RockShox Reverb Thread
Printable View
  • 02-18-2017
    foresterLV
    Originally Posted by BPH View Post
    Hey. Hoping for a little advice. I have read the whole thread and nothing matches my problem!
    My standard reverb has had very little use, is 6 month old and performs perfectly, EXCEPT....
    ...when the post is dropped for the first time, it won't drop smoothly. It's almost like it's stuck. It needs a small bump/wiggle to help it drop. Once that's done, it drops fine, and extends fine, then drops again absolutely fine, until it's been extended fully for about half an hour, and the issue repeats itself.
    Any ideas? It's only a niggling small problem, but certainly one that wasn't there at the beginning of its time!
    What happens if you adjust remote to a slowest setting? If its getting worse bleeding of the cable should help.
    Sent from my SM-G900F
  • 02-18-2017
    Lone Rager
    ^^^Yes. It's also possible to over-tighten the post clamp so it restricts movement of the post. Check the clamp torque. I believe the spec is 6.7 Nm (60 in-lb) max.
  • 02-18-2017
    foresterLV
    My reverb is much better after partial cleanup/regrease (was not able to remove lower cup, so no way to get into upper dust cover, need vice jaws thing for 9.5mm tube). No single "got stuck" situation on today ride.
    I guess I will get vice jaws and will do dropper cleanup/regrease from time to time as shown in the video below. Then it will be time to do "service kit" thing.
    https://youtu.be/NfFRlpCpU3s
  • 02-18-2017
    007
    That might be spec, but on my bike, anything over 3nm and it binds.
  • 02-18-2017
    Lone Rager
    ^^^ Yeah. It can be clamp dependent. Not saying this is your issues, but if a slot in the seatpost lines up with the slot in the clamp, it can really dig into the post. Arranging them so they don't line up can help. This is usually the default arrangement for use with carbon seatpost. Sometime they're 180 degrees apart but in some cases the seat tube may have two slots (Trek, for one) and the clamp slot is equidistant between the two.
  • 02-24-2017
    galicano
    it might be that you have an issue with the brass inserts since you wiggle your post before being able to put the post down. better make an appointment with a service or you can do it on your own with the right tools and instruction from sram via youtube.
  • 02-26-2017
    Christopher Robin
    Question about the process to rebuild the Reverb stealth:
    Pulled it apart last night for the first time to reset the IFP, oil and all that because I was sagging. I had to make my own IFP oil height gauge using one of my remote bleed syringes and a piece of aquarium air hosing. With my Reverb, my height it supposed to be 186.5mm. Fine no problem. But what I found is I couldn't get the tubing far down enough in the shaft to get the full 186.5. I was off by 4 or 5mm. I double checked and this is because the diameter of the hosing is too wide to fit through the blue 'thing' that presses into the IFP tube. I'll have to source a slimmer tube. I reassembled anyway just because I was at my wit's end. At the end of the day, the post is solid and seems to work fine....not trail tested yet.
    So how critical is that oil height? SRAM makes it look like it has to be on the money exactly.
  • 02-26-2017
    niva1989
    Ive got a proper oil height gauge and it only ever picks up small dregs of oil. The first few times I actually poured some oil in so the gauge had something to suck up but found it wasn't necessary. I don't think it needs to be that accurate. The best test is a working post.
  • 02-27-2017
    Christopher Robin
    Perfect good to know. I didn't get a chance to try it out on the trail but the post seems to working fine. Thanks.
  • 03-01-2017
    seamarsh
    Did you find a solution?
    I have the same issue, ill check the post collar to see if that helps.
    new , 4 months old reverb 170mm
  • 03-05-2017
    D3NN15M
    Will there be issues when a bike with a Reverb seatpost is stored upside down (hanging)? Thanks!
  • 03-05-2017
    niva1989
    My bike spends a fair bit of time upside down but resting on the seat. It's good for your fork bushings and seals and I've never had it cause issue with the reverb.
  • 03-06-2017
    D3NN15M
    Good to hear, thank you!
  • 03-07-2017
    TeamRWB
    duplicate
  • 03-07-2017
    TeamRWB
    So reading through here, it seems the sag is present even in the *Updated* model. I have the opportunity to get a good deal on one, cheaper than I can get any of the other External offerings out. Should I hold out, and Get a Fox or Thomson or will this be a reliable option. I noticed mention of using a RH remote vs a LH, and I may of missed an explanation of why skimming through here, so what is the benefit from this? I also read about replacing the u-cup seal with an o-ring, where can the o-ring needed be purchased from? And did anyone replace the Teflon bushing with a polymer made version of it, besides the guy in this blog, The Seatpost Whisperer | Blue Liquid Labs
    Granted I wont do any of the Maint related aspects unless its needed or warranty expired. Just educating myself.
  • 03-07-2017
    Christopher Robin
    Don't know anything about your seal question (which I'll look into as well since I'm always looking for things to make the Reverb more reliable), but using the RH remote vs the LH is personal preference: Using the RH remote on the left side places the plunger below the handlebar so it's easier to access with your thumb. This is also providing you don't have a front derailleur.
    Edit. After reading that article, I'd also like to know what size that seal is.
  • 03-10-2017
    superkermit
    I am selling my bike and thinking I should take the reverb with me and put in the giant one I am buying from the 2nd hand giant bike.
    Good idea?
    giant - https://www.giant-bicycles.com/us/trance-27dot5-1-2014
    nukeproof - http://forums.mtbr.com/all-mountain/...e-1034996.html
    I like the reverb and it looks like a better seatdropper.
    Will they swap out?
  • 03-23-2017
    RS VR6
  • 03-23-2017
    spyghost
    Originally Posted by RS VR6 View Post
    you beat me to it :p
    in any case, i can't see it in sram site nor google results
  • 03-23-2017
    RS VR6
    Could make an appearance at Sea Otter. That's where SRAM typically shows off new stuff.
  • 03-23-2017
    TeamRWB
    Please have an external option!
    Sent from the Beer Cloud
  • 03-24-2017
    spyghost
    b1 still has external just up to 125 only
  • 03-24-2017
    T3mppu
    I think that the O-ring is the same size as in externally routed reverb (3.5x9mm see RockShox Reverb Thread post ).
    I just rebuilt one stealth and replaced the U-cup with O-ring.
    The stealth U-cup was 10x15x4 and replacing O-ring 9.12x3.53 (couldn't source the 3.5x9).
    Unfortunately I don't currently have a frame with stealth routing (planning on drilling my 2011 specialized enduro), but compressing by hand, it appears to be working just fine. More testing when I get it into frame.
    I don't see why it wouldn't work with externally routed as the current remotes in stealth and external are identical per revision (see rockshox spare parts manual 2017_rockshox_spc_rev_b.pdf , there are separate remotes for A1 and A2, but not for stealth/non-stealth)
    The above image is from Vital MTB and there is some more info on the comments.
    For example, the product page apparently exists, but is not allowed to access: https://www.sram.com/rockshox/products/reverb-1x-remote
    I am mainly waiting for the price, as with the current remote price I rather buy another DeHy kit to convert the post to wire controlled than expensive but different hydraulic.
    Maybe the new construction will prevent the wear and leaking of the piston. (current design has only plastic bushing and there is usually sideload when pressing the remote)
  • 03-24-2017
    Mithrandir
    I want one!! The original actuator is the thing I dislike the most on the Reverbs.
  • 03-24-2017
    IndecentExposure
    I have successfully fixed the sag! I tore the entire seatpost apart and rebuilt it. I did use new IFP's, but was careful to make sure the oil was at the proper level. Thanks for everyone on this thread for all the helpful suggestions. We'll see how long this lasts!
    A few notes:
    My original IFP was pretty far down the tube. enough where the zip tie's wouldn't work. I ended up using 2 old spokes to 'hook' the IFP and used pliers to pull the thing out. Worked well.
    It would help to have the specific vice clamps (10mm), but I used the yellow rubber ones and they worked 'okay'.
    Once again, thank you to SRAM for making great videos. I literally just followed along.
    IE
  • 03-27-2017
    adcampo
    I'm switching from a left hand lever to a right hand lever mounted underneath on the left hand side. I've read I can do this without bleeding. Is that correct? Also, I'm assuming the new lever and cable will require trimming?
  • 03-28-2017
    niva1989
    I think you will def have to bleed it especially if you are trimming the hose as you might need to use a new barb. I always bleed as it takes 5-10mins at the most.
  • 03-28-2017
    arnea
    There is now barb in Reverb hose. You just screw the lever into the hose. If you are switching left hand lever to right hand lever on the left side just use the existing hose. If the new lever comes mounted to hose and filled with oil you might be able to avoid bleeding, but it's not sure.
  • 03-28-2017
    arnea
    Google has cached the German page of the new reverb. Not much information, just picture from different angle. It comes with Bleeding Edge technology. Interesting how it works with Shimano brakes.
    Price is important. e-thirteen new mechanical dropper post looks much better upgrade at the moment.
  • 03-28-2017
    niva1989
    There is a barb in the lever. It unscrews from the lever. Rebuild kit comes with a new one too. Only way lever will come with a hose and full of oil is with a new post attached to the other end.
    I don't know why people try to avoid bleeding. It's very easy to do. Much easier than bleeding brakes. If you own a reverb chances are you will have to bleed it at some stage and the bleed kit is cheap.
  • 03-28-2017
    arnea
    Ok, I've never changed the barb, always unthreaded the hose from the barb and then threaded it back after I installed the hose in the frame. I got the Connectamajig version of the post and it is possible to remove the hose from post without loosing oil and needing the bleed. I don't remember how it was packaged - IIRC it was competely assembled and filled with oil.
    And I agree, bleeding is easy.
