Page 6 of 10 FirstFirst ... 2345678910 LastLast
Results 251 to 300 of 454
  1. #251
    Dab-O-Matic
    Reputation: Simplemind's Avatar
    Are you sure you have plenty of cable in the routing, where there's no tugging at full extension?
  2. #252
    Let the good times roll.
    Reputation: miniwisejosh's Avatar
    Quote Originally Posted by fizzywater View Post
    I am now experiencing exactly the same problem. Happens about 1-3 time per ride and only while climbing steep stuff where I am scooted more forward on the saddle. Does anybody know why this happens and what the resolution is?
    I've had that a few times. It's caused by something keeping the release lever (I'm referring the the cable-actuated lever under the saddle, not the remote lever on the handlebars) from fully extending to the lock position quickly enough. Usually this means the cable or housing needs replacement or at least some lube. In one case, the lever on my post was sticking even with the cable disconnected. I dripped some triflow around the lever's pivot and that seemed to free things up again.
  3. #253
    Dab-O-Matic
    Anyone have experience with the locking SIP grips that come with the some of the Blacklite kits?
  4. #254
    Quote Originally Posted by Simplemind View Post
    Too small for me. I have a large hand and wanted them to work, but had to put my ODI Rogue's back on.
    They were a perfect fit for my 10 year old's hands.
    Mojo 3- For Sale
    Carver 420 TI
  5. #255
    Reputation: mestapho's Avatar
    Well, broke a piece off of the collet again.
    It'll be going in for warranty repair for the second time for the same issue.
    Think I'm switching to a Gravity Dropper now.
  6. #256
    Dab-O-Matic
    Quote Originally Posted by mestapho View Post
    I'm curious, what were you doing when the collet broke, ie, raising/lowering, and did you know immediately? Also, do you weight the seat when raising, or let it hit the stops on it's own? Did you disassemble to see the damage?
  7. #257
    Nov 2007
    Also, do you remember if it was the same piece/same general area that broke before?
  8. #258
    I didn't know immediately that it had broken again.
    I keep my butt on the seat as it travels up for the most part.
    I disassembled it to check why it wasn't working correctly again.
    The symptoms are the seat not extending without needing a tug, especially from the cruiser position to full up.
  9. #259
    Quote Originally Posted by pwu_1 View Post
    It was on the opposite side of the collet this time.
    The first time was the piece directly in the front.
    This time it is the piece directly in the back.
  10. #260
    Dab-O-Matic
    Good info, thanks!
    I see how the collet works, from the photo's on the PB review, and it looks like you may be referring to one of the fingers of the collet breaking off...correct? I can see why this "mechanical stop" takes a beating, which is why I think it's important to ease it up and down. May be the Achilles heal of the mechanical design vs hydraulic. I think I still prefer mechanical for it's simplicity.
  11. #261
    Good info, thanks!
    Yep. It's the little finger things that have broken off. I'll take a picture before it goes back to Spec.
  12. #262
    Dec 2010
    I like my 2013 FSR Elite but I think the single bolt seat clamp on he Blacklite is a design flaw. I understand that ease of adjusting the saddle tilt is a selling point but a two-bolt system isn't that difficult. How often do you adjust your seat position fore-and-aft and tiltwise anyway? Unless there's some extreme, North Shore Double Diamond technique of which I am not aware, we generally adjust our saddles once and then forget about them.
    No matter how tightly I torqued the bolt, the saddle would periodically tilt after hitting a bump or a hard landing. Off the bike, loosen, readjust, and torque well past 122 Nm. Four or five times a ride...not acceptable on a $4000 bike.
    The problem is the design and the installation method. The posts uses a clamp to squeeze wedges into a smooth cylinder. The instructions say to grease the wedges but I didn't get a good clamping action until I cleaned the grease off with alcohol, sprayed all the contact points with Carbogrip, and put so much torque on the clamping bolt that I fear something is going to fail catastrophically.
    I was contemplating drilling and tapping two setscrews through the cylinder and wedges but abandoned the idea; probably would have lead to a stress fracture through the holes.
    It works fine now but I don't trust it and am carrying the appropriate allen key in my pocket just in case. Certainly will not go on an epic ride with it.
    By comparison I have a KS dropper post on my Enduro, also a single bolt design (which will be switched onto the FSR as soon as I get the time) that I essentially adjusted once two years ago and have never given it a thought. The difference is that the clamp sits on serrated base which gives that extra hold. The KS, by the way, has worked flawlessly and I just clean it and put grease under the collar every six months or so.
    I'm a heavier rider...around 230 pounds but that's why I got a big bike like the FSR.
    On another note, the lever is awful. Very un-ergonomic and to put it in the ideal position for my thumb would cause interference with the shifter. I know this post is getting rave reviews but while I really like Specialized as a brand and no doubt the post is going to set the standard for reliability I think they could have done better.
  13. #263
    Quote Originally Posted by Ailuropoda View Post
    The tilting seat problem is easily solved with carbon fiber paste on the red cone thingy parts. Don't know if that is the same as the Carbogrip. I had the tilty seat issue until I did this and not a problem since. I'm also a bigger rider was in the 230 range when I first got the post. My issue is the collet breaking. Mine is about to go back to Spec for the second time for the same issue. At your size I can almost guarantee that you will break the collet in the first 6 mos of riding.
  14. #264
    Reputation: dorkboy's Avatar
    I want to get my wife a blacklite for Xmas. She has a 2010 specialized myna fsr small. The max her seat post can go into her frame is 5.250". Does anybody think that the 100 mm will work for her? Or will I have to wait until the 75mm gets back into stock?
    Thank.
  15. #265
    Nov 2007
    Quote Originally Posted by dorkboy View Post
    Thank.
    Depends on how much seatpost is exposed right now. Go measure from the seat collar to the seat rail and see what the measurement is. If there is at least 9.75 then the 100mm will work.
    The way I figured this is as follows:
    The lower portion of the 100mm post from where the post flares out for the seal to the end of the post is 8.5" The top portion from the seal to the seat rail is 6.5"
    Since the frame can only insert 5.25" you take 8.5 - 5.25 = 3.25. Then take 6.5+ 3.25(for the additional exposed lower portion of the post) = 9.75"
    Hope that makes sense.
  16. #266
    Yeah, I measured and my wife rides with her saddle up at 5.750" going uphill, then drops it down 2 - 3 inches for downhill.
    Maybe the 75mm blacklite would be better. But they aren't available, so it might be a delayed xmas gift.
    Thanks for your help!
    Scott.
  17. #267
    Nov 2007
    Scott.
    hm, with 5.75" showing and only able to insert the seatpost 5.25" into the seat tube I'm not even sure the 75mm dropper post would work.
  18. #268
    The broken collet. 2nd time.
  19. #269
    Just found mine broken too. 3rd one for me. Looks like this is a recurring issue.
  20. #270
    Reputation: BaeckerX1's Avatar
    Oct 2007
    Just wanted to give an update to say I've been using the Blacklite for quite some time now with no issues. Many of my local riding buddies are as well and have reported no problems. Once you apply the carbon paste to the saddle clamp to prevent rotating the post is great. Reverb has failed twice so I'm done with that thing.
    I finally decided to get rid of that f@#$%ing curved noodle at the bar clamp and it's resolved all my issues with the lever being too hard to push. I determined it was where most of the resistance was in the cable sliding smoothly. It's not quite as clean looking, but the loop out front really isn't that big and the post is MUCH more useable now. I can drop it quickly whenever I need to now. I love it, and unlike the Reverb it has been reliable.
    Food for thought for those considering the 100 vs the 125mm. I couldn't use more than the 100 for my frame so that's what I've been using. I've found I don't miss the extra drop that the longer Reverb had. 100mm at full drop is more than enough for the steepest, most technical trails. I never really thought about it before, but I think going an inch shorter will also improve longterm durability because ultimately you are looking at less stress on all the components. It will be a shorter lever arm so there will be less torsional forces at the saddle on the thinner telescoping part.
    Gotta get up to get down.
    LMB
  21. #271
    Feb 2006
    Quote Originally Posted by BaeckerX1 View Post
    interesting... And I just lubed my noodle the other day!
  22. #272
    Oct 2007
    Quote Originally Posted by bad andy View Post
    Keep your personal non-bike-related pastimes off of MTBR Andy. Nobody needs to hear about that.
    LMB
  23. #273
    Nov 2007
    I wrote about the same issue with the noodle a while back.
    Removing the noodle was like night and day difference for me. When I got the dropper for my other bike I didn't even bother with the noodle.
  24. #274
    Oct 2007
    Glad to hear it wasn't just me. I didn't have time to read through the entire thread, but it's good others are aware of the issue.
    LMB
  25. #275
    Reputation: trojans1993's Avatar
    I found swapping the stock cable for a Teflon cable made the lever action considerably more smooth as well. Almost 2 years on BL post now with no issues at all - knock, knock, knock.
  26. #276
    Just did a tune up on mine. Thanks for posting the "how to" video, can't remember who it was.
    Still have that noodle but with a teflon cable as well. Better than brand new. Thumb lever feels more like a shifter now.
    Very smooth and very easy to do if you follow step by step video.
    Psyched now to ride...
  27. #277
    I have had this post for 3 months now, and it's my first dropper. I weigh 225 and am 6'2. I got the 100 mm version, and have had no slipping or tilting, zero problems at all, and I use the crap out of it. So far so good...
  28. #278
    Keep on Rockin...
    Reputation: Miker J's Avatar
    Nov 2003
    Tilting clamp....
    Clean it, grease the works, tighten very well.
    I had slipperage until I started to grease it. I have two posts going strong with no slips for a year.
    Admittedly, if I sit on the seat and shift my weight, then try to re- tighten the clamp, I can usually get another eighth turn. Frugality to add that in, and that is important.
  29. #279
    Stalker Mode Enabled
    Dec 2010
    Does anyone know where to get a replacement collet for Blacklite?
  30. #280
    Specialized Command Post Blacklite
    Quote Originally Posted by HZKI View Post
    Had to send mine to Spec. twice to have the collet repaired. The second time the work order said they put the 1nd generation collet on. Hopefully that fixes this issue.
  31. #281
    Oct 2007
    Very confusing wording. Did you mean 1st or 2nd?
    LMB
  32. #282
    Oops. 2nd warranty service put on the 2nd generation collet.
    Stupid fat thumbs.
  33. #283
    Guys, care to advise what are the options to change the cables?
  34. #284
    Mar 2011
    I went with Jagwire ripcord. Just being vain and wanted it to match the rest of my housing. Works good but I did find out that their cable ends are a little bigger than what came with the post and are REALLY tight in the cable stop on the post. If I have my cable off in the future I'm going back to the stock cable end on the Jagwire housing if it will fit. It's tight enough that I need a pair of pliers to pull the end out of the stop. Nice setup otherwise.
  35. #285
    Mar 2013
    Just purchased the 125mm blacklite. Looked around at various options and seems this is a decent solution. They all seem to run into issues at some point so I opted to support the LBS and have access to help if needed. I installed it myself, worked like a champ.
    Rode it today for the first time, I set PR with strava all over the place but that's because I was excited. LOL
    Now I just need to remember to use it before I'm half way down or up the trail.
  36. #286
    Quote Originally Posted by brigcampbell View Post
    It becomes second nature just like shifting after a few rides - best investment I've ever made.
  37. #287
    Mar 2013
    Here is my setup, just mounted on the inside right on the left side. The XT brakes were a bit of an issue. Probably could have moved it over to the left more but I have bear paws.
    Attached Thumbnails Attached Thumbnails Specialized Command Post Blacklite-imag0439.jpg
  38. #288
    Those look like XT shifters. If they are you can the ISpec covers and have just one clamp, cleans up the bars nicely.
    Mojo 3- For Sale
    Carver 420 TI
  39. #289
    Jun 2013
    Quote Originally Posted by Miker J View Post
    Tilting clamp....
    yes you are right. theres a video on youtube where the guy tightens the bolt with a torque wrench. then you rock the seat front to back. then retorque. then do it again. he got about half a turn from initial setting, but now with the right torque.
    could be worth buying a small torque wrench if you are worried about overtightening.
    Specialized Command Post Blacklite: Set Up - YouTube
  40. #290
    Mountain Lion Bait
    Reputation: renderedtoast's Avatar
    Remote Lever
    Anyone buy a complete and swap out the grips? Did your bag of goodies come with a collar some something to allow the remote to clamp to the bars once the stock grips were removed? I didn't get anything like that, and of course, the clamp is too big for the bars. I'm gonna call the shop I got it from, and if that doesn't work, call Spesh directly and see if they can point me in the right direction.
  41. #291
    Nov 2007
    Quote Originally Posted by renderedtoast View Post
    nvm....see below
  42. #292
    I think the remote lever/clamp that replaces the clamp for the grip is only available as OEM when the post comes with the bike. The aftermarket retail package seatpost doesn't come with that clamp.
    I think you can order the other lever/clamp but not sure how much it costs. Post up if you find out how much it is to order.
    Not sure what you mean as far as ordering the complete? I ordered mine from the LBS and mine came with the clamp for use without the grips. The first one I bought was a take off from a bike and if I remember correctly it came with a sleeve for inside the clamp to make it fit bars.
    Mojo 3- For Sale
    Carver 420 TI
  43. #293
    Feb 2006
    Mine came on my stumpy and also included the sleeve/collar for use with non-spec-clamp grips.
  44. #294
    Mountain Lion Bait
    I bought a complete Stumpy. I didn't get a sleeve/collar. I did get two strange looking clamps with a screw on one end to clamp, and another screw on the other that looks like a set screw. I'm calling the shop I bought it from today to inquire about the collar. I was at another Spesh shop in Escondido on Sunday, and they all had blank stares when I asked them how the lever attaches to the bars with aftermarket grips.
  45. #295
    I wouldn't be surprised if the techs didn't know what it was for and threw it away. As I said my OEM take off had the collar that fit inside.
    Mojo 3- For Sale
    Carver 420 TI
  46. #296
    Hi
    I've my my Blacklite for about a year now. Unfortunately it's started to 'drop' from the highest position of it's own accord - this always happens when I'm attacking a steep climb.
    It does drop when pedaling on the flat too but just not as often.
    I thought the cable may be sticking so I disconnected from the post and discovered it still occurs.
    I've dismantled the post and inspected the internals hoping to see an issue but it's in excellent condition - nothing broken or worn.
    The post has been perfect until now.
    Any ideas?
    Cheers.
  47. #297
    Warranty issue. Send it back to be fixed. Happened twice to me. Now riding a Fox DOSS
  48. #298
    Reputation: CrozCountry's Avatar
    Mar 2011
    I had the first and now second generation in 100mm. Both work great.
    The issues with version two are hard lever action and no good mounting position with Shimano shifter/brakes. Lever was so hard to pull that I started looking around for other options. It seems that version one had much better lever design with the exception of proprietary cable (why???)
    The original noodle was impossible to use with Shimano. I replaced it with a noodle that I made from a V brake noodle. Little bit of cutting and sanding. It has a larger radius, so its not as tight. The mod is simple, just cut the bulb at the end of the noodle to make it a single diameter tube. Sand and round smooth and clean any cutting leftovers on the outside and inside of the tube.
    Straighter tube means less friction. Now I get two things:
    • Fits with Shimano
    • Lever action is acceptable. Still hard and nowhere near Reverb or Crank Brothers. But it's usable.
    I highly recommend this mod.
  49. #299
    The manual says the plunger height needs resetting.
    Anyone familiar with this procedure?
  50. #300
    Quote Originally Posted by BorisD View Post
    If it's not the tension in the cable, it's the post itself, I can guarantee it.
    Take it to a Spec. dealer and have it warrantied.
