Results 1 to 6 of 6
    Feb 2018
    KS Lev Integra remote swap HELP!!!!
    So my DB release 2 came with a KS Lev Integra dropper which I absolutely love. I donít love the remote for it, and ended up buying a replacement. I purchased the KS southpaw remote which is a shifter style remote.
    I CANNOT find solid instructions on how to replace the standard remote with the southpaw remote, and coming from the school of if it ainít broke, donít fix it.... Iím terrified of breaking something if I start disassembling without guidance.
    does anyone know where I can get a tutorial for this?
    Jul 2015
    If you go into Google and type "KS Lev Southpaw Installation" the first things to pop up are installation vidoes...
    Sent from my XT1585 using Tapatalk
    Feb 2018
    Ive watched that video. Itís terrible.
    #THELEGEND
    Reputation: Guy.Ford's Avatar
    Assuming you are mechanically inclined enough that you can bolt the remote to your handlebars, this is the only thing you need to know. JK I'm sure you are.
    https://www.youtube.com/watch?v=9368c13RE0M
    An FYI, the cable guide that KS uses to set the barrel leaves 18mm of cable, so just measure up 18mm from the cable housing and install the barrel. Other than that it's not rocket science.
    If you still not feeling it, I recommend taking it to a shop to assist.
    Good luck (I have faith in you).
    #THELEGEND
    2016 RSD Mayor
    2018 Diamondback Release 5C
    2017 Diamondback Haanjo Trail
    I suggest downloading the owner's manual from the KS site in the support section (KS | Support). You have to scroll down below the spec sheets section. Just follow the instructions for the regular remote except you'll be substituting the Southpaw remote, but the manual gives you the correct length to cut he cable relative to the housing.
    #THELEGEND
    From the manual - 18mm, like I said.
  1. KS Lev Integra DX vs. KS Lev Integra?
    By Bosko in forum Components
    Last Post: 05-08-2015, 05:07 AM
  2. Help! KS Lev Integra Seatpost Remote Problem
    By mattangeles in forum Shocks and Suspension
    Last Post: 04-28-2015, 05:46 AM
  3. Replies: 4
    Last Post: 03-25-2015, 06:09 PM
  4. KS Lev or KS Lev Integra for Spider Comp
    By Alpenglow in forum Intense
    Last Post: 03-17-2015, 01:50 PM
  5. Advice on KS Lev, KS Lev Ti vs KS Lev Integra on Mach 6
    By Jordan Wong in forum Pivot Cycles
    Last Post: 11-08-2014, 07:07 AM
Members who have read this thread: 20
