Page 7 of 12 FirstFirst ... 34567891011 ... LastLast
Results 301 to 350 of 590
  1. #301
    Reputation: TwoHeadsBrewing's Avatar
    Thanks Hokidachi! Looks like it should be about 125mm plus another 40mm or so, is that correct?
    "Got everything you need?"
  2. #302
    bike rider
    Reputation: Lelandjt's Avatar
    Quote Originally Posted by TwoHeadsBrewing View Post
    I just want to make sure it's going to fit in my frame.
    I'm 5'8" and ride a medium SC Blur LT. Anyone else with a similar size bike using the 125mm LEV? Thanks!
    When your seat is at full roadie/climbing height how far is it from the top of the frame's seat tube to the saddle rails?
    How much lower than that is the lowest you ever put it?
    How much seatpost length can your frame swallow before it hits a stop?
    Keep the Country country.
  3. #303
    Reputation: Hokidachi's Avatar
    Feb 2012
    I just measured my setup, here you go:
  4. #304
    Perfect, thanks! Looks like I can fit a 125mm in there...although not sure I need it. Most of the time I only drop it 1-2" into a trail riding type position, so 100mm would be sufficient.
    Anyone running the clamp on ODI grips? I've got Rogues right now and was going to do the integrated mount thing.
  5. #305
    Feb 2012
    I do use the clamp with my ODI Ruffian. It's great!
    I also added a brake noodle to bend the housing/cable. Someone else had this noodle idea, pretty cool and convenient.
    Hoki
  6. #306
    Quote Originally Posted by Lelandjt View Post
    1. 7.5" from saddle rails to seatpost collar. 6.5" from saddle clamp to collar.
    2. Maybe 4" down from there on long downhill sections...not slammed all the way to the collar.
    3. It's a continuous tube on my bike, so LOTS of room.
    From the pic Hoki posted, I've got enough to run the 125mm post with maybe 5mm to spare. From collar to bottom of the saddle clamp it measures 165mm, and based on that picture I'd need around 160mm. I'm thinking that is a little too close for comfort, and I'll opt for the 100mm version. Still overkill for most of my riding where I'll put it maybe 2" down.
  7. #307
    Just as an update, here's my installation on the KS LEV 100mm. I probably could have gone 125mm, but it would have been really close. I did a good ride today, and 4" is enough travel to get it well out of the way on the downhills.
    Cable routing on the Blur. Clean and out of the way.
    Lever mounted on ODI Ruffian grips...great solution I must say.
  8. #308
    Reputation: broccoli rob's Avatar
    Just to check. If my seat is 9in (228mm) fully extended and 5in(127mm) lowered. I would need a 125mm post? Thanks
  9. #309
    Quote Originally Posted by broccoli rob View Post
    Check the pictures above. If your post is 228mm between the seatpost collar and your saddle clamp, you have enough room for a 150mm. Adding 150mm travel + ~40mm for the inner/outer tubes junction, that's just 190mm.
  10. #310
    ptd
    ptd is offline
    Oct 2012
    I've been following the 150 choice closely, there was another similar thread here:
    http://forums.mtbr.com/all-mountain/...ed-837468.html
    From what I can tell, critical measurement of the 150 LEV is bottom of LEV seatpost collar to the saddle rails (when seatpost extended fully).
    This should be compared to your existing top of seatpost clamp to saddle rails at pedalling height.
    If the LEV measurement is more than existing measurement, your fine.
    The other thread determined the 125 LEV measurement is 180mm, so adding 25mm for the 150 LEV, the minimum existing top of seatpost clamp to saddle rails should be 205mm.
    The only note was if your seatpost clamp has a larger outside diameter, the cable extension from the LEV cable clamp might foul, so you'd need an extra 20mm or so height..
  11. #311
    Feb 2013
    I found dimensions for KS LEV:
  12. #312
    ptd
    ptd is offline
    Oct 2012
    Quote Originally Posted by limonko View Post
    legend!
  13. #313
    Glad i checked this. I guess i do need the 150mm.
  14. #314
    Sep 2012
    Re: KS LEV 125mm. Am I the first to have?
    First ride with lev installed and love it. Do you guys clean the post with something special? I use brunox deo on shock and fork, do you think it would be wise to use it on lev as well?
    Sent from my GT-I9100 using Tapatalk 2
  15. #315
    Anybody know what the weight difference is between the 150mm and 125mm?
  16. #316
    Nov 2007
    KS Lev 150
    KS Lev 150 for a large Ibis HD
    Attached Thumbnails Attached Thumbnails KS LEV 125mm. Am I the first to have?-image.jpg
  17. #317
    Dec 2005
    Not the first or the last to pick up a Lev
    I just got my 125mm Lev in the mail yesterday. Took about 10 minutes to set it up at home. I did do the measurements with my old KS i900 (stem to seat tip, and bb to seat rail) so I could install the Lev at approximately the same.
    When I had my i900 setup on my trail bike, that does get used to ride on the shore, I would fully use the 5" drop plus some. To get full extension for the climb, I will sometimes lift the post about 3/4" a then drop to as low as the i900 could go before bottom out in the frame. The extra drop was helpful for the really steep sections to get low and behind the seat. I have setup the Lev so that at full extension it is perfect for climbing. I mounted the cable access to the side so if required I can still drop the post in the seat tube 1/2 - 3/4 of an inch without messing up any of the cable routing.
    Haven't had it out on the trail yet, but this thing feels ultra smooth. I will be reusing the i900 on my freeride bike as I typically don't raise and lower the seat as much as when I am on the trail bike. My i900 is the level mount with no remote. It works, just need to be a little more pro-active in getting the seat dropped and get the hand back on the bars.
    I only hope the Lev works as well and for at least as long as the i900.
  18. #318
    Sep 2012
    what's better when not in use/transport-fully extended or pushed down?
  19. #319
    bike rider
    Quote Originally Posted by rzat View Post
    Extended. Less pressure and no chance of it getting pulled up and getting air in the oil.
  20. #320
    I am Specialized
    Reputation: tp806's Avatar
    Nov 2008
    Always extended, no pressure on the whole system.
  21. #321
    Sep 2012
    That makes sense, thanks a lot.
  22. #322
    Oct 2012
    Just ordered the 125 mm off bike bling for my new ASR-5....First foray into dropper posts and I'm stoked!
  23. #323
    Shipped from KS compressed. So will be stocked compressed.
  24. #324
    Feb 2012
    Quote Originally Posted by Mark N View Post
    They likely ship them compressed to save on packaging. I have my LEV always extended when not in use.
  25. #325
    MattSavage
    Reputation: mattsavage's Avatar
    Sep 2003
    Extended, unless on the rooftop carrier (anything to help reduce wind resistance and keep the bugs off the shaft).
    Stored upside down, just like a fork.
    "I wrote a hit play! What have you ever done?!"
    Have Ashtray, Will Travel....
  26. #326
    May 2010
    Has anyone ever lost the little red cable junction box cover lost mine on a ride today and can you buy them?
  27. #327
    Call KS, you don't want that area to get gunked up.
    Installed and rode my new one today, it is great. I am super happy with it.
  28. #328
    Reputation: JPBakerIII's Avatar
    Mar 2012
    Only time I have read about that cover coming off, they had the hook facing the wrong way. Make sure the hook is facing out or it will just happen again. Make sure your new cover has an O-ring on it.
    1990 Schwinn Sierra MOS
    2011 Santa Cruz Chameleon
    2012 Cannondale Claymore 2
  29. #329
    Oct 2012
    I have adjusted the hook to face out but it still popping the red cap off..... Anyone have similar issue?
  30. #330
    Oct 2012
    OK fixed! For those that have similar issue with red cap popping out even with the hook faced out.
    You need to check if the steel cable is protruding out of the hole in the hook piece. If so, you need to adjust the steel cable so it sit flat to the hole.
  31. #331
    I can't remember the exact length, but the instructions give you a measurement (like 21mm?) to cut the housing so you have the correct amount of cable sticking out. That way, the cable doesn't interfere with the hook.
    For any new buyers I highly recommend watching this video on installation prior to doing it yourself. I did, and it made following the directions a whole lot easier. It's probably one of the best and most thorough videos I've seen from a manufacturer.
    <iframe width="560" height="315" src="http://www.youtube.com/embed/XUXcLchjFV4" frameborder="0" allowfullscreen></iframe>
  32. #332
    Mar 2013
    bad ass
  33. #333
    Helmetless Crasher
    Reputation: Stumpjumpy's Avatar
    Just did a week long AM/DH mtb trip with the 125. This was my first use of the post and it performed flawlessly. Could not have ridden these trails w/out a dropper I dont think. I was using it constantly.
    I noticed that the little plastic barb/ferrule that goes on the end of the cable housing that enters the junction box is wearing extremely fast, though. Looks pretty knackered - not sure why . . .
    '95 M2 StumpJumper FS
    '11 Cannondale RZ 120-two
  34. #334
    May 2005
    Quote Originally Posted by anvil_den View Post
    Never liked the lock ring remote. Simply bad ergonomics needing to remove finger from brakes to activate it. Hybridize my LEV with a remote from an old Joplin instead.
    anvil_den: do you still use the Joplin remote with your KS LEV? If so, how do you like it so far? I am thinking of switching as well to the Joplin remote as I don't like the KS remote that much.
  35. #335
    I installed my 150mm LEV last week, so have three rides on it now. It went on easily and has been flawless so far. The remote is perfect, it could not be designed better I don't think. I set it on the left side right above the shifter and it becomes second nature there very quickly. The post operates perfectly so far every single time, and the 150mm of travel is nice and I am glad I got that version. The action really is smooth up and down, and the set up is very clean with the non moving cable. I think the only hit on it is that there is some slight movement with the saddle. There is no way you could feel it riding, so I don't really know that it is a true downside, but it is there. I have heard that with every dropper out there, so maybe it is just the nature of the beast. All in all I am very happy so far with the post and it definitely makes downhills faster and more fun.
  36. #336
    MattSavage
    Sep 2003
    "Never liked the lock ring remote. Simply bad ergonomics needing to remove finger from brakes to activate it. Hybridize my LEV with a remote from an old Joplin instead."
    Why would anyone have to remove their finger from the brake if it's designed to be used with the thumb...?
  37. #337
    Reputation: hrdude's Avatar
    Feb 2006
    Bummer, my Lev 125 died today. After 9 months of trouble free use it suddenly stopped working. Trigger & external cable are functioning fine but post will not move. Appears internal cable broke. Bummed because I finally got my seat position adjusted perfectly, uggh.
  38. #338
    @hrdude - Sucks! Be sure to post back when you figure out what happened, and how KS has responded. I just got my KS a couple months ago, and am interested to hear how their customer service and warranty process is.
  39. #339
    Feb 2006
    After removing & inspecting, the internal cable wore out and broke. The internal cable is made from kevlar or some type of fiber string material. Friction from moving the post up and down wore through the fibers until it broke. Unless they've recently changed the cable material it looks like this could be a regular yearly issue. Other than this, it has been a great dropper post.
    KS was quick to provide an RMA number & I've shipped the post back for warranty repair.
  40. #340
    used to be RipRoar
    Reputation: TraxFactory's Avatar
    Sep 1999
    Quote Originally Posted by hrdude View Post
    When installing mine that was what I was thinking...how long is that internal cable going to last. Awesome post!, but that cable could be a flaw.
  41. #341
    Mar 2012
    Reminds me a little bit of how the older cars used to have a timing belt that needed to be serviced and finally somebody got the bright idea to use a chain instead of a belt which made the 60,000 mile timing belt change a thing of the past. When will KS use a different material for their internal cable that will eliminate this type of problem? I also wonder if extreme cold weather would make the kevlar wear faster?
  42. #342
    inexperienced at large
    I noticed he didn't install the barrel adjuster in the video, is it necessary?
  43. #343
    Quote Originally Posted by ehigh View Post
    You don't need the barrel adjuster, but cables do stretch over time. That's why it's a good idea to install it, so you can tighten it up easily when the cable stretches out.
  44. #344
    There's another video that's a couple of minutes longer that includes the adjuster video installation (@9:20) but is otherwise the same: https://www.youtube.com/watch?v=XUXcLchjFV4. The guy says it's optional, but I found it useful.
  45. #345
    AFI
    AFI is offline
    Reputation: AFI's Avatar
    I didn't install one and haven't had any issues. Going on about 6 months now. I did my best to attach at tightly as possible.
  46. #346
    Reputation: dklopp's Avatar
    Quote Originally Posted by AFI View Post
    I am glad I installed mine. It gives you some on-the-fly adjustment for the lever engagement point and to compensate for a little bit of cable stretch. Plus, it means less chance of damaging that small, fragile aluminum hook - I am most worried about this part of the post and am considering trying to get a spare...
  47. #347
    Apr 2013
    Does anyone know if the diameter of the inner post of the LEV and reverb is the same? I'm trying to determine if the travel limiter clamp from the reverb will fit on the LEV...
  48. #348
    Reputation: da peach's Avatar
    Does anyone else have a problem with having to unweight their seat, then hit the remote, then weight it again to get the post to go down?
    I just installed my 125 and went for a ride and it wouldn't go down unless I did a little bum hop. That can't be normal...
  49. #349
    Fixed. Just needed to take some slack out with the adjuster barrel. Flipped the hook around too. Success.
  50. #350
    Helmetless Crasher
    Quote Originally Posted by Ronstar View Post
    I almost lost mine. The little o-ring tore, creating a loose fit and the cover was hanging out of the box.
    I don't like the box/cover/o-ring design, at all. Way too cutesie/fussy for a part that potentially gets blasted by dirt, rocks, water and debris.
    Seems like a small allen screw (or 2) to hold the cover on would have been tidy and secure. The box/cover O-ring should sit captive in a ridge inside the box, like a gasket, completely eliminating the possibility of pinching/twisting the o-ring during removal/replacement of the cover.
    The plastic barbed ferule that goes into the box should be made of aluminum - mine has disintegrated and cracked in short order . . .
    My post still functions beautifully, however . . .
