Results 1 to 13 of 13
    Jan 2015
    Double crankset setup.
    I have an older e thirteen single/double xcx+ crankset.
    It is currently set up single how would I go about making it a double? And what type of chainrings would I need?
    I would like it to be 22/36 or 22/34 as I plan on running it di2 syncro shift with a dura ace 11-30 cog in the rear.
    The idea being to get the range of eagle and move the weight back to the middle of the bike.
    I already have di2 1x11 and would only need the front derailer.
    Here is pic of my crankset..E Thirteen XCX+ Double Crankset | Chain Reaction Cycles
    Nutrailer
    Reputation: JackWare's Avatar
    Aug 2016
    I'm not sure regarding the derailleur required but looking at the description you added the link for, the outer spider has a BCD (Bolt Circle Diameter) of 104mm so the inner will be 64mm.
    If you just search for 22/36 or 22/34 chainsets and ensure they are 104/64 you'll be fine.
    I found this with a quick Google
    But are you sure you want to add another front cog and derailleur and another shifter?
    You can get a similar spread of rear ratios with by changing out the rear cassette for a wider range one;
    YMMV
    What a perfect waste of time
    Reputation: DethWshBkr's Avatar
    FYI, I do not think a Dura Ace cassette will work as you'd like.
    I have XTR Di2 on my Scarp, 36/26 front. I rarely dump into the 26, so I put an Ultegra 11-32 on the bike, figuring I could set the synchro shift to use the lower ring, and have a tighter ratio.
    The rear would not "quite" work properly. It would shift, but with an occasional skip or shifting issue. The spacing on the road cassettes appears to be slightly different.
    Quote Originally Posted by JackWare View Post
    Di2 makes 2x very nice. No shifter needed for one....
    Range is not always the important thing, sometimes having a tighter spacing is better! 1x cannot deliver that.
    Jan 2015
    Quote Originally Posted by DethWshBkr View Post
    Hmm I have a couple friends who run road cassettes just fine it's common.
    But they don't have di2 I'll look into it.
    Thank you.
    because GIANT
    Reputation: 127.0.0.1's Avatar
    Nov 2013
    "Put your seatbelt back on or get out and sit in the middle of that circle of death." - Johnny Scoot
    Jan 2015
    My crankset only has one set of bolt holes so I thought it needs some special chain ring?
    Jan 2015
    Yes thank you I think I'm screwed and need new cranks those rings are not in stock and are 9-10 which may be too wide for 11 spd chain.
    Jan 2015
    I sent e13 an email to see if they have a set of rings laying around somewhere.
    I'll update if I get them.
    Thanks for all responses.
    Jan 2015
Name:	Gear ratios.JPG
    YMMV
    As the other guy said di2 shifts with one shifter and I can program where it shifts the front ring.
    Meaning it will never be cross chained so I can run a short chain with zero slack.
    Also the point is to get away from huge rear cassette and move unsprung weight from rear to the middle of the bike. The 11-30 cassette is 200 grams.
    Jan 2015
    Ok thanks everybody e thirteen got back to me and I did need the chainrings that bolt together and they do have 22/36 in stock so yay.
    Jul 2017
    Quote Originally Posted by Kevin Van Deventer View Post
    You need a spider for those chainrings, to be specific. I'm assuming that your current chainring (and the existing spider, if any) was designed for 1x. You'll need a 2x spider in the 104/64bcd configuration to be able to fit those chainrings.
    MTB B'dos
    Reputation: LyNx's Avatar
    Subscribed to see how this works out for the OP and if he does in fact have any shifting issues using the road cassette with MTB setup.
    One thought, how about cage length? Thinking that the MTB RDs are designed for cogs up to 46t, so getting the top pulley close enough and good chain wrap, could be an issue. I just set my 10 year old Monkey up for road duty, 10 spd, 25-11 cassette and Zee RD and it worked very well, decided to steal the Zee RD for my newest build running basically a 1x setup and so put a regular XT and it's not shifting nice at all, thinking I may order another Zee RD for it.
  1. Converting an FSA triple Dynadrive Crankset to a double crankset
    By wheelinthai in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-22-2014, 06:20 AM
  2. Differences in strength between XT 780 triple crankset and the 785 double crankset??
    By zoro in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-15-2013, 03:11 AM
  3. Replies: 18
    Last Post: 10-30-2012, 08:35 PM
  4. Double specific FD for triple crankset, 2x9 setup
    By nampla in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-06-2012, 04:41 AM
  5. First Build - Double Sled Design - Double XP-G R5 + Regina
    By tv-kid in forum Lights DIY - Do It Yourself
    Last Post: 11-24-2011, 11:16 PM
Members who have read this thread: 38
