth version comes out get that one too. I can then decide which post goes on mine and my wifes bikes since they have the same seat tube diameters.
    official:
    Thomson Bike Parts
    All right people: The dropper will be offered in a stealth through the frame cable model in March, at the same time as the external model. You asked, we listened!
    May 2012
    Awesome news! Go Thomson!!
    lidless ascender
    Reputation: problematiks's Avatar
    Quote Originally Posted by 'size View Post
    official:
    Thomson Bike Parts
    A LEV or Kronolog-like cable placement would be better I think as it would fit more frames.And to be honest I never liked the idea of Reverb Stealth as it proves to be a PITA if you want to remove the seatpost.
    I really like the look of the post though (and even more the potential of a quality product since it's coming from Thomson) so I guess there's still the option of a non-stealth version for guys like me
    Marko
    I asked God for a bike, but I know God doesn't work that way. So I stole a bike and asked for forgiveness.
    Pictography
    Helmetless Crasher
    Reputation: Stumpjumpy's Avatar
    I prefer the under-seat lever. I would rarely use the dropper function - MUCH less than I use ProPedal, for example. So I'd much rather do without the weight/clutter and potential for fail that a cable set-up provides.
    Hopefully, Thompson does a set-back version of this post for the long-femured.
    '95 M2 StumpJumper FS
    '11 Cannondale RZ 120-two
    GAME ON!
    you'd use it more if you had it.
    RIP Adam Yauch
    Bicyclochondriac.
    Quote Originally Posted by saturnine View Post
    Agreed. If I had to reach down under the seat to shift gears, I would do that a lot less, too.
    official:
    Thomson Bike Parts
    Would I be admitting too much if I said this makes me.. you know... horny?
    I recently had my i950 in for repairs and was stuck with a joplin 4 for a couple of weeks which did not have the remote. I found I used it way less and it was more of a hassle while riding to drop it just prior to rock sections ect. I can't imagine not having a remote after that.
    Helmetless Crasher
    95% of my riding is XC.
    Thus, even if the dropper function were somehow hardwired to my medulla oblongota, I'd rarely use it.
    Reputation: schneidw's Avatar
    Mar 2005
    Setback Version
    Will this design allow for a setback dropper post? All my bikes have Thomson setback seatposts to dial in my fit (long legs)...
    Reputation: Hardtails Are Better's Avatar
    May 2005
    Quote Originally Posted by schneidw View Post
    Doubt it. I don't see Thomson going to a different clamp mechanism and the bent arrangement they use for their setback normal posts obviously won't work here.
    Totaly agree, can't believe two companies that claim to be on the leading edge of componentry release a post with a cable attached to the top of the post. Until bike companies all start addopting stealth internal routing more companies need to wake up to the fact that having a massive loop of cable when you drop the post is a massive weakness.
    May 2005
    Quote Originally Posted by thrower78 View Post
    On the flip side, a post with a seat collar cable mount is inevitably going to be more complicated than an otherwise identical design with either internal or seat clamp routing, and I'd consider that to be a "massive weakness," particularly on a part that's already a whole lot more complicated than the alternative (i.e. a normal post). I'm all for pretty bikes but I just don't see this one as being worth the trouble. And yes, I do own a post with a moving cable mount.
    Apr 2005
    From the company making the cartridge for this post:
    Robert De Rose In order for the cable to be routed at the bottom, the durability and functionality of the internals would drop. We looked at the different options; and the durability of the cable and it's use in the field was less concerning than the durability and functionality of the internals. The overall systems durability was the driver. So when given the choice of which functional aspect to go with, we choose the cylinder functionality over the cable placement. Their should be a 30.9mm, though the 31.6mm will come out first. Won't be able to make a 27.2mm size as it gets to small to fit all the components in, with the same functional requirements. Also it wouldn't meet the structural requirements at such a small diameter.
    I assume the Stealth version will get around this issue. The adj post market is filled with the wreckage of unreliable products; of course Thomson is going to make reliability a top goal. I have no routing issues w/ the Reverb cable.
    Originally posted by bucksaw87
    I still fail to see how mustaches, fixies, and PBR are ironic.
    Mar 2011
    Quote Originally Posted by kapusta View Post
    Ditto on the Gravity Dropper. It is reliable, 400 hrs of use so far and no issues.
    sapienti sat est
    Msrp $399
    According to the last press release MSRP just went up to $399.
    I wonder how much more the price will be raised before the post will eventually hit the market next year.
    Reputation: Thiago7's Avatar
    Jun 2010
    Im so not buying this piece of fail.
    KS LEV is the way to go!!
    Reputation: travman's Avatar
    Finally in the market to buy a dropper post - was all set to order a Reverb but now debating waiting to see how this one works.
    I guess I waited this long - whats another few months, especially with winter around the corner.
    more news : bikerumor
    bluetooth control you say??
    "...they’re actually working on a Bluetooth controlled circuit that can remotely actuate the post...eliminating the cable without sacrificing convenience…which is the ultimate goal. The immediate plan is to have a standalone Bluetooth switch that can be placed anywhere on the bike, but eventually they’ll have a smartphone app capable of controlling it.
    By integrating the GPS, accelerometer and computing power of a rider’s smartphone, the app could automatically control the seatpost height based on incline/descent. Or, you could program it to learn a course and adjust the height based on location. No ETA on this, but they’re working on it."
    it's been said before, but the evolution of these posts has to get the point where they can be lowered without the rider needing to use their weight. this sounds like a decent first step in that direction.
    Reputation: jkidd_39's Avatar
    Sep 2012
    Wow!! Go from a stealth mount vs not so stealth mount argument and just blow it all out if the water!!
    Very cool idea. Thomson is awesome. But please don't borrow gopro's programmers for the software.
    RideDirt
    While all that tech seems cool , i would just like a dropper post that " works " .. Anyways gettr done already !
    I don't know about the whole dropping via GPS thing but I do like the idea of a cable-less remote. That would be cool.
    Can't wait for this thing to come out. I'm still waiting for my Kronolog to fail and when it does I will be replacing it with one of these, as long as they hold up like all of Thompson's other products.
    Dirtbag Medic
    Reputation: "Doc"'s Avatar
    Jan 2013
    Nice! Side question, what carbon bar is that?
    I mostly just skim the important bits
    Nov 2008
    Apr 2005
    "Claimed weight – 592g, with remote, cable, and housing – on the 127mm-travel (5in) post has creeped up a bit".
    Hmmm. That'll disappoint some customers.
    $449 now....and climbing?
    Oh hell no on a GPS enable dropping control. Is it going to pedal for me too? This seems like a fluff idea that is designed to solve a problem that does not exist.
    Post reply to this post if you just cannont decide to drop your seat on a decent or not.
    Lead by my Lefty............... right down the trail, no brakes.
    Quote Originally Posted by frorider View Post
    Oh well, I'll keep my GD and just go with it. 550 grams with shim and remote and it always works. It ain't pretty, but I don't look at my bike while riding.
    Reputation: hugerooster's Avatar
    Wasn't the post supposed to be available April 1? I haven't seen it pop up for sale on my initial Google searches...anyone order one yet?
    Quote Originally Posted by hugerooster View Post
    from the internet:
    "First shipments of the dropper will begin by April 12th. That’s 11 days later than I wanted but an internal part that is in the radial play mechanism is not quite right and is being re-made."
  67. #67
    April 12 is the date I got from Jenson as well. Anyone have a good place to get an initial run?
  68. #68
    I looked all over online earlier and it seems that most pre-orders (i.e. Chain Reaction et al) are for May/June.
  69. #69
    Quote Originally Posted by ziscwg View Post
    I don't think a new seatpost will change the fact that my descending skills are barely decent, if that.
    And as with all first-run products, it's Caveat Emptor here. The news of the release date being pushed back by close to 2 weeks is not exactly confidence-inspiring to me, even though all of my bikes sport Thomson posts. Their standard post is absolutely perfecto, IMO.
  70. #70
    Sep 2012
    Quote Originally Posted by Ray Raton View Post
    Have you gotten the chance to try out a dropper post? It's truly inspiring... With Thomson's track record for quality a delay doesn't mean something back.. it means it wasn't perfect yet..
    Time will tell of course
  71. #71
    have you tried descending with your seat dropped 3-5"?
    in this sport a 2 week delay is much better than a lot of products that have been hyped up for months or even years and something i wouldn't fret over, especially from a company with thomson's track record of quality.
  72. #72
    007
    007 is offline
    b a n n e d
    Reputation: 007's Avatar
    Jun 2005
    Can't wait to hear people's experience with these once they get some "real world" testing a la the fine folks here on MTBR, especially with speak of an internally routed version. If the post holds up to the hype they claim and is consistent with Thomson quality, this post will quickly set the benchmark.
  73. #73
  74. #74
    g3h6o3
    Reputation: PissedOffCil's Avatar
    Oct 2007
    Cool
    Check out my SportTracks plugins for some training aid software.
  75. #75
    I used to have one of the state-of-the-art "Hite Rite" springs that went with a standard seatpost QR. I wish I still had one. These days I don't do that much radical descending to justify 400 bucks and over another pound on the bike.
    And it's always best, in my experience, to wait for Gen 2 of any given product. Even a Thomson. Time really DOES tell.
  76. #76
    Sep 2012
    It's quite obvious you have never got to use a dropper post. It's an amazing idea/product. It will change the way you ride. You will love it.
    Try one out and you will have to get one. It is one of those products you try and a light bulb illuminates.. Like the first time you land a huge drop and you now know how.. or the first 500hp vehicle you drive.. that amazing..
  77. #77
    Self Appointed Judge&Jury
    Oct 2000
    Quote Originally Posted by erikrc10 View Post
    products.
    Same here I love Thomson products and if history repeats itself this dropper should be top notch. I just have to wait for my first generation 5 year old Crank Brothers Joplin to fail. Then I will get one of these if the reviews are good.
  78. #78
    sapienti sat est
    Has anyone got this thing yet?
  79. #79
    Ninja Master Powers
    Reputation: DWill's Avatar
    Aug 2010
    I've been watching BTI every day since the first and the LBS I frequent has it stock watch at QBP and BTI. So far I still don't have one. I'm heading to Sea Otter Thursday hope to find out more there.
    I'm just guessing but something tells me they'll magically appear in stock either during or right after Sea Otter.
  80. #80
    Ninja Master Powers
    Aug 2010
    Still waiting..... off to Sea Otter tomorrow.
    I'm still guessing it will magically appear in distribution either during or just after Sea Otter....
  81. #81
    Sep 2012
    Waiting here too.
  82. #82
    Jun 2012
  83. #83
    Sep 2012
    $469?? F that S!!
    http://www.bikebling.com/Thomson-Dro...dropper-sp.htm
    Much better pricing.
  84. #84
    007
    007 is offline
    b a n n e d
    Jun 2005
    Will definitely be waiting for the Stealth version . . . . and I'm sure (hoping) there's at least talk of a "Masterpiece" version as well.
    Thomson could KILL it with this thing if it works . . . a stealth masterpiece that is reliable would quickly become the industry leader IMO.
  85. #85
    Banned
    Re: Thomson Elite Dropper Post Thread
    Got a KS LEV today. I started thinking about getting a Thomson this morning and decided I would wait until I have a frame that accepts a stealth cable and until Thomson makes a stealth version. Then I started thinking, well, I should just wait for the bluetooth model. And so I got the KS LEV today. I hope I don't end up eating my words on this, but until it is reliable bluetooth tech... See ya next time remote control seatpost market. LEV is good for now.
    Sent from my Desire HD using Tapatalk 2
  86. #86
    Reputation: mazspeed's Avatar
    Wow $475 for a seat post. I guess you can buy it or not buy it type of thing. I just bought a Lev as well and not impressed with the setup. Nice action for sure, but the parts inside the lev sign on the post itself seems very breakable. You can very easily strip that hook and if you do, you're screwed. Also you need the outer cap not to fall out. If that does on a ride, you're in trouble as well.
  87. #87
    Reputation: cman8's Avatar
    Quote Originally Posted by mazspeed View Post
    Not really. the hook if it does fail and break just get a new one from KS, they are very responsive and ship stuff out quick (at least it was in my case) and as for the cap, its not exactly catastrophic if it does fall out, I mean a simple piece of tape can cover the hole.
  88. #88
    Quote Originally Posted by cman8 View Post
    That's cool, glad they ship quickly. I did notice that if the cap is off, the hook refuses to latch into the little bar in there. I almost want to glue it in but realize that's not a great idea. Thanks.
  89. #89
    Really? Thats weird, mine works with the cap on or off. I say this because when I got a second LEV for my nomad, The cap came without the gasket so while I was testing it made sure everything was working right I had it without the cover and it was working fine.
  90. #90
    It's quite possible I screwed it up. You have to cut the line just at the level of the screw which I did, but maybe mine is a little more temperamental. Like it's owner.
  91. #91
    Bicyclochondriac.
    Quote Originally Posted by jkidd_39 View Post
    $469?? F that S!!
    Thomson Dropper Seatpost from BikeBling.com
    Bike Bling? No thanks.
  92. #92
    Sep 2012
    Bike bling bad?? Please inform me. I'm new!!
  93. #93
    Why? They have been great for the high dollar items I have gotten from them. I got my Lev way cheaper from them than anyone else, and the transaction was perfect.
  94. #94
    Bicyclochondriac.
    I've found them to be pretty flaky in the past. Placed an order and did not find out until a week later when I called to check up that they were out of stock. They sorted it out, but it was irritating. One time I called and thought I reached some random stoner's apartment.
    There were a few threads a few years back about them. Not crooked, just occasionally incompetent.That was a few years back, maybe they have gotten better.
    Another time a ordered something that seemed too good to be true (price-wise). Took a stupid long time to ship, but the deal was for real.
  95. #95
    In the past I had a hang up or two with them, but I find BikeBling great to deal with now. I always call and verify with Zach that everything I want is in stock then place my order.
  96. #96
    Jun 2012
    Did anyone else notice the June availability. Thompson trying to get a back log of orders in befor they start shipping these unicorns?
  97. #97
    Jun 2012
    Bikebling says its $389 available in may
  98. #98
    Quote Originally Posted by Motomarco View Post
    june is for the stealth version.
    earlier today:
    "All looks set for the droppers to start heading our way on Friday. We should have them Monday or Tuesday, I will know more once they are in the UPS system.
    That means we will fully inspect and then ship the first units the next day.
    We are late, but scrambling to get this out as the weather warms up."
    "Stealth is planned for June and remains on time."
  99. #99
    007
    007 is offline
    b a n n e d
    Jun 2005
    Unicorn post.
  100. #100
    Ninja Master Powers
    Aug 2010
    earlier today:
    Where did this come from?
Members who have read this thread: 55
