Page 4 of 6 FirstFirst 123456 LastLast
Results 301 to 400 of 590
  1. #301
    Reputation: TwoHeadsBrewing's Avatar
    Thanks Hokidachi! Looks like it should be about 125mm plus another 40mm or so, is that correct?
    "Got everything you need?"
  2. #302
    bike rider
    Reputation: Lelandjt's Avatar
    Quote Originally Posted by TwoHeadsBrewing View Post
    I just want to make sure it's going to fit in my frame.
    I'm 5'8" and ride a medium SC Blur LT. Anyone else with a similar size bike using the 125mm LEV? Thanks!
    When your seat is at full roadie/climbing height how far is it from the top of the frame's seat tube to the saddle rails?
    How much lower than that is the lowest you ever put it?
    How much seatpost length can your frame swallow before it hits a stop?
    Keep the Country country.
  3. #303
    Reputation: Hokidachi's Avatar
    Feb 2012
    I just measured my setup, here you go:
  4. #304
    Perfect, thanks! Looks like I can fit a 125mm in there...although not sure I need it. Most of the time I only drop it 1-2" into a trail riding type position, so 100mm would be sufficient.
    Anyone running the clamp on ODI grips? I've got Rogues right now and was going to do the integrated mount thing.
  5. #305
    Feb 2012
    I do use the clamp with my ODI Ruffian. It's great!
    I also added a brake noodle to bend the housing/cable. Someone else had this noodle idea, pretty cool and convenient.
    Hoki
  6. #306
    Quote Originally Posted by Lelandjt View Post
    1. 7.5" from saddle rails to seatpost collar. 6.5" from saddle clamp to collar.
    2. Maybe 4" down from there on long downhill sections...not slammed all the way to the collar.
    3. It's a continuous tube on my bike, so LOTS of room.
    From the pic Hoki posted, I've got enough to run the 125mm post with maybe 5mm to spare. From collar to bottom of the saddle clamp it measures 165mm, and based on that picture I'd need around 160mm. I'm thinking that is a little too close for comfort, and I'll opt for the 100mm version. Still overkill for most of my riding where I'll put it maybe 2" down.
  7. #307
    Just as an update, here's my installation on the KS LEV 100mm. I probably could have gone 125mm, but it would have been really close. I did a good ride today, and 4" is enough travel to get it well out of the way on the downhills.
    Cable routing on the Blur. Clean and out of the way.
    Lever mounted on ODI Ruffian grips...great solution I must say.
  8. #308
    Reputation: broccoli rob's Avatar
    Just to check. If my seat is 9in (228mm) fully extended and 5in(127mm) lowered. I would need a 125mm post? Thanks
  9. #309
    Quote Originally Posted by broccoli rob View Post
    Check the pictures above. If your post is 228mm between the seatpost collar and your saddle clamp, you have enough room for a 150mm. Adding 150mm travel + ~40mm for the inner/outer tubes junction, that's just 190mm.
  10. #310
    ptd
    ptd is offline
    Oct 2012
    I've been following the 150 choice closely, there was another similar thread here:
    http://forums.mtbr.com/all-mountain/...ed-837468.html
    From what I can tell, critical measurement of the 150 LEV is bottom of LEV seatpost collar to the saddle rails (when seatpost extended fully).
    This should be compared to your existing top of seatpost clamp to saddle rails at pedalling height.
    If the LEV measurement is more than existing measurement, your fine.
    The other thread determined the 125 LEV measurement is 180mm, so adding 25mm for the 150 LEV, the minimum existing top of seatpost clamp to saddle rails should be 205mm.
    The only note was if your seatpost clamp has a larger outside diameter, the cable extension from the LEV cable clamp might foul, so you'd need an extra 20mm or so height..
  11. #311
    Feb 2013
    I found dimensions for KS LEV:
  12. #312
    ptd
    ptd is offline
    Oct 2012
    Quote Originally Posted by limonko View Post
    legend!
  13. #313
    Glad i checked this. I guess i do need the 150mm.
  14. #314
    Sep 2012
    Re: KS LEV 125mm. Am I the first to have?
    First ride with lev installed and love it. Do you guys clean the post with something special? I use brunox deo on shock and fork, do you think it would be wise to use it on lev as well?
    Sent from my GT-I9100 using Tapatalk 2
  15. #315
    Anybody know what the weight difference is between the 150mm and 125mm?
  16. #316
    Nov 2007
    KS Lev 150
    KS Lev 150 for a large Ibis HD
    Attached Thumbnails Attached Thumbnails KS LEV 125mm. Am I the first to have?-image.jpg
  17. #317
    Dec 2005
    Not the first or the last to pick up a Lev
    I just got my 125mm Lev in the mail yesterday. Took about 10 minutes to set it up at home. I did do the measurements with my old KS i900 (stem to seat tip, and bb to seat rail) so I could install the Lev at approximately the same.
    When I had my i900 setup on my trail bike, that does get used to ride on the shore, I would fully use the 5" drop plus some. To get full extension for the climb, I will sometimes lift the post about 3/4" a then drop to as low as the i900 could go before bottom out in the frame. The extra drop was helpful for the really steep sections to get low and behind the seat. I have setup the Lev so that at full extension it is perfect for climbing. I mounted the cable access to the side so if required I can still drop the post in the seat tube 1/2 - 3/4 of an inch without messing up any of the cable routing.
    Haven't had it out on the trail yet, but this thing feels ultra smooth. I will be reusing the i900 on my freeride bike as I typically don't raise and lower the seat as much as when I am on the trail bike. My i900 is the level mount with no remote. It works, just need to be a little more pro-active in getting the seat dropped and get the hand back on the bars.
    I only hope the Lev works as well and for at least as long as the i900.
  18. #318
    Sep 2012
    what's better when not in use/transport-fully extended or pushed down?
  19. #319
    bike rider
    Quote Originally Posted by rzat View Post
    Extended. Less pressure and no chance of it getting pulled up and getting air in the oil.
  20. #320
    I am a Nomad
    Reputation: tp806's Avatar
    Nov 2008
    Always extended, no pressure on the whole system.
  21. #321
    Sep 2012
    That makes sense, thanks a lot.
  22. #322
    Oct 2012
    Just ordered the 125 mm off bike bling for my new ASR-5....First foray into dropper posts and I'm stoked!
  23. #323
    Shipped from KS compressed. So will be stocked compressed.
  24. #324
    Feb 2012
    Quote Originally Posted by Mark N View Post
    They likely ship them compressed to save on packaging. I have my LEV always extended when not in use.
  25. #325
    MattSavage
    Reputation: mattsavage's Avatar
    Sep 2003
    Extended, unless on the rooftop carrier (anything to help reduce wind resistance and keep the bugs off the shaft).
    Stored upside down, just like a fork.
    "I wrote a hit play! What have you ever done?!"
    Have Ashtray, Will Travel....
  26. #326
    May 2010
    Has anyone ever lost the little red cable junction box cover lost mine on a ride today and can you buy them?
  27. #327
    Call KS, you don't want that area to get gunked up.
    Installed and rode my new one today, it is great. I am super happy with it.
  28. #328
    Reputation: JPBakerIII's Avatar
    Mar 2012
    Only time I have read about that cover coming off, they had the hook facing the wrong way. Make sure the hook is facing out or it will just happen again. Make sure your new cover has an O-ring on it.
    1990 Schwinn Sierra MOS
    2011 Santa Cruz Chameleon
    2012 Cannondale Claymore 2
  29. #329
    Oct 2012
    I have adjusted the hook to face out but it still popping the red cap off..... Anyone have similar issue?
  30. #330
    Oct 2012
    OK fixed! For those that have similar issue with red cap popping out even with the hook faced out.
    You need to check if the steel cable is protruding out of the hole in the hook piece. If so, you need to adjust the steel cable so it sit flat to the hole.
  31. #331
    I can't remember the exact length, but the instructions give you a measurement (like 21mm?) to cut the housing so you have the correct amount of cable sticking out. That way, the cable doesn't interfere with the hook.
    For any new buyers I highly recommend watching this video on installation prior to doing it yourself. I did, and it made following the directions a whole lot easier. It's probably one of the best and most thorough videos I've seen from a manufacturer.
    <iframe width="560" height="315" src="http://www.youtube.com/embed/XUXcLchjFV4" frameborder="0" allowfullscreen></iframe>
  32. #332
    Mar 2013
    bad ass
  33. #333
    Helmetless Crasher
    Reputation: Stumpjumpy's Avatar
    Just did a week long AM/DH mtb trip with the 125. This was my first use of the post and it performed flawlessly. Could not have ridden these trails w/out a dropper I dont think. I was using it constantly.
    I noticed that the little plastic barb/ferrule that goes on the end of the cable housing that enters the junction box is wearing extremely fast, though. Looks pretty knackered - not sure why . . .
    '95 M2 StumpJumper FS
    '11 Cannondale RZ 120-two
  34. #334
    May 2005
    Quote Originally Posted by anvil_den View Post
    Never liked the lock ring remote. Simply bad ergonomics needing to remove finger from brakes to activate it. Hybridize my LEV with a remote from an old Joplin instead.
    anvil_den: do you still use the Joplin remote with your KS LEV? If so, how do you like it so far? I am thinking of switching as well to the Joplin remote as I don't like the KS remote that much.
  35. #335
    I installed my 150mm LEV last week, so have three rides on it now. It went on easily and has been flawless so far. The remote is perfect, it could not be designed better I don't think. I set it on the left side right above the shifter and it becomes second nature there very quickly. The post operates perfectly so far every single time, and the 150mm of travel is nice and I am glad I got that version. The action really is smooth up and down, and the set up is very clean with the non moving cable. I think the only hit on it is that there is some slight movement with the saddle. There is no way you could feel it riding, so I don't really know that it is a true downside, but it is there. I have heard that with every dropper out there, so maybe it is just the nature of the beast. All in all I am very happy so far with the post and it definitely makes downhills faster and more fun.
  36. #336
    MattSavage
    Sep 2003
    "Never liked the lock ring remote. Simply bad ergonomics needing to remove finger from brakes to activate it. Hybridize my LEV with a remote from an old Joplin instead."
    Why would anyone have to remove their finger from the brake if it's designed to be used with the thumb...?
  37. #337
    Reputation: hrdude's Avatar
    Feb 2006
    Bummer, my Lev 125 died today. After 9 months of trouble free use it suddenly stopped working. Trigger & external cable are functioning fine but post will not move. Appears internal cable broke. Bummed because I finally got my seat position adjusted perfectly, uggh.
  38. #338
    @hrdude - Sucks! Be sure to post back when you figure out what happened, and how KS has responded. I just got my KS a couple months ago, and am interested to hear how their customer service and warranty process is.
  39. #339
    Feb 2006
    After removing & inspecting, the internal cable wore out and broke. The internal cable is made from kevlar or some type of fiber string material. Friction from moving the post up and down wore through the fibers until it broke. Unless they've recently changed the cable material it looks like this could be a regular yearly issue. Other than this, it has been a great dropper post.
    KS was quick to provide an RMA number & I've shipped the post back for warranty repair.
  40. #340
    used to be RipRoar
    Reputation: TraxFactory's Avatar
    Sep 1999
    Quote Originally Posted by hrdude View Post
    When installing mine that was what I was thinking...how long is that internal cable going to last. Awesome post!, but that cable could be a flaw.
  41. #341
    Mar 2012
    Reminds me a little bit of how the older cars used to have a timing belt that needed to be serviced and finally somebody got the bright idea to use a chain instead of a belt which made the 60,000 mile timing belt change a thing of the past. When will KS use a different material for their internal cable that will eliminate this type of problem? I also wonder if extreme cold weather would make the kevlar wear faster?
  42. #342
    Banned
    I noticed he didn't install the barrel adjuster in the video, is it necessary?
  43. #343
    Quote Originally Posted by ehigh View Post
    You don't need the barrel adjuster, but cables do stretch over time. That's why it's a good idea to install it, so you can tighten it up easily when the cable stretches out.
  44. #344
    There's another video that's a couple of minutes longer that includes the adjuster video installation (@9:20) but is otherwise the same: https://www.youtube.com/watch?v=XUXcLchjFV4. The guy says it's optional, but I found it useful.
  45. #345
    AFI
    AFI is offline
    Reputation: AFI's Avatar
    I didn't install one and haven't had any issues. Going on about 6 months now. I did my best to attach at tightly as possible.
  46. #346
    Reputation: dklopp's Avatar
    Quote Originally Posted by AFI View Post
    I am glad I installed mine. It gives you some on-the-fly adjustment for the lever engagement point and to compensate for a little bit of cable stretch. Plus, it means less chance of damaging that small, fragile aluminum hook - I am most worried about this part of the post and am considering trying to get a spare...
  47. #347
    Apr 2013
    Does anyone know if the diameter of the inner post of the LEV and reverb is the same? I'm trying to determine if the travel limiter clamp from the reverb will fit on the LEV...
  48. #348
    Reputation: da peach's Avatar
    Does anyone else have a problem with having to unweight their seat, then hit the remote, then weight it again to get the post to go down?
    I just installed my 125 and went for a ride and it wouldn't go down unless I did a little bum hop. That can't be normal...
  49. #349
    Fixed. Just needed to take some slack out with the adjuster barrel. Flipped the hook around too. Success.
  50. #350
    Helmetless Crasher
    Quote Originally Posted by Ronstar View Post
    I almost lost mine. The little o-ring tore, creating a loose fit and the cover was hanging out of the box.
    I don't like the box/cover/o-ring design, at all. Way too cutesie/fussy for a part that potentially gets blasted by dirt, rocks, water and debris.
    Seems like a small allen screw (or 2) to hold the cover on would have been tidy and secure. The box/cover O-ring should sit captive in a ridge inside the box, like a gasket, completely eliminating the possibility of pinching/twisting the o-ring during removal/replacement of the cover.
    The plastic barbed ferule that goes into the box should be made of aluminum - mine has disintegrated and cracked in short order . . .
    My post still functions beautifully, however . . .
  51. #351
    MattSavage
    Sep 2003
    This is an amazing post!!!!
    That being said, I don't feel it performs any better than the i-series or supernatural. I guess, technically, it shouldn't.
    Hopefully the price will come down soon and the availability goes up! If I buy again, soon, I'll probably just get the Supernatural instead.
  52. #352
    Apr 2013
    Quote Originally Posted by djball View Post
    Does anyone know when the Lev Integra(stealth) version will be available?
    I didn't see this answered anywhere - Since I'm in the market and deciding between the LEV and the Reverb I emailed KS today about Integra aftermarket availability and was told "A few months."
  53. #353
    So...I figured out what that creaking noise was! I am an idiot, and the noise was rocks grinding around in my skull where my brain should be.
    But seriously, I just didn't have my torque wrench set correctly so the bolts weren't tight enough on the seat clamp. Properly torqued them and problem solved.
  54. #354
    My seat in climbing position is 130mm from the seat post collar. The 100mm version extends 157mm past the color when the post is set as far down as possible. Having it extend 27mm too high every time I release the post, would this be a deal breaker? Looking to get feedback from those who have it, before I pull the trigger and order one. Anyone else find themselves in this situation?
    Thanks,
  55. #355
    Quote Originally Posted by NW-Rider View Post
    Thanks,
    Check this image from KS and then measure from seatpost collar to saddle rails. You basically need to add travel (100mm) + post head (22mm) + cable/collar (35mm), and compare that to your own measurement. I've included a pic of my 100mm travel post below, with a total height collar to rails of 185mm.
    Old seatpost, ~185mm from collar to rails:
  56. #356
    Reputation: Jongalt26's Avatar
    Jan 2013
    Thanks,
    You'll be able to stop the seatpost wherever you want. The only time the seatpost would be fully extended, in your case, is if you inadvertantly press the lever when you aren't above the seat to stop it. Plus 27mm is only an inch so it should be an easy recovery even if the post becomed fully extended while you're riding.
    The only downfall is that you'll just have to be over the seat while you extend the post.
    j
  57. #357
    MattSavage
    Sep 2003
    deal breaker...
    I'd get the 300mm Supernatural. It functions equally as well and you wont have to hunt for the proper seat height.
  58. #358
    Helmetless Crasher
    May wanna try running a simple/thin seatpost collar/clamp that allows the LEV to be lowered maximally, ie the clamp and the LEV junction box do not make contact when the LEV is pushed all the way into the seat tube. This would buy you another 24mm.
  59. #359
    Nov 2012
    Supernatural seatpost rail holder is flawed. I have a friend who snaps the bolts from time to time. Last time was yesterday and luckily he got some spare bolts.
    Bolts are on left and right, working in a bad mechanical way (shear). It was quality steel bolts (not even stainless which are worse). Even using loctite did not prevent it.
    No problem with the LEV (I have one), the bolts are front and behind, this way no shear problem.
  60. #360
    MattSavage
    Sep 2003
    Quote Originally Posted by Mac_Aravan View Post
    I have 3 supernaturals. Never had a problem, not a creak, not a groan. And I'm a fatty. I've never heard of bolts breaking, if that was really a systemic problem, someone would've posted it here at some point in the last 3 years...
  61. #361
    Mar 2012
    Thanks,
    Why don't you raise your current seat post 27mm and ride around to see if you will get used to it? My legs stretch after I ride for a while so my seat post seems like it is a little too high when I start a ride but about 20 minutes in, the seat post height is perfect.
  62. #362
    Reputation: anvil_den's Avatar
    Nov 2007
    Quote Originally Posted by randan View Post
    Yup. still on the Joplin remote. In fact I have another bike which I'm thinking of changing as well... but they don't sell them anymore. Closest to the old Joplin remote are the ones used in Xfusion HiLo adj posts...
  63. #363
    Reputation: fire_strom's Avatar
    Any difference in 2013 vs 2012 besides color? Which is which?
    G
    KS LEV 125mm. Am I the first to have?-%24t2ec16f-0e9s37fbmobrv0fgu-qq%7E%7E60_57.jpg
  64. #364
    www.derbyrims.com
    Reputation: derby's Avatar
    The upper picture is how my KS LEV 150 looks, bought new in late March 2013.
  65. #365
    Thanks. I wonder if the listings and stores that show the silver one are selling old stock or if they just haven't updated their photos. I'll call KS and post if I hear.
    G
  66. #366
    Mar 2012
    I have two KS LEV's, a 125 and a 100. The 125 was bought at the end of 2012 from pricepoint and looks exactly like the top photo. The 100 was bought a few months ago from bikebling and looks similar to the top photo except it has a different collar. The collar on the 100 is smoother, but has LEV printed on it. Everything else is the same as the top photo.
    So far, they both work flawlessly.
  67. #367
    bike rider
    QBP and BTi are still out of stock of the 150mm. This is silly. I've been trying to get one for over a year.
  68. #368
    A few questions for those who have had a LEV for a while:
    -Is there any actual solution to the problem of the seat slipping? Mine creaks like crazy and I have to re-tighten multiple times per ride. I recall the install video using carbon paste on the nuts, so maybe I'll give that a try.
    -Does anyone have the size of the cover O-ring? Mine, like everyone else's has torn.
    -Mine was always challenging to lower (I'd have to pretty much bounce on it) and now it's stuck up (used it maybe half a dozen rides). Is there anything to try prior to following the service instructions/sending back to K&S?
    -It would return to full extension fine, unless I only lowered it a small amount, in which case it wouldn't go up at all. I made sure that the seatpost clamp was as loose as I could get away with but no change. Is this normal?
    It seems like a nice product and it gets great reviews, but so far I've had issues with almost every function of this thing (and it's a seatpost...there aren't many!). Hopefully I can get it sorted out, because it's great when it works.
  69. #369
    I don't know what QBP and BTi are, but why not order from someone who has them? I ordered from Bike Bling and paid $313 for the 150mm with their coupon code and it was in in less than a week.
  70. #370
    I used to have that problem, but I was not tightening the bolts to proper torque. If you're sure the setting is right on your torque wrench, maybe try someone else's or the LBS.
    I've never had a problem with the O-ring or the cover, so not "everyone" has this problem. In fact, after I got the cable cut to the right length, there's been no reason to ever remove it?
    Again, I've never had a problem with lowering the saddle. Just hit the lever and sit on the saddle. It sounds like some people had problems when a)they installed the hook backwards, b)tightened the post collar too much. If neither of these is the case, it sounds like the post needs to be sent back to KS as it is not functioning properly.
    Again, I'd say that if the installation of the hook is correct and seat post clamp is correct, it sounds like you got a bad post. It happens, so it may be time to talk to KS about an RMA.
  71. #371
    UniversalCycles.com has the 150mm in 31.6mm, but it looks like they are out of 30.9. That's where I ordered mine from with coupon code "VIP15" for 15% off, no tax, and free shipping.
  72. #372
    Thanks. O-ring was definitely my fault. I opened it after the seat stopped going down to make sure there was nothing obviously wrong and that the cable pull was sufficient to disengage the "lock". O-ring looks to be 1mm thick and 20mm ID if anyone else needs one.
    Seat slips all the way forward when tightened to spec and also when tightened about as much as I'm comfortable doing without fear of stripping threads etc.
    Hook is installed correctly (facing out) and post is clamped as gently as I can get away with without having it slide.
    Thanks for the suggestions, I'll probably be in contact with KS about an RMA.
  73. #373
    Helmetless Crasher
    I think perhaps you had the KS remote installed backwards or upside down. It is THUMB actuated, thus no need to remove any fingers from brake lever.
  74. #374
    Reputation: cmarshack's Avatar
    The LEV is the best post I have had to date (Several Joplins and a KS Supernatural) but my internal cable broke last week too. Off to KS USA for a quick fix. Lasted 8 months of solid use.
  75. #375
    Follow up to the picture question:
    I just spoke with Ron @ KS. The picture with the silver is an older promo/proto picture that is still floating around. They're all black now. The newer/current models come with a smooth collar. The knurled ones were the late 2012 early 2013 version. No internal differences.
    That's AFAIR.
    Just ordered a 100mm 30.9 from JensonUSA. Price matched and offset with a gift card (thanks sis). Still big $$$ but...Should be here Friday.
    -G
  76. #376
    Anybody know of any foam lock on grips that are compatible with ODI clamps so I can integrate the remote?
    -G
  77. #377
    Mar 2012
    Quote Originally Posted by ebarker9 View Post
    Check the hook to see if you have any of the wire sticking out. It is supposed to be flush. I installed one of mine and it acted screwy until I made sure the wire was flush. Mine only had a tiny bit sticking out and it had an effect on the operation of the post, so make sure you cut the wire to the correct length, and that it is flush in the hook.
  78. #378
    Nov 2007
    Quote Originally Posted by Stumpjumpy View Post
    FYI, I've had adjustable seatposts in all shapes and configurations.. Have mounted the KS lever both ways, that is you can push down (like how most install it) or push up when mounted in reverse. Thing is not everyone has long fingers and thumbs.
    I tend to grip to the end of bars with more levers more inboun using 1 finger-- so that kinda stretches the thumb more. To get the lever (conventional direction of installation) in a comfortable position enough to go with thumb will make the cable exit angle way too much upward. Messy and dorky looking up front as a result.
    To each his own. Anyway this hybrid with a Joplin remote on the underside works well in this particular case without front shift lever.
  79. #379
    Helmetless Crasher
    OK cool.
    But that's a matter of aesthetics not ergonomics.
  80. #380
    Apr 2013
    I solved that problem with the use of a 2 brake noodle. Looks clean and usable in both directions.
  81. #381
    Helmetless Crasher
    Mine pretty much looks like that without a noodle. I also located the barrel adjuster down by my shock mount for a cleaner look.
  82. #382
    Reputation: briangarson's Avatar
    I just upgraded to the Lev from the i900r. First ride of the season on the i900r and I blew the cartridge inside the post. It did well though, lasting me 2 full seasons with on average 3-4 rides per week. I used the post alot.
    I've done one ride with the new Lev and I have to say it has a better feel than my 900, it seems more responsive to the lever, and comes up / goes down a bit smoother.
    I'm mechanically challenged so it took me nearly 1.5 hours to install it on my bike.
  83. #383
    bike rider
    Quote Originally Posted by Haymarket View Post
    What's the coupon code? QBP & BTi are the main distributors that a bike shop would get a KS from but if I can't get one from my shop I'll go online.
  84. #384
    I got mine from pricepoint for cheap.
  85. #385
    15off300
  86. #386
    Nov 2007
    OK cool.
    If you bothered to read the rest, obviously ergonomics is the bigger factor. Seeing the setup of your bike I guess it boils down to that we do very different kind of riding. Can understand how your setup of the lever doesn't really bother you
  87. #387
    15off300
    That is the best deal I have seen in 2+ weeks of searching. Comes in under $300 delivered. If they have them in stock and you want one, do it. Beat my deal by ~$15. Seems like they're in short supply.
    I hope I even like dropper posts. I'm diving in on testimonials and the epiphany that wow, my seat really is in the way frequently.
    Thanks for all the input.
    -G
  88. #388
    bike rider
    15off300
    Thanks, that's a rediculous deal. Close to wholesale. I got 2 to replace the 5" Reverb and i950 on my FR & XC bikes. Anyone want a cheap Reverb or i950, 31.6?
  89. #389
    Helmetless Crasher
    Not trying to argue, but I read all of it. You said when you place the lever where it fits your ergonomics, you don't care for the aesthetics - which is fine. To each his own.
    But to claim that using the remote requires one to take fingers off of the brake lever is uh - odd, to say the least.
  90. #390
    Quote Originally Posted by fire_strom View Post
    -G
    As a natural skeptic of all things, not just dropper posts, I was in the same boat. I had doubts about the benefits, but figured I'd never know for sure until I got a good post and rode with it regularly. I can say that after a couple months, it's changed my riding for the better and I wouldn't want to ride without it, except on a purely tame gravel road or easy XC ride. There's a few reasons why I feel that it has improved my riding:
    1. Immediately faster times on the downhills. Not that I care too much about times, but that's just what the numbers showed with no other changes to the bike.
    2. I was running my normal seat about 1/2" too low with the fixed post. I think this was because I was trying to get a "happy medium" between pedaling efficiency and ability to get behind the seat for the DH sections. Now I'm running at the correct height, and it's much easier on the knees and my times are better on the hill climbs.
    3. DH sections are more fun with the seat out of the way, once I got used to it. Now I can ride with a lower center of gravity with my weight properly balance between front and rear tires instead of having my butt hanging over the rear wheel. It's more confidence inspiring on the steep drops and technical sections because I don't feel the seat is going to hit me in the rear.
    4. Just within the past couple weeks, I've been lowering the seat for fast flowy sections. The ability to get lower on the bike and have a lower center of gravity makes it a lot easier to dig into the corners. Fun factor ++!
  91. #391
    Quote Originally Posted by JPBakerIII View Post
    Thanks. I pulled the cover and just pulled the cable by hand and it works fine, so there must have been just enough cable stretch or the cable slipped under the setscrew. Either way, cable shortened ever so slightly and I'm back in business.
  92. #392
    Mar 2013
    -G
    I reckon you will love it, the dropper post has really improved my riding skills, and the rides are even more fun with the seat out of the way on the downs
  93. #393
    Reputation: bigfruits's Avatar
    Mar 2011
    thanks Haymarket, I just ordered the 150mm.
    there is just about 8" between my seat collar and the seat rail currently at max height. you think that's cutting it close with the 150mm LEV? (total length will not be an issue.)
  94. #394
    Stand back
    Reputation: dbabuser's Avatar
    Maybe I missed it - why the switch from the reverb?
    Golden Bike Park
    Golden Connector Trails need your support!
  95. #395
    bike rider
    Quote Originally Posted by dbabuser View Post
    For 6" drop instead of 5". On this bike the cable routing was really clean so the stationary cable isn't much of an upgrade but at my height 5" just wasn't enough difference between my climbing and descending heights. Now I can ditch the QR and only have to drop the post farther for serious jumping.
    On my trail bike where it's replacing the i950 the routing wasn't as ideal so the LEV cleaned things up a lot but that extra inch was the real reason for buying.
  96. #396
    Helmetless Crasher
    Ditto to all of the above.
    The ability to get over the rear tire makes it SOOOOOOO much easier to attack rough DH sections at higher speeds than before.
  97. #397
    Reputation: hartwerks's Avatar
    Oct 2011
    I got a 27.2 today with 100mm drop. I was very excited about it and stoked to get my NS Surge stepped up a level and ready for some serious fun. Unfortunately, the post has effectively no air pressure and so it does not return on it's own without getting off the bike and pulling it up. (In all fairness, it functions just fine as a "dropper" post. Unfortunately, it doesn't work at all as a "riser" post...) In and of itself, it's a bummer getting a broken post straight out of the box. Much more frustrating is the response from KS which was effectively that I could mail it to them (my cost) and they would get it fixed and send it back. So on top of buying a very expensive post, I get some added cost, added wait time, and added frustration.
    Apparently KS can brag that they cost more because they are "the best," but they can't afford to send out a UPS label for a broken brand new product. Maybe I've just gotten spoiled by dealing with other companies with better customer service.
  98. #398
    There is an air valve on the top of the post, underneath the seat clamp. Part of the installation is checking to make sure it has the correct pressure. Did you check it?
    Quote Originally Posted by hartwerks View Post
  99. #399
    Oct 2011
    Unfortunately, there is no air valve and no adjustable air pressure on the 27.2 version of the LEV. It is preset at the factory. There seems to be a sealing issue in the Taiwan factory, and KS is aware of it.
  100. #400
    Ah, that sucks! They really should send you a new post AND a return label...none of that RMA BS.
