Page 1 of 2 12 LastLast
Results 1 to 100 of 132
    Reputation: AaronJobe's Avatar
    KS LEV Integra??? Where is it?
    Is the ks lev integra out yet? Where can I get one?
    Reputation: lancelot's Avatar
    I just got one in the mail today.
    The LPG
    Quote Originally Posted by lancelot View Post
    Did u but it on ebay
    Yes. It was only one I could find. Bummer it is broken though. Gotta call KS today about getting it repaired.
    The LPG
    What was broken on it?
    The piece in the bottom that holds the cable housing was sheared off where the springs attach. Hope they have parts in stock to repair it.
    The LPG
    Just saw this in stock at artscyclery. Comes up to $340 with 15% off. Shipping should be free as well.
    Received a broken one as well....straight from the distributor.
    in Boulder, Colorado, United States - photo by nyesteeze - Pinkbike
    Damn! That piece needs to be made out of something a little stronger!
    That is exactly where mine broke. Call Ron at KS. He should have replacement parts by now because I just got mine. They are also aware of the packaging problem and going to beef the part up a bit according to Ron. It is super easy to replace.
    The LPG
    Aug 2013
    Has anyone used a KS LEV Integra with a Tallboy 2 Carbon?
    I am trying (in vain) to do so, because the cable housing moves relative to the frame, thru a grommet in the frame, which due to friction between cable housing and grommet, the return springs on the seat post are not strong enough, which causes terrible operation of the seat post, will not stay locked, goes up when it should stay put...just plain sucks.
    Tried 'hollowing out' the grommet, Triflow on grommet/housing, cable with slack, cable without slack...it all ends up not working very well at all.
    Anyone have suggestions that have worked for them?
    Thanks.
    On my Bronson carbon I zip tied rings around the brake cable going up the frame for the housing to move free inside of them. Also you need to make damn sure you have just the exact amount of housing also adjust the cable about 3mm short of the diagram on the seatpost
    Aug 2013
    MonkeyBoy65 did you ever come up with a solution that worked for your Tallboy? I have the same situation with my Solo, have to fight with the damn thing on every ride.
    Aug 2013
    Yep, here is what I did with help of Aaronjobe:
    Yes, my KS LEV Integra works now. Here is how I got it to work. I also got some tips from aaronjobe on forum too, didn't have to try everything he said, but will tell you what he told me.
    A LOT of words here, I got detailed help from aaronjobe, trying to return favor.
    The problem: The housing has to move relative to the bottom of the seat post. The lollipop end of the cable does not move at all. The housing pulls CLOSER to the end of the post, which means it has to travel in/out of the frame. But there is a lot of friction on the housing due to grommet, bending it, etc. Thus, when you push button, housing goes INTO frame, seat post drops, but then the 'return springs' on the post are not strong enough to push housing back away from post, back OUT of frame, hence, button stays pushed and seat post sucks.
    1. Take the grommet out of the frame; notice it has the outer lip that touches the frame, then in the center, a membrane. Get a new xacto #11 blade; completely remove membrane so grommet has a clean thru-hole. Do not OMIT the grommet, the carbon fiber is even more 'grabby' on the housing...I tried this, does not work.
    2. Route cable for seat post, etc, set it up exactly like graphic on the post shows. Aaronjob said even less cable sticking out than graphic, about 3mm less. I cannot second this though.
    3. Aaronjobe said pre-bend the provided cable housing to give it the shape it will have on the bike frame, totally agree with this. He also recommended higher-end Jagwire housing, which I think is both easier to bend (more flexible) and possibly smaller outer diameter. The included stuff worked for me, but I think Jagwire would still be better.
    4. Route the brake hose to the frame cable standoffs with zip ties. THEN you will zip tie the post housing TO THE BRAKE HOSE.
    4a. Install the post housing zip ties ABOVE (higher up) than the brake hose zip ties because the looser post housing zip ties will not fall down due to gravity/bumps.
    4b. Notice LOOSER zip ties for post housing, very important, aaronjobe reminded me of this too, and I agreed. The post housing must be free to slide/move relative to the brake hose. Ensure post housing can move up/down thru zip ties.
    5. I originally had noodle below/behind the brake reservoir, it looked better, but aaronjobe told me it should be in front of/above brake. I think instructions say this also, so I agree. I actually got my post to work with the noodle in either position, but in front/above brake I think is better.
    6. Here was my ‘trick’: I think instructions say to start with barrel adjuster all the way screwed in, then to adjust out ALL slack out of cable. I did this originally, and the post would never work. I finally screwed the adjuster all the way back in, resulting in a pretty sloppy feeling button, but with all that slack, it STARTED WORKING PERFECTLY!!! I really believe this is due to a tight cable causing more friction on inside of the housing, reducing housing's ability to slide around on the cable. Once there was more slack = less cable/housing friction = post works.
    7. Cable length on bike should be longer if anything, not shorter. Sneak up on housing length...cut a bit, try again, repeat.
    7a. DO NOT CUT CABLE to final length like instructions say until you are sure it works! I had to install/remove the system about 10-15 times, left the cable long, and only torqued set screw enough to prevent cable slippage, which will partially squash cable strands, so I highly recommend a backup brake cable on-hand just in case. Only after you know the post is working, cut and stow cable end.
    8. Triflow on the housing and grommet I think helps, aaronjobe mentioned this too I think.
    9. Try to be patient....this system with a Tallboy and likely also a Bronson could be a pain in the behind to get right. I tweaked, fiddled, cussed a LOT, tried again, gave up, tried again...then figured out step 6, and then it has been great from then on.
    I was plenty pissed after spending that kind of $$$$$ on that bike, then that kind of $$$ on just about the most expensive post you can get, only to have it totally suck, never stay put, drop without touching the button, etc. Once it works, and you learn how to best use it, it will REALLY change the way you ride that bike. SO much safer/confident on steeps, drops, rocky down-hills.
    The moving part of the tube wiggles just a bit relative to the part in the frame, which I notice when handling/walking the bike/seat, but never notice it during riding. The post has ~150 miles on it so far, wish that number was a lot higher...but it has worked well so far.
    Good luck. I can also send pics if that will help. Let me know.
    Reputation: DrewBird's Avatar
    While I appreciate the detail here, I have to say I'm considering returning the (so far unused) Integra I have sitting in the garage. This just seems like a total pain.... and what happens if-when you are unfortunate enough to need to change your seat height by a couple mm, like when changing pedals or shoes? Doesn't is screw the whole fragile system up? Having it depend on movement of the house seems like a bad design.
    Quote Originally Posted by MonkeyBoy650 View Post
    Aug 2013
    Yep, I completely understand your point......but once it works, it's so sweet! I cannot really defend the design at all though, I agree, why move the housing when they could have almost as easily moved only the cable, which would totally fix the problems everyone is having...? Not sure what is going to happen when I need to remove the post for any reason...could screw it all up.
    If it helps you decide, one thing I have not commented on is how when I contacted KS with this issue, and I also contacted Santa Cruz...KS never replied at all, not one peep. Santa Cruz on the other hand replied to my email in about 12 hrs, tried to help, but the guy I emailed back/forth with was not familiar with the LEV Integra. He mentioned they have been using the Reverb without issue for a while. For whatever that is worth.... Good luck.
    Yeah, but would the bike be just as sweet with a nice Thomson on there, even though it doesn't have the internal routing? Maybe it'd be a bit less "clean looking" but I bet it'd ride as well. Don't get me wrong, I loved my Reverb Stealth (until it quit working). I'm just disappointed that KS seems to have screwed up what could have been a great post--and a great alternative to the Reverb--with a horrible actuator design.
    Thanks for the credit! You can move your post height up or down, I have enough slack that I could raise the post an inch if I needed to. I also have a pretty slick way of cable routing on my Bronson now I will post pics later
    Living the Dream
    Reputation: Alpenglow's Avatar
    Would you guys have purchased a regular (non-integra) version of the KS Lev if you could do it over again. I am building up a Spider Comp with Stealth cable routing and after reading this thread, I am thinking maybe the non-integra version is the way to go.
    "And I shout that your all fakes and you should have seen the look on your face"
    Aug 2013
    My 2012, external-routed LEV was totally reliable except on really wet/muddy days, so yeah I'd recommend one of those over an Integra.
    After prolonged tweaking I've gotten my Integra working 99% of the time on my Solo. Finding just the right sweet spot for housing length and cable tension took a while but the steps listed by MonkeyBoy above are exactly correct!
    Living the Dream
    Thanks. I think I am going to go with the non integra version.
    Quote Originally Posted by deepwat3r View Post
    I was able to install a 5" Integra on an 09 Force Carbon without much issue. The hole where the cable goes through is at the bottom of the seat tube, so maybe that makes some difference with respect to how the cable bends. I just followed the installation manual, including the length of the exposed cable that connects to the bottom of the posts, the length to cut, and torque values, especially for the seat post clamp. The seatpost worked fine before and after cutting the cable to the proper length.
    Reputation: bikepikespeak.com's Avatar
    Nov 2013
    I had some of these same issues on my 2014 Kona Process 153. It doesn't seem to need to be AS picky as from what I read above. My question is this though. I have it all working well with the exception that when it is extended up all the way there is a little give in it. I haven't really noticed it while riding, but I'm guessing that should happen? Do yours give a little? It's for sure locked out as it's not dropping on me...but it gives about 1/2" when weight is applied. Any thoughts?
    Aug 2013
    Quote Originally Posted by bikepikespeak.com View Post
    I only had this happen as a result of the issues detailed above, housing tension vs. the springs on the actuator. When mine's working, and it's up, there's no give. In your situation, to know for sure, I'd test with the post off the bike or with enough slack on the housing to rule out any actuator issues.
    Jun 2013
    That design flaw is completely bewildering to me, particularly since the pre-production prototype they first unveiled didn't have it (second pic down) - KindShock Unveils New LEV Integra Dropper Post, Along With LEV
    If the post is that good, why not wait until it's fully engineered to release it? This flaw is enough for me to say I'll hold off.
    2014 Trek Remedy 8 29er
    2003 Gary Fisher X-Caliber
    Reputation: dan4jeepin's Avatar
    My post was acting off at first with the stock Teflon cable so the shop swapped it out with a standard cable and dripped tri-flow on it. They felt that it was binding up some where in the housing. Now it doesn't have any problems and I even moved my seat up 1/4 inch without having to make any adjustments.
    Aug 2013
    Quote Originally Posted by Billy Mumphry View Post
    Wow I never noticed that but that prototype interface is totally different!
    It's unfortunate that KindShock has made so little investment in customer support, leaving it to others to figure their way around such design flaws. They need to follow the lead of some other manufacturers (like RaceFace) who keep an eye on threads like these and offer some explanations at the very least. I bought the Integra because my original LEV (despite chronic seat clamp issues) worked flawlessly for two seasons but unless I see an improvement in customer support it'll probably be my last KS product.
    Jun 2013
    Bizarre, right? I mean I have to assume there was a benefit to going the way they did, but I hope the backlash isn't lost on them (or rockshox). I really want a dropper, but I'm not adding something to my bike unless it's reliable.
    Totally agree, and the Integra issue isn't a reliability thing, it's a bad design. Did they just test it at a workbench and not ever actually install/ride with it?
    Also FWIW, I know personally of at least 6 non-integra LEVs that have failed (one was mine); they become "suspension posts" i.e. develop an inch of squish at the top of their travel. Seems to happen with increased frequency in cold weather.
    I've also had to warranty a Reverb. They sent a new post, which arrived with a blown seal and oil soaked through the box! So they've sent another one. It has a good 1-2mm lateral play right out of the box.
    My current favorite by far: The Thomson I have on my Ripley. Rock solid so far, though I've only had it a couple of months. They're coming out with a stealth version, supposed to ship in March...
    Reputation: mtbgtr's Avatar
    Feb 2014
    Wish I saw these posts before getting the Integra. Santa Cruz told me they dont spec this post the spec the Rockshock. I'll be going back to the shop I purchased frame and post from for a fix or a new post.
    Reputation: boostin's Avatar
    Quote Originally Posted by mtbgtr View Post
    fwiw, I had a reverb stealth and it was a pile of ****. In the first 8 weeks I owned it they sent me 2 warranties. The first time the post dumped its oil into the seat tube after 2 weeks. The second time it just stopped working, again after only a couple weeks.
    I am currently on the Integra, but don't have enough rides in to say if it works or not.
    Aug 2013
    Just saw something interesting here re: the Integra's actuation: Singletrack Magazine | The Bike Place - Here's what caught our eye
    Somehow I doubt KS is going to offer a free upgrade to those of us who have been struggling with the 1st-gen Integra but I'm about to email them about it anyway.
    Good news everyone!!
    "KS knew about the issues as well and have come up with a redesigned mechanism that eliminates that problem by way of a revised housing stop design. Already own an Integra? KS is going to offer you a free upgrade that will fix your post with a minimum amount of hassle"
    Mine still works fine but I'll take the free upgrade whenever they roll it out.
    Aug 2013
    I saw a rumour of this in another thread and RMA'd my post a few days ago requesting the upgrade. I will post back here when I hear something from KS.
    Aug 2013
    I received my Integra back from KS, had a little over two weeks turnaround, and the new mech is MUCH better. The cable movement is now completely isolated from the housing, and the cable now feeds through the remote trigger the way it did on my LEV. They even cleaned & lubed the internals so it's like getting a brand new post.
    Now if they'd just do something about the seat clamp...
    Feb 2014
    @deepwat3r
    The new design still doesn't look like the original design. I can't tell from the pic above, but can you tell me in the new design if cable movement now actuates the post or housing movement still actuates the post? Thanks.
    KS needs to take a lesson in customer care from Santa Cruz, two emails and two phone calls to KS and no response and no mention of new design on web page. One email to Santa Cruz and I received a reply same day.
    "If you're getting chased, you don't have to be first, just don't be last!"
    Aug 2013
    Yes, the cable motion is isolated from the housing. The housing doesn't move at all now. Mine works perfectly now, even if I dare wiggle my housing around to clean!
    And I couldn't agree more re: customer care. KS is really poor on communication, even compared to other companies in this industry. I give them credit for upgrading/servicing my post with decent turnaround time but I got zero communication from them about the RMA until the box showed up in the mail. And no response - ever - to my first email asking about the new mech.
    Nov 2013
    The cable feeds through the trigger the same way as the LEV? As in you insert it there and work back as opposed to the opposite? Did they ship you a different trigger than also? Aren't they different? I received mine back with the retrofit done and while it does work better (ie doesn't need housing to move) it didn't come with any other parts or directions. In fact there was no clear way at all for me on how I should be attaching the cable to it. The hole in the retrofit was too big for a end of the cable.
    The first picture is how I set it up currently but doesn't seem correct. The second pic is how I set it up first but the end of the cable kept falling off the actuating lever.
    Attached Thumbnails Attached Thumbnails KS LEV Integra??? Where is it?-image.jpg
    Aug 2013
    I received a new cable, new trigger, updated instructions and a crimp-on stopper for attaching to the new mech. The cable is a standard shifter cable, inserted through the hole in the trigger. Then you crimp on the stopper and slide it into the new mech, but perpendicular to the way you've got your stopper in there now.
    Will send pics later when I get home, but you should definitely hit them up for the new trigger/cable/stopper!
    Nov 2013
    Thanks for the help. I called and they are shipping out the other parts to me today.
    Reputation: MustG0Faster's Avatar
    Appreciate all of this info. I am about to purchase a KS Lev Integra but I've been put off by the negative reviews. It sound like they have worked out the bugs now.
    i32
    i32 is offline
    They worked well. Waiting for updated actuator.
    I solve this issue particaly witn softer outer casing. Got one from Shimano Road Shifting Set.
    Reputation: GR1822's Avatar
    Deepwat3r and bikepikespeak.com---
    How is the LEV integra working for you now that you have the upgraded part? I'm looking to buy the integra if the problem has been sorted out.
    Aug 2013
    Quote Originally Posted by GR1822 View Post
    I would say near-flawless. No more actuator-related problems at all, and it was easier to install & get adjusted properly.
    Now if they'd just beef up the seat clamp a bit they'd have the perfect post
    I wash my chamois every 50 rides whether it needs it or not.
    Nov 2013
    The only issue I've had was user error most likely. I did not secure the hex screw tight enough in connecting the piece to the end of the cable that attaches to the post and when I was riding it call came loose. I had to take my bike all apart to get the little piece out of the frame! haha. I tightened it good the next time though and everything has worked great. I don't know why they didn't do it like this in the first place.
    Mar 2005
    I'm another person very happy with the update after a month of riding it.
    Sent from my SCH-I545 using Tapatalk
    Apr 2014
    I just got a KS LEV Integra on Pinkbike from Fodster. He sells them brand new for $275 out the door. The one I got was already upgraded and easy to install. Check him out he's a cool dude.
    Jun 2013
    Is this the upgraded LEV Integra?
    I just bought a KS LEV Integra from Fodster, thanks for the tip Bosko!
    I'm not familiar with what the new mechanism looks like compared to the old... Can anyone tell me if this is the new upgraded model or not?
    Thanks in advance!
    Apr 2014
    Yep. That's it. Just make sure u follow the directions. They can be a little confusing. If you want to get a hold of me I can give you some tips to make it easier. U can call me 916-412-5207. That is my business cell. I own a mountain bike clothing company called KENETiC. You can look me up too on Pinkbike under the profile name Bosko.
    Quote Originally Posted by nstokes View Post
    Thanks in advance!
    Jun 2013
    @Bosko - Thanks for the offer, I'm having my local guy put it on, but I greatly appreciate that. And thanks for confirming too!
    Reputation: SoCal-Rider's Avatar
    Old One?
    So then I just received the old style?
    KS LEV Integra??? Where is it?-photo-1.jpgKS LEV Integra??? Where is it?-photo-2.jpg
    Aug 2013
    Quote Originally Posted by SoCal-Rider View Post
    Yup, you should send that straight in to KS for the upgrade, or back to where you bought it.
    Thanks for confirming. So much for calling up Jenson before ordering to verify they stock the new version.
    Jun 2013
    [QUOTE=SoCal-Rider;11240340]So then I just received the old style?
    I can't recommend Fodster on Pinkbike enough. Exactly what I wanted, shipped quickly and excellent, responsive service. If you can return this one, I would order from him instead. If not, KS should retrofit it for you, but you'll be out a few weeks from what I've heard.
    Jul 2014
    Personal experience with the old actuation version of KS LEV INTEGRA:
    1. The actuation is based on the movement of the cable housing when u push the button on the handle bar button. Therefore the cable should be moving free thru the frame, including the cable housing openings (i.e. hole in the frame). Thus your frame should be compatible with big enough openings for the cable housing and smooth cable movement inside the frame.
    2. The cable tension should be just enough to trigger the button, not too big, not too small. If you follow the KS instruction, you cut the cable before installing the cable end to the seatpost, you may get too much slack to the cable and the cable, ferrule will be coming out. If you get too much tension, the spring may be pressed too much.
    3. I would install the cable end, ferrule and housing first. Screw in the needle same as KS instruction. Then install the cable to the lever and pull it a bit to ensure tension is just enough so that the ferrule will not coming out. Then screw fixed the cable end. Adjust the tension if necessary by unscrew. Then put the seatpost to the frame (and pull the cable housing out from the frame at the same time, both hands required)
    You should be able to get a working LEV INTEGRA with old actuation lever. However, you should get an upgrade if any from KS because the design is bad. Water will go inside the frame from the space between the frame and cable housing. In addition, you could always hear the spring noise whenever you press the lever button
    Nov 2007
    I just got a new first generation Integra and will sending it in for an upgrade. Is there anything else I need to send from the package other than the post itself?
    Aug 2013
    Quote Originally Posted by LucindaInGA View Post
    Nope, all they'll need is the post itself. What you ought to get back is the post with new mech at the bottom, a little plastic cap thingy over the mech, a new cable + a new actuator.
    Does anyone have any experience of the 150mm 30.9 KS integra? Is it proving reliable?
    Mar 2005
    Quote Originally Posted by Rick Draper View Post
    Mine's been great for the whole summer now (I had the update done before installing it on my Enduro 29). Smooth as butter and solid feeling. 150mm of drop is so nice. I never touch the seat collar now while with a 125mm post I always felt like I needed to drop the seat a bit more for larger jumps. I personally think infinite positions are overrated, but if it's this or a hard to find middle position, I'll take this as seat position in those situations isn't that critical.
    Reputation: dirtbiker's Avatar
    Jan 2005
    Are these posts still doing well with the new updated design? I am deciding between a KS and Reverb but want to make sure there are no known issues before deciding.
    2017 Pivot Mach 5.5
    2017 SC Hightower CC
    2017 SC Tallboy 3 CC
    2013 Jackal
    The next Integra to be released in march/april might come in "all black".
    May 2005
    That sound freat! Where did you get that news from?
    Quote Originally Posted by randan View Post
    From KS Customer Service. It is not confirmed. But should be expected as the non-integra version already ships in "all-black".
    Aug 2013
    Quote Originally Posted by dirtbiker View Post
    The post mech itself is pretty much flawless, but I won't buy another KS unless they fix their saddle clamp design. Going on three years of creaky riding
    Dec 2005
    After wasting a few hours trying to get my KS Lev Integra working, I gave up and put my externally routed KS Lev back on. I had found a video that showed the installation of the Integra and gave it a go, but it was a no-go. I then search around a little more and found the the pdf file on the KS site and realized that I had an old version of the Integra.
    I have just emailed KS to see what they will do. Hopefully they will fix my Integra post. I bought new as a take-off, so the post has not been used (would be hard to actually use the post as it does not work with the first gen actuation hardware on the bottom of the post).
    With any luck, I can go through the headache once again of trying to get the cable housing for the dropper post through the frame again. Wow that was fun, can't wait to do that again.
    Will post back once I know more.
    Cheers
    J
    May 2012
    Integra Service?
    Any of you guys with the Integra ever service it? With the LEV, there's a video on the KS site of how to break it down, clean it out, re-lube it with post paste, and re-assemble. Not seeing that for the Integra. I've serviced the cartridges on LEVs and Supernaturals and imagine that the Integra cartridge is the same but would like to know how to get to it. I'm mostly interested in this to keep my thread updated: http://forums.mtbr.com/all-mountain/...ld-899659.html
    I also plan to work on one of these soon and figured I'd check to see if any of you guys have opened the Integra to clean it and re-grease the guide bushings, etc.
    Thanks in advance!
    -Chris
  67. #67
    May 2012
    Nevermind. Figured it out. Super easy to open.
    -Chris
  68. #68
    Reputation: subydoo's Avatar
    Feb 2005
    Saw one of the Lev Integras in all black on a fully assembled bike yesterday. Think it was Giant at Go-Ride in Salt Lake City.
    Edit: It was Pivot bike...
    Quote Originally Posted by jarango View Post
  69. #69
    May 2005
    I want to purchase a LEV Integra as soon as they are available totally black. For instance I don't know if a 150 mm LEV would fit my frame. The KS site says the 150 mm version ist 442 mm long - from where to where do they measure the post? Is the silver thing that protrudes at the bottom of the post included in these 442 mm? Thanks in advance.
  70. #70
    Feb 2005
    I spoke to Fodster over on Pinkbike, great source for Lev posts. He said the all black Integra is the Lev Integra Ti, and its available but he does not carry it.
    Anybody know where to get the all black 150mm Lev Integra Ti? I have the Lev Ti, but new frame has internal routing only....
  71. #71
    Reputation: sohnice's Avatar
    Quote Originally Posted by subydoo View Post
    Kind Shock LEV Integra 150 Vario-Seatpost | low prices
  72. #72
    Feb 2005
    Nice, I created my own. Bought a 150mm Lev Integra, took my 150mm Lev Ti apart and swapped the stanchion and bushings over.
    My new frame is 30.9 and old was 31.6 so needed to buy it anyway. Now I have a 31.6 lev non ti for sale...
    Jul 2013
    Hello ppl!
    Today i've recieved new Lev.
    I wait so long for new 2015 models and was really disappointed, when realize, that there's no Lev Ti Black 30.9 150 Integra!
    I've buyed regular Lev and gonna convert it to integra by myself.
    Anyone knows, is it possible to buy new Integras actuator with lever?KS LEV Integra??? Where is it?-cdab4f02-2d3e-eafd-a308-adabbc382ddf.jpg
  74. #74
    May 2012
    I think you're best bet is to do what subydoo did above: buy the regular LEV in black and the Integra that fits your bike, then switch the stanchions so that your Integra is black (I'm assuming that's what your goal is). Then you can sell the standard LEV to get some money back.
    You'll run into some issues trying to swap just the actuator since the threads for the standard LEV end cap are on the external surface of the black casing as opposed to the Integra's actuator threads which are located inside the black casing.
    -Chris
  75. #75
    Jul 2013
    I'm affraid it's not possible. Because of price - no one here needs dropper posts at all.
    So i justy need that actuator, i can solve any technical problem - i have many tools and machines\equipment.
  76. #76
    May 2012
    Yeah, buying 2 LEVs is definitely a costly way to do it. If you find the actuator for sale by itself, let us know where you got it and post up some pictures of the conversion when you're done.
    -Chris
  77. #77
    Jul 2013
    Shure!
  78. #78
    Feb 2015
    do not be put off more directly tested guys
  79. #79
    Be warned. I bought this from the link above and received it Monday. But it is NOT the all-black version.
    I have been trying to contact them to get a refund or an exchange but it's been two days without a response. Maybe because my email isn't in German...
  80. #80
    Quote Originally Posted by greddyvox View Post
    Dang, they changed their picture back to 2014 model. Did you screenshot their site picture? Hope you get your refund asap.
  81. #81
    The product pic was still all black on Tuesday. Guess this means they saw my email! But they still haven't responded... Fingers crossed
  82. #82
    Colorado Yeti Rider!
    Reputation: g1701gst's Avatar
    Nov 2008
    New Black 150mm Integra
    Brian lopes is running a new all black 150mm KS LEV Integra with new thumb lever in his bike:
    Pro Bike Check: Brian Lopes' Intense Spider 27.5 - Pro Bike Check: Brian Lopes' Intense Spider 27.5 - Mountain Biking Pictures - Vital MTB
    Hopefully that means it will be available soon. My guess is it will officially be announced around Sea Otter.
  83. #83
    May 2012
    The lever has been available for quite a while if you haven't seen it before. It's the KS Southpaw and it's available at Arts Cyclery last I checked. I've been running one for a while now and love it.
    -Chris
  84. #84
    Jul 2013
    I've owned it for half year!
  85. #85
    Nov 2008
    I thought I had seen the lever before but I wasn't sure. It also isnt shown on their site with any of the LEV models. I found it under accessories: SOUTHPAW ? KS | Get Down and Dirty Good to hear you like it Chris, it makes sense for 1x bikes. I still like the ODI lock-on compatible lever but dont like having to run the cable over/around my brake lever. I wonder if the Southpaw. will be included or be and stay an optional accessory only.
  86. #86
    FM
    FM is offline
    Reputation: FM's Avatar
    Apr 2003
    I have a southpaw and I'm not much of a fan.
    #1 due to the price. Introduced at $60+ which was ridiculous. Now I'm seeing them at $45 which is still about 2x what it's worth IMO.
    #2 the split clamp sucks. Requires a ridiculous about of torque on a 4mm bolt to prevent slipping. Like double the torque I run on my stem or brake levers.
    Otherwise it's good- ergonomics are good- but I wouldn't buy again.
    On my other bike, I did convert a SRAM XO shifter, and that is awesome. Used front shifters are practically free. The ergonomics are perfect and symmetrical with my rear shifter. Works with matchmaker. And has a return spring and barrel adjuster. The conversation took about 3 minutes with a vice and bench grinder.
    details on the arts cyclery blog
  87. #87
    KONA BIKES | 2015 BIKES | ENDURO | PROCESS 153
    Kona is packaging with new 2015 process.
  88. #88
    Folks,
    Does anyone happen to know the measurement on a 150mm Integra, from the bottom of the collar to the seat rails, fully extended? I'm trying to find out if I can make a 150mm work or not.
    I've done some digging but all I can find is a measurement for a 150mm Lev, and I'm not sure how old that data is, and/or if it would be the same for the Integra.
  89. #89
    Feb 2006
    Rode my brand new LEV Integra 150 about two miles, dropped the seat a few times, then put the bike away for a few days. Now the seat won't drop at all. Lever and actuator appear to be working, but the seat won't move at all. Played with cable tension, but didn't make any difference. It was rather cold when I rode (20s F), but that shouldn't break the post.
  90. #90
    May 2012
    If the seat won't drop, it's not usually the typical seal issue that causes air and oil to mix. I'd pull the post and try manually activating it with the cable detached and see what happens. Let us know.
    -Chris
  91. #91
    Feb 2006
    Quote Originally Posted by cakelly4 View Post
    -Chris
    Thanks for the advice. I just dropped it off at the LBS, so I'll see what they say.
    Was planning to drive five hours to get away from the snow and do my first real ride on the bike (HD3) this weekend. Might have to swap in a rigid post for the maiden voyage.
  92. #92
    May 2012
    Bummer. Good luck. Let us know what they find.
    -Chris
  93. #93
    Feb 2006
    -Chris
    I guess I'm just crazy. My friend/mechanic pulled the seatpost out, took a look, adjusted cable tension, and now it works again. I swear I did the same thing and couldn't get the post to move. Hopefully it will keep working now...
  94. #94
    Feb 2006
    Quote Originally Posted by rscecil007 View Post
    Folks,
    Did you get an answer on this? I could measure mine tonight. Must be about 8".
  95. #95
    Quote Originally Posted by blizzard_mk View Post
    I went by the description on Art's, they said it was 200mm IIRC. Mine's on it's way, know for sure on Friday.
  96. #96
    Jul 2013
    I made the mistake of buying an Integra with the old actuator--no wonder the PO had only used it a couple of times. lol.
    Has anyone had recent experience with KS doing the upgraded actuator?
    Thx.
  97. #97
    Yep, 200mm. Fits with about 3/4" to spare on my bike. I wasn't sure if I was going to have to return it for a 125 but miraculously the ruler didn't lie. Now for the snow to finish melting and then the mud to dry...
  98. #98
    So anyone with any news on an all black Lev integra? I was in my LBS the other day and saw a couple Kona Process models equipped with them. Looked really good, dunno why it's not available aftermarket. A LEV Integra Ti would be cool too.
  99. #99
    Quote Originally Posted by sohnice View Post
    Just to update, Action Sports did give me a full refund - including the EUR50 shipping! Excellent service (if slightly slow but that might be because of language differences).
  100. #100
    Nice, looks like the Germans live up to their name.
  1. Kind Shock LEV integra
    By zhengki in forum All Mountain
    Last Post: 06-04-2013, 03:50 AM
  2. Replies: 3
    Last Post: 11-18-2011, 04:15 PM
  3. Speedway and Integra
    By Trek223 in forum Cars and Bike Racks
    Last Post: 02-18-2011, 12:09 AM
  4. Stolen! Specialized Enduro and Acura Integra - Everett
    By pressingonward in forum Washington
    Last Post: 12-30-2010, 09:56 AM
Members who have read this thread: 7
