Results 1 to 90 of 90
    Jun 2012
    Reliable DROPPER POST?
    Ok I'm probably opening up a whole can of worms here, but I'm looking for a dropper post for my Turner 5 Spot. 30.9m seatpost. I've been looking at basically every post available, and all that I'm seeing are bad reviews on them. Is there a dropper post out there that's actually reliable for any length of time? I mean, I'm not going to lay out $200-$350 for a dropper just to have it fail in a few months, I'd much rather go without it than have a piece of junk that fails. Nor do I want something that requires tons of maintenance.
    Re: Reliable DROPPER POST?
    Dropper posts are like forks and shocks. At some point service will be MANDATORY.
    KS,Reverb, etc...they all work. But you have to give them attention every so often.
    http://Theclydeblog.org Big guy cycling product tester
    Reputation: kubikeman's Avatar
    Jun 2010
    Specialized Command Blacklite owner here.
    Uses a standard shifter cable and housing (no bleeding).
    Solid mechanical engagement/feel.
    Easy to disassemble and clean.
    Proven to be pretty reliable.
    Cons:
    Some people experience a broken collet (warranty issue I have not come across yet).
    Seal friction over time causes the need for a manual tug on the post every now and then.
    The saddle clamp needs to be watched as it can loosen and the saddle can rotate.
    Tiny (1mm or less) side to side play developed over time.
    Overall, most of the time the benefits outweigh the cons. It's nice though, I can remove it in 30 seconds, swap the saddle to a regular post and lose a pound if I'm riding flat trails.
    The cake is a lie.
    I have had good luck with my X-Fusion HiLo once I added some carbon grip to the rail clamp.
    Gravity Dropper seems to be the most reliable and low maintenance. I used one for over 4 years with no failures and limited maintenance (changing the cable once or twice). I currently run a Lev, but haven't used it long enough to give any meaningful feedback.
    I have a KS Lev on my 5 Spot and feel "meh" about the whole dropper post movement.
    I'd ask yourself if you really need one. Personally, losing the saddle offset isn't worth the convenience of dropping a post without having to undo a QR. Droppers add a whole lot of complexity where there once was none. Regular posts have zero maintenance.
    Jun 2012
    Thanks creeker, that's what I was thinking too after seeing all the problems with droppers... 5 Spot doesn't have a QR clamp, not sure why Turner sends them out w/o. Of course it's quite simple to get one, but I was just weighing a QR or just going all the way to a dropper.. I've always had QR, and honestly I always tended to not get off and lower/raise saddle because of interrupting my ride and getting post back to correct height/etc... so I was just thinking that perhaps a dropper is a good thing since there seems to be alot of hype about them out there and in mags/etc.
    Reputation: Vespasianus's Avatar
    Quote Originally Posted by k1creeker View Post
    Interesting view point. I am on the fence right now about a dropper for my 5-Spot. Part of me thinks, why the heck do I need one and the other side says that it would help on some of the more technical downs and drops. But, will the added weight hurt on the climbs?
    On MTBR, the reputation is infamous.
    Banned
    KS LEV 150MM owner
    Added weight hasn't bothered me. I ride the same trails 3 times a week and it hasn't slowed me down. I don't have a bike computer, so my information isn't 'exacting' to those standards, but climbing remains the same, sometimes better when I want the seat out of the way, and its fun downhill.
    I'll take it off for aggressive riding out of fear of breaking it, which speaks for itself.
    Gravity Dropper. I have replaced the cable and lubed it a few times in 3.5 years. No problems at all. All mechanical with no oil or air to leak and cause a failure.
    Reputation: 006_007's Avatar
    I think it really depends on the type of terrain you frequently ride. My trails have lots of ups and downs with technical features. I am a huge fan of my 150mm LEV (and the i950 I had for over 2 years before it). Only reason I replaced the i950 was I liked the cable mounting way better on the LEV - so it was a good upgrade.
    Reliability has not been an issue - although I do annual maintenance on them (same as I do on my shocks, brakes, drivetrain etc).
    Bicyclochondriac.
    Quote Originally Posted by gigabike View Post
    If you want reliable, get a Gravity Dropper Classic. I seriously doubt you read much that to indicate they are unreliable.
    Mine is 7.5 years old. Next to zero maintenance needed. I lube the shaft once every year or two, and I have replaced the cable twice. The switch broke after 6 years, it was a $15 part. My experience is not unusual.
    I am not aware of one other post that has the track record that GD does. It is as reliable as any other moving part on your bike.
    If it makes any difference to you, I ride a 5-Spot also.
    To me, there is simply no question that the dropper is worth the cost and weight. Of course, if I had to deal with the reliability issues most posts have, I might feel differently, but with the GD it is a non-issue.
    Mar 2013
    maybe im a fanboy?? but I chose to buy the RS Reverb, because of Srams Tech videos and parts being catologed and available everywhere.. Even ebay is full of the parts needed to rebuild the post. All of these posts need maintenance so why not have all the info and parts available when needed..
    I love using the Reverb and it has changed the way I ride for sure. I dont care about the weight, I care about having fun and it makes my bike and the way I ride more enjoyable. + the reverb adjusts to any spot and i use that feature a lot, even for climbing really steep technical. I can lower it just about 2" for fast/flowy trails that still need pedaling to maintain speed but still have lots of sweeping hits/jumps.
    LCW
    LCW is offline
    Reputation: LCW's Avatar
    +1 for Reverb. Smooth. Infinite adjustment. Hydraulic.
    /end thread
    Santa Cruz Hightower LT
    EVIL Following
    Reputation: AllMountin''s Avatar
    Blacklite owner. I broke my KS Dropzone after a couple months. It seemed pretty finicky with cable length. What got me in the end was the seat rail clamp. I run a slightly downward angle on my seat, and the clamp didn't like to hold the rail effectively there. Seat would slide all the way back in the clamp, which fatigued and cracked the aluminum head.
    I like the idea of the mechanical and air sprung Blacklite, if you can live with a 3 position post. It just works. Same way every time. Just don't put your junk in the line of fire when you push the lever, or you may receive a blunt force vasectomy. =-0
    bike rider
    Reputation: Lelandjt's Avatar
    That makes no sense. Worst case scenario with any of them is it fails and you have to send it back for warranty work while you "go without it" and use your standard post for a week or two. So you'd rather go without one entirely than face the possibility of going without one for a few rides? For what it's worth I've owned several droppers over five years and the worst I've had is going for 2 days without my first gen Reverb while Rockshox warrantied it. They knew I had a race that weekend and rush shipped a second gen post to me before even recieving my malfunctioning post. This was after a year and a half of use and it was a known problem with the first batch made. All three of my KSs have been perfect and my first gen Joplin just needed an occasional stroking to get bubbles out of it.
    If you want the most bomb-proof model that won't even risk having to finish a ride with the post down get a Specialized Command Post (1st gen or Blacklite). They use a mechanical lock that I've never heard of failing. Even if the cable snaps and/or the spring breaks/loses pressure you can manually set it in one of the three positions. Howevver, I prefer the infinite settings and non-moving cable of the KS LEV.
    Keep the Country country.
    GD is soooo reliable. one of the best investment.
    mine is GD turbo, built like a tank, but one of the lightest dropper post out there. very minimum maintenance, 99% always work, parts are cheap. I use it a lot during ride, been almost 3 yrs. no boot for me, the boot is ugly. GD just works. if you get it, i suggest you put cable noodle.
    i have 2 Spesh command posts. One on an Enduro that came with it, then bought one for my stumpy.
    Had them for about a year. I ride 1-2 times a week and use the post alot every ride , switching probably too often for all kinds of terrain change.
    Yes you can just stop and lower your seat, but the stops your rhythm and breaks your groove. It makes riding a little more fun and flowy. I know that once i used it for a week on my Enduro, i had to have one on the stumpy.
    Anyway, only issue i had so far was a known issue. I didn't torque the saddle bolt enough and the saddle started tilting up once after about half the ride. Tightened the nut and all has been good.
    I agree with Duke that eventually it will need to be serviced. Its one more bill to keep your bike working.
    I found a really good deal on pb. 175 for my command post.
    OP did indeed open a can of worms!! I got one for my Nomad, it made the DH a bit easier, but true it's another added complexity. I then got a 29er HT, dropped the post a little bit while on the trails (no funny bent knees) and did all the same trails without any problems on the fixed post.
    They are nice to have, but will they make a massive difference in your riding? not in my experience.
    Since they are not a huge amount of money, I would suggest giving one a try, if you are not happy with it, sell it for a minimum loss but you will have a definite answer to your question.
    Reputation: lew242's Avatar
    Dropper posts are all prone to failure, it's just in the nature of the work that they need to do vs the size they are, possibly the industry need to think about a larger seat post size across the board maybe make 32.4mm dia standard or make a new 34mm or 36mm standard.
    They are inherently fragile, yes you can use a good one like a GD for years, but if you wanted to you could induce one to fail in a few hours, just do a few 'no way' (feet off the pedals) endos and some aggressive wheelies or crash wrong and it will probably have more play than a kindergarten.
    Bicyclochondriac.
    Quote Originally Posted by lew242 View Post
    Dropper posts are all prone to failure.
    That's not true. Perhaps most, but not all.
    Quote Originally Posted by kapusta View Post
    What I mean is yes, some might never fail 'if used as they should be', as a trail bike seat-post. However if you abuse them even the best will fail, eventually. If you can't kill yours someone heavier certainly could.
    A good quality regular seat-post is always going to be stronger less heavy and less complex. However a dropper post is massively convenient and fun.
    MTB B'dos
    Reputation: LyNx's Avatar
    To the OP, as said, just like your fork or shock, a dropper will need service, some sooner than others, it's a new market as such and not a lot of real long term testing. I stayed away reading all the "wrongs" with them, especially the play some can have, but then I decided time to give one a go and got an X-Fusion HiLo 100mm post. So far it's been pretty damned good IMHO, bit of play I guess side to side, like a mm or two maybe, but I don't notice it when riding.
    I'm coming off nearly 9 years riding MTBs without one, so I often approach and ride stuff without using it because I'm just not accustomed to having it there - stuff I can ride with really lowering the saddle from learning that way, but which lowering the saddle would help a bit in being able to ride it more aggressive or faster with it dropped.
    Ves, best advice I could give is to try and see if you can demo one and see how you like it. I too have never had one and not really thought it a disadvantage to have to stop and lower my normal post manually before heading down a super steep descent or roller etc, but honestly it does help keep he flow so you can just roll right on it and down without having to stop. As to the weight, I really haven't noticed it to be honest, but then again I'm riding a 34lb+/- FS.
    Quote Originally Posted by Vespasianus View Post
    Bicyclochondriac.
    By your definition, almost everything on a bike is "prone to failure".
    Jun 2012
    inter - you stated no boot, it's ugly. I know I shouldn't put form over function in some cases, but I like how my bike looks and a boot is pretty ugly, makes it look really old school. Anyway - does removing the boot cause any performance issues and/or warranty issues that you know of? Thanks
    Bicyclochondriac.
    I would not remove the boot. The shaft does not seal like on a fork or shock.
    The fact that someone has gotten away without it for 3 years speaks volumes for the robustness of the design (might also have to do with where they ride), but the boot is on there for a reason.
    It'll largely depend on your terrain. I might drop mine once or twice a ride, and mostly due to the mindset that "I have it I may as well use it". I've ridden long enough at full saddle extension that I'm just used to getting behind it when needed.
    If I lived in Moab where you climb to play all the way down and usually encounter a climb or two on the way out, I'd consider it more convenient.
    It's one of those parts that's nice to have when you need it, but I'd easily give the dropper post up before any of the more important upgrades (disc brakes, modern suspension, a good wheelset, etc)
    a dad
    reverb owner for about a year, zero issues..
    also had a joplin (new seals) and zero problems for 1.5 years
    Persoanlly, i think they make riding more enjoyable..
    if you are on the fence buy a used joplin for less than 100 and decide if you like it
    BBZ
    Beer is proof that God loves us and wants us to be happy - Benjamin Franklin
    Thanks LyNx. I am going to go for it. Only other concern, is my weight of close to 200lbs but I think that should be fine. Anything that increases fun can't be all that bad!
    no issue at all for me. Im in Socal. I rode thru snow / mud during winter. Do you have GD? if you do, just try it for a few ride.
    no boot for almost 3 yrs. My one and only problem during a ride was when the cable broke, nothing to do with boot or no boot. That is why I put cable noodle.
    about warranty, Idk, well, I never need it tho. I did bought new inner shim and seal for like $9 after 2 yrs, not because it didnt work, but because the play has become a bit too much, inner shim was worn out, and GD recommend change the seal as well, so I did. GD customer service is one of the best out there.
    Good luck.
    Reputation: ihaveagibsonsg's Avatar
    Giant contact switch.
    Costs 200$ and mine is going on two years without a single service. It's infinitely adjustable and is no more complicated than the cable running to your rear derailleur. I have no issues of it losing travel, getting stuck, ect. Runs as advertised without fault. Install was cake. Took it out of the box and stuck it on my bike and that's it!
    Here, diagonally!
    Reputation: JACKL's Avatar
    Quote Originally Posted by kubikeman View Post
    Cons:
    I pretty much agree with this. My Blacklite has been in service for a year now. Iím 225, ride 2x per week pretty religiously, and probably change the height 20+ times per ride. The damn thing has surprised me by essentially being 100% reliable. It doesnít even lose air that I can tell.
    I do lube the stanchion about every 3 - 4 rides as the post will not come up as quickly when itís dry. I also run 60 psi which you are not supposed to do, but no ill effects thus far. 2 months ago, I took it apart, and everything looked fine. I just wiped off the old grease, slathered on some heavy grease, and put it back together. Pinkbike has the details on the procedure. I lubed the cable once when it started to get stiff.
    This post has a ĺ inch setback, which was a plus for my setup. If it broke tomorrow, Iíd buy another. Well worth the $250 bucks to me.
    Jun 2012
    Just an FYI everyone - I contacted Gravity Dropper regarding removing the boot, below is their response. Sounds like it's OK to do, not recommended, but does not void warranty so that's all I need to hear :-) I might go with the GD, sounds like the majority opinion is in their favor. Thanks everyone very much for all the feedback.
    Jun 2012
    GD's reply: "The boot is highly recommended in order to keep dirt and grime from accumulating inside the post. If you choose to remove the boot it will not void the warranty but may affect its performance. If you maintain the post regularly you should not have any issues."
    Good job!
    good choice! if you are getting the turbo, dont forget to get cable noodle or brake noodle. I got mine off ebay. not sure if GD has it.
    Feb 2012
    Recently put a GD Turbo LP on my 11' Spot and have been really happy with it. Get the LP and you won't need any noodle as the cable is more flexible. Purchased from Universal Cycles for $255 shipped use coupon code vip15.
    Jun 2012
    Cope: Did you get the 4" or 5"? Thanks
    Quote Originally Posted by Cope View Post
    Oh great, LP has difference cable now. I wonder if I can put LP cable on my old Turbo. just curious, I hv no problem with the noodle.
    Thanks for the info.
    Feb 2012
    I got the 5" multi position. Honestly thought 5" would be overkill, but it worked out perfectly.
    a dad
    careful with this.. some bikes have interupted seat post tubes and can only be inserted so far.. and they cant be cut down like regular seat posts..
    BBZ
    Apr 2013
    The Gravity Dropper is bullet proof. The other systems seem to have unnecessarily complicated mechanisms. The GD has a spring and a retaining pin. There is no need to over think this and rebuild the wheel. They have the full parts diagram on their website and anybody can rebuild the post at home...I really mean anybody.
    This is not the most gimmicky or blingy post but it is absolutely the most reliable.
    Jun 2012
    Cope: Thanks much for the advice and the tip on Universal Cycles deal. I just ordered a Turbo LP from them 5" drop with the coupon code! Thanks again!
    Reputation: PhaseSpace168's Avatar
    Sep 2012
    I have 2 2012 reverbs on 2 bikes, both have never broken or failed me after 6 months of frequent use on both. Also I'm 6'5" 190lbs so i probably put some odd strain on them. Great, reliable seat post IMO.
    Tree Crasher
    Reputation: rockhop's Avatar
    Mar 2006
    Gravity Dropper Turbo owner here for five years, back when the Joplin was the only other choice. The only failure was a broken cable some 18 months ago. Cost me four bucks and a ten minute drive to the LBS for some shifter cable and jacket. Since there's no air or hydraulics it works the same in ten degree weather as it does in 90. It's also the lightest, if not one of the lightest posts on the market. It's never dropped, sagged, stuck down or stuck up. Once it wouldn't stay down. Had to back off the collar by hand 1/8 turn (my fault). The only maintenance I've done is lube the inner tube. It's 100% serviceable and I've been meaning to replace some wear items but I say that every year.
    I defy anyone to make these claims with their post.
    CRAP... I'm in the wrong gear
    I view dropper-less riding as a compromise. It's easier to set up a manual with more freedom of movement, which in turn makes hopping easier. When doing a high(1.5 to 2 feet for me) hop, the seat always slaps me in the backside when bringing the back end of the bike up. The post height limits rear tire height when clearing obstacles.
    Won't matter if you ride only sanitized trails. Backcountry trails with large log overs and big boulders to mount, it comes in handy.
    You can't absorb a big hit with your body with a seat in your sternum. You can get behind the seat with a standard post on the descents, but it limits your range of motion and how much you can manipulate the bike on the way down.
    I broke mine on vacation last week. Bought the Blacklite same day so as to not compromise the riding on the rest of the trip. Game changer for me.
    Also, disc brakes and proper suspension aren't really upgrades in this category, but standard equipment. The wheelset might be a consideration, depending on what you've got. I'd ride a stock wheelset and upgrade the post first, personally.
    After having a dropper (150mm KS LEV) for a short time, I view it as something I won't ever be without moving forward. It just allows me to descend so much better and much, much faster. Some don't like a dropper, but the vast majority seem to say the same thing...that they wouldn't ride without one once they install it. The KS is bomb proof so far, but again, I have only had it a few months. There is some rotational movement in the saddle, but I can't tell it's there when on the bike, only when I am off of it and trying to move it around, so I don't think that matters at all.
    Reputation: kragu's Avatar
    I've owned a LEV and a used Reverb. The Reverb gave me issues (2011 model) so I went with the LEV. The LEV was awesome for about 6 months, then it was stolen along with the rest of my bike. The only thing I didn't like about the LEV was the remote - the hydraulic actuation of the Reverb was SO nice, going to the LEV's was a bit disappointing. The Reverb was akin to operating a dimmer switch - you're able to control the speed of the descent and return by how much you push the remote. The LEV was more like an on/off switch, which resulted in some rough drops. I'm making a bigger deal of it than it was, but it's there.
    I'm going back to a Reverb on my replacement bike. From all accounts, it seems they've fixed the 2011/2012 issues.
    Guessing Im in the minority a bit on my take - but my 2013 Satori came with the CB Kronolog. Lots of reported early issues etc - altho - in discussing w my LBS mech's - they believe alot of it was setup and the importance of the cable routing/angle at the clamp mechanism - i learned it firsthand when I changed out my seatpost clamp and didnt reset the cable - ended up with the slipping post. My error - not the product. That said - I've been riding the bike regularly since I bought it thanksgiving and if my gps is correct - close to 500 miles here in CO and UT - other than my error - NO issues and working flawless - also - with the tight technical and chunky i normally ride - it's made a huge diff for me - while they may not be or be needed for everyone, Ill never ride without while on my fave trails!!
    Bicyclochondriac.
    The fact that people are giving praises to their dropper post for lasting 6 months without issue really hits home how just low people's expectations are for these things.
    I think all you can REALLY say with confidence after six months that it is not a totally worthless piece if sh!t. After year, you can say that it does not suck.
    After the post has lasted 3 years.... 5 years.... 7 years...... THEN you will have a worthwhile opinion on how well built it is for the long haul.
    North Van/Whistler
    Couldn't agree more. I use droppers and am pretty amazed by how much of a junkshow dropper owners tolerate.
    Locals' Guide to North Shore Rides http://mtbtrails.ca/
    Team NFI
    Quote Originally Posted by LeeL View Post
    The most reliable one I have seen was a guy riding with an old school Hite Rite.
    Bicyclochondriac.
    Quote Originally Posted by Enduramil View Post
    I will say that I've never seen a Hite Rite dissed on grounds of unreliability.
    I've had a gravity dropper for about 5 years now, it STILL works extremely well considering how much I've used it over the years. Last year I bought a Reverb for my new bike and even though I like the way it feels, it has given me more problems that I would like to deal with in this short period of time.
    As far as reliability goes, I think a lot of people don't factor in riders weight. A person weighing under 150 using the same dropper seatpost as someone else weighing over 200 will probably see significant difference in reliability.
    Factor in moving parts that need seals and fluid, you can see where if you have any lateral movement, it will start to compromise relatively quickly. Yes I know some companies have "solutions" to these problems but point remains that people are still having to service/warranty adjustable seatposts within months of owning them.
    Gravity dropper though most basic in design, has proven itself on numerous occasions. I've had to get a new spring, a lever, and new cable housing but nothing has ever broken, it is always runs smooth.
    Other droppers such as the KS and RS feel really nice, I like the adjustability but I'm more confident in my older GD Turbo.
    Just re-inforcing what everyone else has said about the Gravity Dropper so far and OP, it also has a high user-review rating here at MTBR.
    'been using the GD classic since '07. System simplicity gives it high reliability and makes it easy to fix/maintain. No special tools needed, very supportive company and parts are shipped quick.
    I'd say about 80% of folks I ride w/ uses an adjustable post so I've seen the assortment and heard the issues w/ other brands - a big group discussion at times. Our terrain of rock gardens, roots & rollers isn't gear friendly but the GD has held up steady on numerous crashes.
    I also bought a Specialzied blacklite command post last year and it's becoming a fav. I like the fact that it can be manually operated and still function like a regular seatpost if the seals fail. If anything, I think rider weight plays a big role on durability, I'm 140 lbs fully geared.
    d butt u kicked today, could b d same butt you'll kiss tomorrow.....
    Reputation: bigfruits's Avatar
    Mar 2011
    ive done 3 good rides on a 150mm KS Lev on a 1x10. i knew it was a gamble when I ordered but after a few rides, ill be content if it makes it to winter '14.
    i don't think ill ride without one on anything but featureless XC. if your local trails call for it, you gotta try one. after you order it, the voice in your head will stop.
    Reputation: mazspeed's Avatar
    Gravity dropper has been real reliable. In that price range that one has been the best so far. I have had good luck with the joplin4 but a lot of others have had issues with it. You can find new jop4's on ebay and pinkbike cheap.
    Jan 2013
    I want a drop post also but the horror stories of faulty equipment has me confused
    17' Riot
    12' Horsethief
    96' Killer v
    Bicyclochondriac.
    Quote Originally Posted by sdm74 View Post
    Not all models have horror stories.
    Jan 2013
    Which modern one doesn't? I really do want one, but spending 500 on a Thomson is a little high. And the GD seems outdated
    17' Riot
    12' Horsethief
    96' Killer v
    Bicyclochondriac.
    Outdated how? Looks funny? Lacks features that nobody has proven they can pull off with long term reliability?
    Seriously, 99% of the function of a dropper post is to go up and down and stay where you leave it. $230 gets you one that will do that very reliably for a very long time.
    I don't know what it is about dropper posts that makes people throw common sense out the window. You have a reliable product that is wildly successful, enough so that it attracts many competitors. These competitors keep trying to add features (and raise the price), but they are for the most part unreliable (time will tell about the latest batch to come out in the past year or so). Now suddenly the original product is "outdated" even though it is the only one to be proven to actually work over the long haul.
    It's like calling regular seatposts "outdated" because they are not dropper posts.
    The GD will be "outdated" when someone else proves they can make one just as reliable with more features. Right now the only possible contenders (too soon to tell) cost way more.
    bike rider
    When a dropper post stops dropping and becomes a heavier version of a standard post it's a horror? When you have to make a phone call, a little wrench turning, trip to the post office, and run your old standard post for a week or two....it's a horror?
    I'm not passing off your 1st world fears as insignificant, I have my own:
    1. Having to get off my bike every time I want to change my seat height.
    2. Having to ride a section of trail with my seat at an non-optimal height.
    P.S. In 4 years of using dropper posts I've only had to spend 2 days riding on a squishy post that wasn't properly locking and I've never had to remount an old standard post (thank God, the horror).
    bike rider
    The Specialized Command Post (mechanical spring and lock) seems as unbreakable as a GD and the Blacklite version is the same with the exception that the air spring could lose pressure. This seems unlikely though as it's very low pressure (20-30psi) and if it were to lose the spring it can still be raised with your thighs and the mechanical locking mechanism will still lock.
    I like my Command Post Blacklite but I like my Reverb and LEV better for the infinite adjustment and LEV's 6" travel and fixed cable.
    Jan 2013
    Quote Originally Posted by Lelandjt View Post
    Its a figure of speech as I'm sure you are aware.
    When people are spending 4 to 5 hundred bucks on a seat post and it works a handful of times or not at all that seems "horror"ible. Unless you have so much cash to throw around you can afford to buy and try them all
    17' Riot
    12' Horsethief
    96' Killer v
    Jan 2013
    Thanks for really putting that in perspective, seriously.
    Guess I will be looking for a GD in 31.6
    Which model gd should I look at?
    17' Riot
    12' Horsethief
    96' Killer v
    Reputation: las-palmas's Avatar
    That is my idea of a long term test. If it does last 3 or 5 years without problems: Then it is OK!
    I am looking for a dropper post, but only the GD seems to be close to that kind of reliabily from having read the posts so far.
    Nothing new in this old thread. If reliability and DIY annual service is most i portant, then get a GD--they do what they are supposed to do and when they need some grease it is a 10 minute DIY job.
  67. #67
    Reputation: TahoeBC's Avatar
    Just picked one up at a great price, no tax and free shipping
    Road & MTB Bicycles, Bike Parts & Cycling Clothing | Merlin Cycles
    ORDER DETAILS:
    1 x Thomson Elite Dropper Seatpost - Black / 400mm / 31.6mm / 125mm Travel @ USD 304.66 = USD 304.66
    1 x Happy New Year! Save 10% On Your Order (Percentage Discount $304.66 @ 10%) @ USD -30.47 = USD -30.47
    TOTAL USD: 274.19
    I just gave up on my LEV, back 3 times since I bought it 1 1/2 years ago, last one I sent in in October, they messed up and shipped it to the wrong address over thanksgiving, after 2 weeks of e-mailing and calling them everyday I finally get an email saying they do not stock posts and they placed an order at there china factory and lead time is 60 days. There customer service sucks so bad, I never want to deal with them again, as soon as I get my new post from LEV, I'm selling it new in box.
  68. #68
    Reputation: jon123's Avatar
    My vote goes to the much under-appreciated Fox DOSS. It is rock solid, no play, and super smooth. Excellent construction.
    I think a lot of the criticism came because of the lever. It's sort of a love it or hate it affair.
    If you're running a 1x (like me) then it is actually THE best lever out there (I've owned Reverb, Lev, tried Thompson), fitting very comfortably in place of the front shifter.
    That said, I can see that if you're not running a 1x system how the lever would be less than ideal.
    I didn't have any problems with my Lev (very nice feeling post actually) but KS sounds like a nightmare company to deal with if you ever do have to send it in, which I think with droppers you have to assume you may. Whereas Rock Shox and Fox you know who you're dealing with.
  69. #69
    Banned
    having posted in this thread back on 5-21-2013, I was skeptical how durable the post would be. Now I don't take it off and I've banged the heck out of it without any problems. I've only used a LEV 150mm.
  70. #70
    Viva la Vida!
    Reputation: Camaleon's Avatar
    Gravity Dropper Turbo LP FTMFW!
    There's nothing else out there as reliable.
    And it has the advantage of being a Mom & Pop company that makes them in the USA.
    We do not stop playing because we grow old;
    We grow old because we stop playing
  71. #71
    Feb 2007
    Followed this thread a while ago......bought a Gravity Dropper......too early to judge reliabilty.....but it's definetely one of the better purchases for a bike so far....
  72. #72
    Feb 2013
    My vote goes for Giant Contact SL Switch Seatpost. Got it for a $180, it looks great, works great, infinite adjustability, it has a stealth routing option, no problems so far. Next is command post. If specialized sold replacement collets for this post separately, that would be my #1 post by far.
  73. #73
    Viva la Vida!
    Quote Originally Posted by El_Zilcho View Post
    You got to be kidding me!
    That's the worst dropper of them all (The GIANT Contact) in my personal experience.
  74. #74
    No good words for that dead weight. Replaced it with the DOSS. sorry
  75. #75
    Bicyclochondriac.
    Quote Originally Posted by Camaleon View Post
    I think that honor might go to the CB Kronolog.
  76. #76
    Feb 2013
    What was wrong with it? I really would like to know. When I bought it end of last year there were very limited reviews about it and most of them are positive. Actually most of the other droppers mentioned here apart from gravity dropper had a lot more negative reviews. And I'm talking about new 2015 all black version. Like I said so far I have very positive experience and for the price I paid if it lasts a year or two I would be happy and it has 2 year warranty.
    +1 on that
  77. #77
    Viva la Vida!
    Yes you are right.
    I don't remember the Kronolog experience to much as it failed on my 2 ride and I just got rid of it immediately.
    The Giant lasted like 4-5 weeks before it wouldn't go up all the way and it wouldn't stay up even when lifting it by hand.
  78. #78
    I do love your filosofy.
    Wish more people understood.
    errare humanum est
  79. #79
    Reputation: targnik's Avatar
    Jan 2014
    KS Eten :FTW:
    it's cheap (price, not build) it works( had mine for 18 months) as long as I keep it clean, all is good.
    Opinions are like A-holes... everybody
    has one & they're usually full of...??
    "Mountain biking: the under-rated and drug-free antidepressant"
  80. #80
    Quote Originally Posted by Flucod View Post
    Having some many issues lately, I am done with any post but the GD. Bought a KS Lev and it failed first ride, was repaired and sold on Ebay. Replaced it with a Thomson and it now just failed on its second ride, less then 10 total miles. Have used GD for years but wanted something sleeker looking. Was going to order RS Reverb but with all of the issues with them, just dont want anymore hassle. Will be re-ordering a GD on Monday!
    Sorry you have had all thse issues, it's a bummer, but wlecome back to the GD family. i have them on both of my bikes. No issues, incedibly easy to service DIY, they just work. Oh, and if you need a part or have a question, GD has outstanding customer service.
  81. #81
    The Original Suspect
    Reputation: HitmenOnlyInc's Avatar
    Speaking of GD, a buddy of mine got a Chinese nock-off for some ridiculously low price and he's happy with it.
    My LEV DX has been issue free for 9 mos. In fact I ride with three other guys with either the LEV or the DX and there hasn't been any issues.
  82. #82
    Reputation: Havinfun's Avatar
    Mar 2015
    Not much love for the Thomson??? Had mine for about a year. Perfect so far, except a bit slow when it was 25 degrees. My Spesh needed a repair in the first year and made for a very problematic ride when it became an autodropper.
  83. #83
    Quote Originally Posted by Havinfun View Post
    I am surprised the Thomson does not get more raves or love but it might be small market share compared to others. I have one and a Crank Bros. The Thomson has had perfect function and reliability for a year and my Crank Bros had 3 trips to the factory in its first year.
  84. #84
    Nov 2008
    Love my Thomson, over a year now. Perfect.
  85. #85
    Nov 2013
    I am surprised at all the Thomson bashing as well. I looked into a bunch of them for my first dropper purchase and it came down to GD LEV Thompson. Merlin came out with a great deal on the Thompson and I pulled the trigger. 9 months so far and no issues. I use it almost as much as shifting. Great upgrade and for me worth the hype. I am not brand specific and am considering a GD for my hardtail
  86. #86
    take the boot off the GD and it looks like all the others. You just should wipe any dirt off you see like your rear shock.
    Lead by my Lefty............... right down the trail, no brakes.
  87. #87
    Why is it bashing when you pay $450 for a product that fails after 5 miles of use? My guess is you would not be excited either.
    I think the $450 price tag is what keeps the Thomson limited.
    I do agree that it should be perfect at that price. Their CS is great, but you still have to send it back to them.
  1. 27.2 Dropper post ?
    By Saucyjack in forum 29er Components
    Last Post: 09-16-2016, 04:06 PM
  2. What dropper post can take DH?
    By man w/ one hand in forum Downhill - Freeride
    Last Post: 04-02-2013, 11:10 AM
  3. Anyone try the XLC Dropper Post?
    By cleo in forum All Mountain
    Last Post: 12-21-2011, 02:55 PM
  4. Have a RIP? Get a dropper post!
    By Jisch in forum Niner Bikes
    Last Post: 12-06-2011, 06:52 AM
  5. Post your old, reliable, beat Santa Cruz
    By debtfree1 in forum Santa Cruz
    Last Post: 06-30-2011, 07:59 PM
