Page 16 of 18 FirstFirst ... 6 12 13 14 15 16 17 18 LastLast
Results 376 to 400 of 436
  1. #376
    Reputation: Simplemind's Avatar
    Quote Originally Posted by TwoTone View Post
    Maybe you should ride the way you want to and the rest of us will ride the way we should.
    But thanks for trying to tell me how to ride like you.
    TwoTone, I think Matt came off a bit strong, however I think he makes a good point, and that is why have a middle position. I use the middle position a lot because my usual terrain is quite technical and up-down up-down and I don't have time to be constantly changing seat positions. However when I ride Colo there are long assents and descents, giving to using the top and bottom seat position much more.
    The middle position allows me to still get behind and also gives a platform for climbs, but it IS a compromise, in that it not ideal in either (descend/ascend) but that's the way it is.
  2. #377
    Re: Specialized Command Post Blacklite
    Might as well post here.
    Anyone have a 75mm that wants to trade for 100mm one? The 100 is too long for my new frame.
    I have a 75mm giant dropper post that i would trade. 75mm was to short for me
    Sent from my SM-N900T using Tapatalk
  3. #378
    Quote Originally Posted by retrofred View Post
    No thanks, Blacklite for Blacklite
    15 Canfield Riot on order
    ?? Carver 420 TI
    13 Lenz Lunchbox punkass
  4. #379
    Elitest thrill junkie
    Reputation: Jayem's Avatar
    Quote Originally Posted by mattsavage View Post
    I think you're missing the point of dropper posts... If the post is dropped, that means you're descending or navigating technical terrain and should not be seated, ever.
    Have you ever done any downhill riding?
  5. #380
    Oh no worries. Wasn't sure which you had cause of all the people started talking about all different brands.
  6. #381
    Jul 2013
    i there any manual on the service IR version of coommand post?
    standart can be fount on the youtube
    but ir, im not shure how to dissasemle it
  7. #382
    Well just had a broken collet. Even though I'm under warrantee still (11 months) Spec will NOT replace it.
    Specialize SUCKS... they will not cover a broken collet under warrantee saying it's a "wear and tear item" (like those holes don't severely weakens the post!) nor will they sell the shop the $18 replacement part. You have to send it in and pay >$90 for service. LAME on a $300 item. never buy spec again. Might have to go back to Gravity Dropper (if only the cable routing was better) who's CS was amazing in replacing a broken shaft no questions asked for me.
  8. #383
    Quote Originally Posted by adumesny View Post
    That sucks!
    Maybe I should sell mine before it craters.
  9. #384
    Reputation: Rakuman's Avatar
    That's and the fact so many Non upgradable parts + their Business practices is why Specialized will never get another dime from me, Other than that I love My Stumpy LOL
    I always type in bold cuz I'm blind as a bat
    For the Rich there is therapy!!!! for the rest of us we have Mountain Biking
  10. #385
    Quote Originally Posted by Rakuman View Post
    Good friend has a Spec (I ride a Mojo HD with Ibis amazing CS) which he loves but not when it comes times to replace anything on it. Spec doesn't provide any parts it seems (only complete repair) and even the bolts are non standard threads pitch!... he HATES Spec now.
    Reading this long thread looks like some people have this break repeatedly... why wouldn't it after all - looks like a weak design and leaves a bad taste in my mouth as they expect us to spend $90 every couple years with 'wear and tear' BS... It's a design flaw.
  11. #386
    Quote Originally Posted by cka3o4nuk View Post
    hi people!
    is it safe to use 30.9 seatpost with shim to 31.6
    Yes but if going in a carbon frame make sure it won't void warranty. That's why I needed to just get the next size up. BTW - someone saw my previous post and got in touch, got my post,its all good!
  12. #387
    May 2012
    Can I insert cable housing into remote lever?
    Quote Originally Posted by pwu_1 View Post
    I wrote about the same issue with the noodle a while back.
    Removing the noodle was like night and day difference for me. When I got the dropper for my other bike I didn't even bother with the noodle.
    I took out my noodle and put the cable housing straight into the remote lever. I filed the end of my cable housing. This won't damage my lever, right? Thanks Bill
  13. #388
    Reputation: CrozCountry's Avatar
    Mar 2011
    I just replace my blacklite with the latest version with the new head clamp, went from 100 to 125. The lever action is a huge improvement. Much lighter and does not disrupt riding. The new head is an improvement, and angle range was not an issue as it was on the enduro that I tested. The new seat clamp is not acting up and does not need crazy torque and wiggling to stay in place.
    But the problem now is that my frame has too long seatpost, and 125 middle position is too high, even when the post is slammed all the way in. I have no idea how this happens since with the 100 I had more than an inch exposed post above the seat tube.
  14. #389
    So my 2012 Command Post Blacklite is no longer locking in the lowest position. It will lock in the middle position. Is this an easy fix?
  15. #390
    Armature speller
    Sep 2004
    Quote Originally Posted by toyotatacomaTRD View Post
    Sounds like something is jammed in the lower groove.
    Disassembly time...
  16. #391
    If it's locking at the mid and top position then it doesn't sound like a broken Colette (which many of us had) but something is maybe limiting the down travel - make sure the shaft lock is tight all the way and not longer which may prevent full travel down.
  17. #392
    Feb 2006
    My experience as exactly that, actually. Broken collet with one of the broken pieces at the bottom inside preventing full down travel, so the post's shaft wouldn't quite reach the lowest lock point. The upper position worked ok as my collet was still intact enough to work. IT was just one broken piece. Sent to Spec to fix.
  18. #393
    I ended up fixing the post from not locking into the bottom position by loosening the cable. The post had been on for 2+ years, I'd never adjusted the cable in that time. I was really surprised it fixed it. Thanks to all who offered suggestions.
  19. #394
    good it was a simple fix.
    Update on my broken colette - took almost 2 months (always delayed 'another 3 weeks', etc...) to get the spare part (shop quoted me $18, which must have been their price as I was charged $36) as apparently Spec keeps them for their warrantee department !! (didn't want to spend ~$75-90 sending it in and have it break again). Taking it off was a PAIN as they use red lockit and the grove is very small. Neighbor mechanic didn't want to give up, and together with a torch to melt the lockit and eventually a regular plier (didn't care about damaging the colette as a flat key didn't have enough grip) we got it off... super hard with 2 people!
    Tired of waiting so long, I bought a used blacklit cheap which was almost impossible to open ! (not sure why they didn't keep the bolt pattern of the original and have it rounded now) to make sure the colette wasn't broken (didn't want to double my problem). Now I have a spare one for my DH bike in case my main one acts (the inside is the same between the 2 sizes 30.9 and 31.6 I now have).
    Been told to NOT let it slam on the way up as that is what breaks the colette. My cable is intentionally short so it slows it down near the end (adjust your air pressure as well) so it just barely makes it to the top, else use your legs/butt to slow it down.
    Hopefully it will last longer this time... The blacklight is definitely an improvement (nicer remote with regular cable, easy disconnect at the seat, etc...
  20. #395
    I wanted to share my experience with the broken collet issue.
    First though, I should mention that I've been using this post for 2.5 years with no issues at all. I took it apart twice during that time for cleaning/maintenance (done by me, not a shop).
    A few weeks ago I experienced the same issue described by a few others here where the post would not lock into the lowest position. It would still lock in the top and middle positions, however. I pulled it apart to take a look and this is what I found:
    I took the Blacklite to the local Specialized dealer where I bought it. They had not seen this issue before, but they called Specialized and confirmed they could order the part in and repair in-house. The quote was $25 for the part, and they said it would arrive in 4-5 days. The part got there on time, but... the shop didn't realize they needed a special tool to remove/install the collet. They called me and apologized for the oversight, and said they would order the tool and it should be there in 3-4 days. They called 4 days later saying my post was fixed and ready to go.
    Overall, I was very happy with the process. I expected the shop to charge a little for labor, but the total was only $25 + tax. Not bad! And total turn around time was less than 10 days.
    One more thing, since I already had the post off the bike, I decided to convert my old SLX front shifter into the dropper remote lever (I run a 1x10 drivetrain). I found a few threads on here detailing the process. I haven't taken it out on a proper ride yet, but around the neighborhood it felt great! Much better than the Spec. remote. Really looking forward to this upgrade.
  21. #396
    Quote Originally Posted by lunchwagon View Post
    You are very lucky and have a good local Spec shop, because I had to wait 7 weeks to get the part (after repeated calls, Spec was out but eventually used their repair department supply, I had 2 shops try to get it!) and was originally quote $18 (ended up being cost so $36+tax) or $80+ to send in for service. It was a real PITA to replace it as they use red lockit (need blow torch, at least on the original model) and you have a very small grove to unscrew it. Very lucky your shop didn't charge you labor either as I almost gave up after couple hours trying to get it off with 2 people.
  22. #397
    I agree. I've been following this thread and was aware of your experience before my collet broke. I was not hopeful and didn't expect it to go so well. But when it did, I thought I should share my story so folks know it's worth giving it a go with their LBS. I'm not a Specialized fanboy (ride a Santa Cruz currently) and rarely purchase from this shop, so it's not like they were doing a favor for a loyal customer. The post was purchased there originally though, as they were the only place locally with stock.
  23. #398
    Sep 2014
    Hi to all. I'm new in the forum and I'm writing here because I'd like to have from you a help... I've just received m blacklite seat post from the assistance but they forget to put in the bag some component : one of these is the one that fit with the cable and you match with the trigger. is there a possibility to buy it somewhere? Anybody know the exact name of that particular? I know I've been kind of confusing, I'm sorry for that (and for my English too...)
  24. #399
    Armature speller
    Sep 2004
    I'm yet to take mine on a "proper" off road ride but just short rides around the streets makes me think this out the best way to do it too. A much more natural feel.
  25. #400
    Oct 2014
    Hi,
    My son has a command post on a recently purchased Stumpy expert,
    the dropper works in all three positions fine, then randomly drops a small amount(maybe an inch or two) from its fully extended position when riding. press the lever and it pops up again.
    on a ride it can happen quite a few times, ride for a mile or so no problems, then it goes again.
    the couple of times he's rode it its been near 0-+3c.
    Any advise please?
    thanks in advance.
Can't find it? Just search our site!
