Page 55 of 56 FirstFirst ... 545515253545556 LastLast
Results 2,701 to 2,750 of 2768
  1. #2701
    Reputation: foresterLV's Avatar
    Dec 2016
    Quote Originally Posted by BPH View Post
    Hey. Hoping for a little advice. I have read the whole thread and nothing matches my problem!
    My standard reverb has had very little use, is 6 month old and performs perfectly, EXCEPT....
    ...when the post is dropped for the first time, it won't drop smoothly. It's almost like it's stuck. It needs a small bump/wiggle to help it drop. Once that's done, it drops fine, and extends fine, then drops again absolutely fine, until it's been extended fully for about half an hour, and the issue repeats itself.
    Any ideas? It's only a niggling small problem, but certainly one that wasn't there at the beginning of its time!
    What happens if you adjust remote to a slowest setting? If its getting worse bleeding of the cable should help.
    Sent from my SM-G900F
  2. #2702
    Reputation: Lone Rager's Avatar
    Dec 2013
    ^^^Yes. It's also possible to over-tighten the post clamp so it restricts movement of the post. Check the clamp torque. I believe the spec is 6.7 Nm (60 in-lb) max.
    Do the math.
  3. #2703
    Dec 2016
    My reverb is much better after partial cleanup/regrease (was not able to remove lower cup, so no way to get into upper dust cover, need vice jaws thing for 9.5mm tube). No single "got stuck" situation on today ride.
    I guess I will get vice jaws and will do dropper cleanup/regrease from time to time as shown in the video below. Then it will be time to do "service kit" thing.
    https://youtu.be/NfFRlpCpU3s
  4. #2704
    007
    007 is offline
    b a n n e d
    Reputation: 007's Avatar
    Jun 2005
    Quote Originally Posted by Lone Rager View Post
    That might be spec, but on my bike, anything over 3nm and it binds.
  5. #2705
    Dec 2013
    ^^^ Yeah. It can be clamp dependent. Not saying this is your issues, but if a slot in the seatpost lines up with the slot in the clamp, it can really dig into the post. Arranging them so they don't line up can help. This is usually the default arrangement for use with carbon seatpost. Sometime they're 180 degrees apart but in some cases the seat tube may have two slots (Trek, for one) and the clamp slot is equidistant between the two.
    Do the math.
  6. #2706
    it might be that you have an issue with the brass inserts since you wiggle your post before being able to put the post down. better make an appointment with a service or you can do it on your own with the right tools and instruction from sram via youtube.
  7. #2707
    Dec 2004
    Question about the process to rebuild the Reverb stealth:
    Pulled it apart last night for the first time to reset the IFP, oil and all that because I was sagging. I had to make my own IFP oil height gauge using one of my remote bleed syringes and a piece of aquarium air hosing. With my Reverb, my height it supposed to be 186.5mm. Fine no problem. But what I found is I couldn't get the tubing far down enough in the shaft to get the full 186.5. I was off by 4 or 5mm. I double checked and this is because the diameter of the hosing is too wide to fit through the blue 'thing' that presses into the IFP tube. I'll have to source a slimmer tube. I reassembled anyway just because I was at my wit's end. At the end of the day, the post is solid and seems to work fine....not trail tested yet.
    So how critical is that oil height? SRAM makes it look like it has to be on the money exactly.
    2000 Giant DH Team
    2003 Balfa BB7
    2004 Nicolai Nuclean ST
    *break*
    2011 Intense M9
    2014 Intense C29
    2015 Intense 951evo
  8. #2708
    May 2014
    Quote Originally Posted by Christopher Robin View Post
    Ive got a proper oil height gauge and it only ever picks up small dregs of oil. The first few times I actually poured some oil in so the gauge had something to suck up but found it wasn't necessary. I don't think it needs to be that accurate. The best test is a working post.
  9. #2709
    Dec 2004
    Quote Originally Posted by niva1989 View Post
    Perfect good to know. I didn't get a chance to try it out on the trail but the post seems to working fine. Thanks.
    2000 Giant DH Team
    2003 Balfa BB7
    *break*
    2011 Intense M9
    2014 Intense C29
    2015 Intense 951evo
  10. #2710
    Mar 2012
    Did you find a solution?
    I have the same issue, ill check the post collar to see if that helps.
    new , 4 months old reverb 170mm
  11. #2711
    Will there be issues when a bike with a Reverb seatpost is stored upside down (hanging)? Thanks!
  12. #2712
    May 2014
    My bike spends a fair bit of time upside down but resting on the seat. It's good for your fork bushings and seals and I've never had it cause issue with the reverb.
  13. #2713
    Good to hear, thank you!
  14. #2714
    Reputation: TeamRWB's Avatar
    Feb 2014
    duplicate
    "I cycle so I don't choke People"
    Big Wheel Racing Europe
    It's Our Turn!
    Team RWB
    http://www.teamrwb.org
  15. #2715
    Feb 2014
    So reading through here, it seems the sag is present even in the *Updated* model. I have the opportunity to get a good deal on one, cheaper than I can get any of the other External offerings out. Should I hold out, and Get a Fox or Thomson or will this be a reliable option. I noticed mention of using a RH remote vs a LH, and I may of missed an explanation of why skimming through here, so what is the benefit from this? I also read about replacing the u-cup seal with an o-ring, where can the o-ring needed be purchased from? And did anyone replace the Teflon bushing with a polymer made version of it, besides the guy in this blog, The Seatpost Whisperer | Blue Liquid Labs
    Granted I wont do any of the Maint related aspects unless its needed or warranty expired. Just educating myself.
    It's Our Turn!
    Team RWB
  16. #2716
    Dec 2004
    Quote Originally Posted by TeamRWB View Post
    Don't know anything about your seal question (which I'll look into as well since I'm always looking for things to make the Reverb more reliable), but using the RH remote vs the LH is personal preference: Using the RH remote on the left side places the plunger below the handlebar so it's easier to access with your thumb. This is also providing you don't have a front derailleur.
    Edit. After reading that article, I'd also like to know what size that seal is.
  17. #2717
    Nov 2013
    I am selling my bike and thinking I should take the reverb with me and put in the giant one I am buying from the 2nd hand giant bike.
    Good idea?
    giant - https://www.giant-bicycles.com/us/trance-27dot5-1-2014
    nukeproof - Help me identify what is on my bike and price it for sale
    I like the reverb and it looks like a better seatdropper.
    Will they swap out?
  18. #2718
    Reputation: RS VR6's Avatar
    Hello?
  19. #2719
    Reputation: spyghost's Avatar
    Oct 2012
    Quote Originally Posted by RS VR6 View Post
    Hello?
    you beat me to it
    in any case, i can't see it in sram site nor google results
    Canfield Yelli Screamy
  20. #2720
    Could make an appearance at Sea Otter. That's where SRAM typically shows off new stuff.
  21. #2721
    Feb 2014
    Please have an external option!
    Sent from the Beer Cloud
    It's Our Turn!
    Team RWB
  22. #2722
    Oct 2012
    b1 still has external just up to 125 only
  23. #2723
    Sep 2015
    I think that the O-ring is the same size as in externally routed reverb (3.5x9mm see RockShox Reverb Thread post #2211 ).
    I just rebuilt one stealth and replaced the U-cup with O-ring.
    The stealth U-cup was 10x15x4 and replacing O-ring 9.12x3.53 (couldn't source the 3.5x9).
    Unfortunately I don't currently have a frame with stealth routing (planning on drilling my 2011 specialized enduro), but compressing by hand, it appears to be working just fine. More testing when I get it into frame.
    I don't see why it wouldn't work with externally routed as the current remotes in stealth and external are identical per revision (see rockshox spare parts manual 2017_rockshox_spc_rev_b.pdf , there are separate remotes for A1 and A2, but not for stealth/non-stealth)
    The above image is from Vital MTB and there is some more info on the comments.
    For example, the product page apparently exists, but is not allowed to access: https://www.sram.com/rockshox/products/reverb-1x-remote
    I am mainly waiting for the price, as with the current remote price I rather buy another DeHy kit to convert the post to wire controlled than expensive but different hydraulic.
    Maybe the new construction will prevent the wear and leaking of the piston. (current design has only plastic bushing and there is usually sideload when pressing the remote)
  24. #2724
    Reputation: Mithrandir's Avatar
    Hello?
    I want one!! The original actuator is the thing I dislike the most on the Reverbs.
  25. #2725
    Thread Terrorist
    Reputation: IndecentExposure's Avatar
    I have successfully fixed the sag! I tore the entire seatpost apart and rebuilt it. I did use new IFP's, but was careful to make sure the oil was at the proper level. Thanks for everyone on this thread for all the helpful suggestions. We'll see how long this lasts!
    A few notes:
    My original IFP was pretty far down the tube. enough where the zip tie's wouldn't work. I ended up using 2 old spokes to 'hook' the IFP and used pliers to pull the thing out. Worked well.
    It would help to have the specific vice clamps (10mm), but I used the yellow rubber ones and they worked 'okay'.
    Once again, thank you to SRAM for making great videos. I literally just followed along.
    IE
    Golden Bike Park Group
    Peak Cycles Gravity Team & Bikeparts.com
    Trestle Bike Park
  26. #2726
    DAC M5 Beast
    I'm switching from a left hand lever to a right hand lever mounted underneath on the left hand side. I've read I can do this without bleeding. Is that correct? Also, I'm assuming the new lever and cable will require trimming?
  27. #2727
    May 2014
    Quote Originally Posted by adcampo View Post
    I think you will def have to bleed it especially if you are trimming the hose as you might need to use a new barb. I always bleed as it takes 5-10mins at the most.
  28. #2728
    Feb 2010
    There is now barb in Reverb hose. You just screw the lever into the hose. If you are switching left hand lever to right hand lever on the left side just use the existing hose. If the new lever comes mounted to hose and filled with oil you might be able to avoid bleeding, but it's not sure.
  29. #2729
    Feb 2010
    Quote Originally Posted by T3mppu View Post
    Google has cached the German page of the new reverb. Not much information, just picture from different angle. It comes with Bleeding Edge technology. Interesting how it works with Shimano brakes.
    Price is important. e-thirteen new mechanical dropper post looks much better upgrade at the moment.
  30. #2730
    May 2014
    Quote Originally Posted by arnea View Post
    There is a barb in the lever. It unscrews from the lever. Rebuild kit comes with a new one too. Only way lever will come with a hose and full of oil is with a new post attached to the other end.
    I don't know why people try to avoid bleeding. It's very easy to do. Much easier than bleeding brakes. If you own a reverb chances are you will have to bleed it at some stage and the bleed kit is cheap.
  31. #2731
    Feb 2010
    Ok, I've never changed the barb, always unthreaded the hose from the barb and then threaded it back after I installed the hose in the frame. I got the Connectamajig version of the post and it is possible to remove the hose from post without loosing oil and needing the bleed. I don't remember how it was packaged - IIRC it was competely assembled and filled with oil.
    And I agree, bleeding is easy.
  32. #2732
    May 2014
    I think it should be fine if you cut the end of the hose a little and have a fresh hose end to screw into. A friend of mine did this and didn't have any leaks but some air did get in when he unscrewed the lever. He may have bumped the plunger though. I had to re bleed it for him once fitted to the bike.
  33. #2733
    Oct 2012
    the only thing that keeps me on reverb is the external cable. if e13 were to have external, i'd to for it.
  34. #2734
    Feb 2010
    I've unthreaded and threaded the lever for 8-9 times now without cutting the hose and never had any problem with leakage.
  35. #2735
    Feb 2010
    Quote Originally Posted by spyghost View Post
    Check out Features | Absenkbare Sattelstütze moveLOC | Vecnum GmbH - also mechanical, lightweight, with external cable.
  36. #2736
    Thread Terrorist
    q on vise blocks for air shaft...
    those who have rebuilt a reverb, did you use sram's brass vise block? i find the price too steep at around $45 on the average.
    compared to these which costs only at around $10-15. i find these more suitable 'price-wise' that is...
    which among the 3 alternatives above is safe for the air shaft of the reverb?
    yes i know that it has to do with the clamping force, but of course material choice also has to do with it... plastic (yellow), nylon (black), or aluminum (silver)
    I tried it with the Yellow rubber ones. They don't work so well.
    Trestle Bike Park
  37. #2737
    Oct 2012
    Quote Originally Posted by IndecentExposure View Post
    which one works well?
  38. #2738
    Nov 2007
    I've found that the Aluminium Vice Blocks works better than the plastic and rubber ones. I've serviced many posts and never had a drama.
  39. #2739
    May contain nuts
    Reputation: Haggis's Avatar
    Ditto
  40. #2740
    May 2014
    Don't mess about just buy the brass RS ones. They are the only type that grip properly and won't damage the shaft. It can also be used on other RS components like Pike/Lyrik damper and air shafts. If you damage a shaft it will cost you way more than $45. The RS shaft clamp Has much more surface area contact than those other ones you pictured. I also have good quality Park soft jaws and they don't hold the 10mm shaft with enough grip. $45 will seem very cheap when you get into trouble.
  41. #2741
    Oct 2012
  42. #2742
    Jun 2016
    Nice that'll be day one for me for sure. That button was just so awkward, $90 ain't cheap though.
  43. #2743
    I think it'll be 90 bucks well spent...I mean its a lever I'll be using all the time. I really didn't like the plunger on my Reverbs. I'm going to get one.
  44. #2744
    Reputation: piperpilot964's Avatar
    Dec 2014
    Bout time! Already have the Novyparts remote which is simple and tougher. Glad to see there is another option should i trash mine in a crash.
  45. #2745
    Has anyone tried ordering one? I went to my immediate LBS and said its not showing up on his vendor sites.
  46. #2746
    Reputation: gocat's Avatar
    Feb 2012
    Call Sram. They are easy to get a hold of.
  47. #2747
    Probably won't see them out for another month at least.
    Jason
    Disclaimer: www.paramountsports.net
  48. #2748
    Feb 2010
    How much Reverb fluid is required for rebuild?
  49. #2749
    Jan 2014
    I recently completed a rebuild of Reverb Stealth (A2), followed the directions to the letter from SRAM video.
    The post no longer sags, however, way more force is required to press it down, and the post is very slow to go up. This is the case for slow speed settings (on the remote), as well as fast speed setting.
    I verified PSI is at 250, and all lines and remote have been bled properly. What could be the issue? Did I miss something during the rebuild?
  50. #2750
    Feb 2012
    Quote Originally Posted by dreys View Post
    Over tightened seat post clamp?
Members who have read this thread: 428
