Page 6 of 6 FirstFirst ... 23456
Results 501 to 544 of 544
Thread: Bikeyoke Revive
  1. #501
    Reputation: smithcreek's Avatar
    Nov 2012
    5 nm.
  2. #502
    Reputation: DriverB's Avatar
    Apr 2014
    Quote Originally Posted by monts View Post
    And yep, I'm pretty sure i used the anti-seize your describing.
    How sure is pretty sure? This is not an insignificant detail relative to your problem
    Sent from my SAMSUNG-SM-G925A using Tapatalk
    Marin County, CA
  3. #503
    Quote Originally Posted by DriverB View Post
    100% sure I used anti-seize
    99% sure I used the type of anti-seize that is being described in the post.
  4. #504
    Apr 2014
    Got it. I don't think the type would have much effect as long as you're using it. Anti Seize would be appropriate vs Carbon paste assuming the inside of your seat tube is aluminum. Finish Line makes this.
    Marin County, CA
  5. #505
    Oh, So Interesting!
    Reputation: davec113's Avatar
    Quote Originally Posted by Didzy2009 View Post
    thanks man for the info, ill drop them an email to confirm it all
    Mine is doing the same, Ti rails, pretty sure it's low torque.
    I'm using Park carbon paste but have not broke out the torque wrench, I think it's needed as we probably need to approach max torque to keep the squeaking away.
    The saddle definitely doesn't creak when it's not mounted, I don't think it's the problem.
  6. #506
    It's a steel frame (canfield nimble 9), Sacki said to use grease (i e-mailed him).
  7. #507
    Oh, So Interesting!
    Quote Originally Posted by davec113 View Post
    To fix the squeek, the saddle and mounting hardware need to be removed, cleaned, apply anti-seize anywhere metal contacts metal, carbon paste to the seat rail channels and re-assemble.
    Anti-seize should be applied to the bolt threads as well as the bottom surface of the bolt head, also inside the cavities the nuts sit inside. Doing this reduces friction and allows more torque to go to turning the bolt rather than overcoming friction. So for the same torque you get increased clamping force. This also means proper torque is lower, so be careful of this. A torque spec doesn't mean anything if the fastner isn't prepared correctly, and can vary by large amounts depending on lubrication type. For the threads it's possible assembly lube would be a better choice but without knowing how the torque specs were chosen to begin with it's all a crapshoot if you want to achieve just the right clamping force.
    In any case... no more squeeky saddle!
  8. #508
    Oh, So Interesting!
    This is unfortunate it happened so quickly, even using grease!
    Penetrating oil and heat may be useful to prep, maybe not.
    You need to figure out how to hit the top of the seatpost with a large metal hammer without damaging it. Many small taps can often work instead of one big hit. Heat the frame until it's hot to the touch but don't go too far or the paint will bubble. You might also be able to grab the post with a strap-type wrench and apply some torque.
    I'm not sure there is any good way to go here except some heat, oil and force. Good luck!
  9. #509
    Elitest thrill junkie
    Reputation: Jayem's Avatar
    Due to the low torque that all dropper posts use (lest they bind) its not realistic to use anything other than friction paste.
  10. #510
    Apr 2014
    Are you suggesting the 5nm max spec torque dictates friction paste, or said differently that Anti-seize paste at 5nm does not hold? I haven't installed mine yet but this would seem strange, particularly since the manual specification states friction or Anti-seize (and not grease in all caps, which increases necessary clamping force).
    Friction paste contains microspheres and should be used for carbon to decrease necessary clamp force. Anti-seize is for titanium or aluminum (but can work for other metals), and prevents galvanic corrosion and the like. It is not necessary for carbon on metal interfaces.
    Marin County, CA
  11. #511
    thanks, that's what we've been doing, small taps... made some progress today... hopefully soon. this is stressful
  12. #512
    I serviced my Revive for the first time. I stopped noticing any excess grease at the top of my post after a ride, so I decided to crack open my post and regrease. I used Slick Honey to grease the internals.
    Some tips:
    1. I did NOT let the air out of my post before doing the service. No problems.
    2. My 7mm Stanley wrench measured 4.3mm wide v. 3.9mm for the wrench in the service video, and I couldn't fit my 7mm wrench all the way onto the wrench flats. I used an 8" crescent wrench on the other wrench flats. Luckily, the black end piece unscrewed with little force. When I reassembled, because the black end piece wasn't screwed into the end of the rod anymore, I could now fit my 7mm wrench all the way onto the flats, but when I screwed the black end piece back on and tightened, my 7mm wrench was stuck. So I had to loosen the black end piece again to free my wrench, then fit my 7mm wrench only partially on the flats, then retighten. I tightened to what I estimate was 1-2 Nm.
    3. The large snap ring is removed by squeezing the holes together. On the other hand, the small snap ring is removed by pulling the holes apart. My cheapo $7 snap ring pliers with red handles from amazon allow you to reverse the direction that the jaws move when you squeeze the handles together--you just remove the jaws and mount them on the posts on the opposite side of the pliers.
    4. I didn't think the tape was sufficient to protect the rod, so in addition to the tape I wrapped some paper towels around the rod, then folded over the top of the paper towels and taped it down. That created a hood I could slide on and off the rod.
    5. The brass rods did not fall out when I slid the inner post out of the outer post like in the service video. In fact, they were quite difficult to get out. I held some wadded up paper towels in the palm of my hand for cushioning, then I whacked the outer post against my hand to encourage the brass rods to fall out of their slots. I would suggest stuffing a paper towel in the opening at the top of the outer post, so that the rods don't fly out that end when you whack the post against your hand.
    6. I couldn't tell one side of a snap ring from the other--despite looking at them under a magnifying glass. Both snap rings looked perfectly symmetrical to me. If you want to install the snap rings exactly the way they were, carefully place the snap rings down on your work bench in the same orientation they were in when you removed them.
    7. Reassembling the white plastic ring and the large silver plate/washer was a little fiddly. I couldn't fit my fingers down into the post, so I used Q-tips to press in the white ring, and then I pressed the white ring all the way down with the silver plate.
    8. I didn't use loctite on the threads at the end of the rod as shown in the service video. There was no evidence of any loctite that had been previously applied, and because my 7mm wrench doesn't fit all the way onto the wrench flats, I didn't want to make it harder to unscrew the black end piece the next time I service my post.
    All the internal pieces looked like they were in excellent condition, however I like to have spare parts on hand before disassembling, but I couldn't find the service kits available anywhere.
    Servicing my Revive was easier than servicing my old KS Lev (external). I like how you insert the brass rods into the slots after you slide the inner post into the outer post. With my KS Lev, I had to hold the brass rods in their slots on the inner post while trying to slide the inner post into the outer post, which inevitably caused the brass rods to get knocked out of their slots. If I remember correctly, my KS Lev had three brass rods, and the Revive has six, so the Revive should resist twisting better than the KS Lev. My KS Lev had about 1mm of side to side play, which wasn't noticeable on the bike. I noticed that my brass rods had no markings on them contrary to what is shown in the animated video.
  13. #513
    Quote Originally Posted by happyriding View Post
    I like how you insert the brass rods into the slots after you slide the inner post into the outer post. With my KS Lev, I had to balance the brass rods on the inner post, then try to slide the inner post into the outer post, which inevitably caused the brass rods to get knocked out of their slots in the inner post.
    This sounds so much easier, Those brass keys on a 9.8 rebuild almost drove me crazy!
    Thanks for the tips
  14. #514
    n00b
    Reputation: Krigloch's Avatar
    Holy crap, just read this whole thread!
    Totally saving up for one of these!
    Sent from my SAMSUNG-SM-N920A using Tapatalk
    instagram@krigloch
  15. #515
    Reputation: Kirkerik's Avatar
    Apr 2016
    If you have'nt freed it yet, prob should break the bike down. Make it much easier.
    Have you soaked it w penetrating oil from the BB side w frame upside down? It can take a long time to get oil where you want it. Gentle heat such as w heat gun, or if you are CAREFUL enough and warm SLOWLY a torch w a bush/brush flame setting.
    The problem w tapping it w a hammer is you're driving it deeper in to the frame thereby potentially increasing the hold the frame has on the seat tube! I'd only do that as a last resort. Can you borrow or rent a slide hammer? A slide hammer pulls w each strike. You can prob make one out of some iron pipe and fittings and a way to attach to post perhaps w cable.
    The tires are the things on your bike that make contact with the trail.
  16. #516
    Quote Originally Posted by Kirkerik View Post
    Used heat and penetrating oil. i'm going to check in today again on it.
    I looked at a slide hammer but not sure where the best spot would be to attach it, any ideas?
  17. #517
    Oh, So Interesting!
    It won't matter. Once it can move at all, it will be able to move freely up or down.
  18. #518
    Apr 2016
    That's the hard part, isn't it. hmmm.
    Def don't want to stress the internals of the revive.
    If you can get some type of pipe clamp cushioned w a few layers of inner tube rubber (or maybe an old seatpost clamp) on the larger part of the dropper just before the collar and then girth hitch a couple loops (one each side to balance load) of cable below the clamp so it does not slide up and off the dropper post. A secure connection and straight pull is essential.
  19. #519
    Apr 2016
    Yeah, prob right.
    Keep soaking it for sure.
    Do you have a gorilla for a friend that can stand on the frame and simply yank it out? Lol
  20. #520
    Oh, So Interesting!
    There might have been a small squeek from the post bottoming in the frame too. The perfect position for the post (for me) is right where it bottoms, but obviously I don't want the post to wear a hole through the frame so giving it a mm or 2 is probably a good idea, with a mark on the seatpost to make sure it doesn't get pushed all the way down as you ride.
    Anyways, went for a ride yesterday with a completely non-squeeky bike and it was nice.
  21. #521
    I've got some Maxima 5 Fork Oil left over from servicing my KS Lev, and I wondered whether I could use it to do a full service on my Revive--when the time comes. So I did some research.
    1. 1 cSt = 1 mm2/s
    2. If you click on the big black image in sacki's post, your browser will download a pdf file that gives the specs of the stock Revive oil:
    Code:
    Viscosity index                       method=ASTM D2270     161
    Kinematic Viscosity @ 40 C, mm2/s     method=ASTM D445      15.8
    3. Maxima's reported specs:
    So to compare:
    Code:
                        Revive Oil     Maxima 5 Fork Oil
    cSt                    15.8                15.9
    Viscosity Index        161                 201
    That looks pretty close. But here is some independent data on Maxima 5:
    That info is credited to Peter Verdone Designs, but I couldn't find it on his site. For Maxima Fork Oil 5wt, it says:
    Code:
                                        Independent
                                       Maxima 5 specs
    Recalculated Viscosity Index            98
    (but it says Maxima reported 150)
    It seems like the Maxima 5 would work--but maybe the VI is a little low? From the Peter Verdone Designs info:
    The other interesting number is the Viscosity Index (VI), which is how stable the viscosity is over a wide temperature range. Bigger numbers are better.
    I wonder if a dropper ever gets very hot?
  22. #522
    Reputation: BmoreKen's Avatar
    Sep 2004
    Has anyone had any issues with the remote lever getting stuck?
    I rode yesterday in 20*F cold. Was doing some maintenance on the bike today in my basement and I cannot depress the lever - it gives a little bit but very stiff, and cannot depress enough to release the seatpost to drop.
    Is this somehow related to riding in cold?
    What should I do? Will it return to normal when Im back in the cold?
    Apr 2017
    That has just been addressed just on the last page of this thread:
    Bikeyoke Revive
    BikeYoke staff member - www.bikeyoke.com
  24. #524
    Sep 2004
    Quote Originally Posted by sacki View Post
    Bikeyoke Revive
    Awesome thanks!
  25. #525
    Mar 2012
    Yea. Use the Revive feature to open it up. Next time drop the post a little before storing.
  26. #526
    Quote Originally Posted by jm2e View Post
    Do this
  27. #527
    Jan 2009
    Has anyone got an issue with the anodizing on the seat post itself (the bit that goes into the seat tube)
    Mine is absolutely full of loads of missing paint presumable from my back light being attached...its only a rubber band and its totally solid so it doesnt move at all....obviously grit and mud get in there and cause this...but ive had about 10 dropper posts and not one has ever rubbed off the anodizing before...looks a right mess its only 4 weeks old...just rubbed it off straight down to the metal
    Any one elses doing this? Its literally the only thing i can fault but it hasnt had a very good long lasting finish on it
  28. #528
    I don't know if my problem had anything to do with the anodizing or not, but there was seriously nasty stuff on my post when I finally got it unstuck from my frame. I had to get a new lower tube unit. Fortunately it's an easy switch.
  29. #529
    Jan 2017
    I believe bikeyoke should replace it for free by warranty.
    No seatpost should develop this in weeks. Hell, even in years.
    Even hated-by-everyone Reverb is great regarding its anodizing durability and it can last year or two without any 'lower leg' service.
    This is quite concerning, since this seatpost is one of the priciest on the market. And if there are serious durability problems, it's not worth it at all. Better look for something mechanical (E13 for example).
  30. #530
    Slovakia (Europe)
    Reputation: PeterG's Avatar
    This has nothing with "durability" and warranty, it's so called "electro corrosion" between 2 materials (aluminium/carbon, aluminium/aluminium) if moisture is trapped between seatpost and frame. I noticed that in any seatpost if was not properly treated, i.e. greased. To prevent from overtightening the seatclamp I prefer to use one size down seatpost diameter (i.e. 30.9 instead of 31.6mm) and U.S.E. shim 31.6/30.9. Shim has the collar so doesn't slip into the frame and can be greased on outer surface, while inner surface is grooved from machining and holds the seatube well even greased (much better than carbon frame). This solution works for me for years for standard and dropper posts, no problems with anodizing issues from electro corossion. The other advantage of a shim is the possibility to use the seatpost for all frames from 30.9mm up (when changing the frame).
  31. #531
    Quote Originally Posted by PeterG View Post
    It's not in any manual to follow this procedure, so how would the customer/user know?
  32. #532
    Jul 2017
    I suppose if one were to read up more on metals, one would learn of this?
  33. #533
    There's no way we should have to use shims to avoid corrosion. Also, I've never had an issue with any other seat post corroding like this one did. Also, I used anti-seize. Grease seems to be working much better. Will only be using it from now on. I always used grease on my other posts, but the Revive manual states to use only Anti-Seize and not to use grease.
  34. #534
    Apr 2016
    It is possible the formula for "antisieze" is quite different in Germany but how are we to know that.
    When i read that (antisieze) i thought it was a weird suggestion. I have been using fluid film on my aluminum frame and have yet to have any problems.
    With the dissimilar metals such as a steel alloy frame and the aluminum revive corrosion is more likely. A quality grease should work well here. I'd still check it occasionally to dry, clean and re-grease as necessary.
    Your issue with your frame may have something to do w the particular alloy they use?? IDK
    Glad to hear you got it out.
    How did you end up doing it?
    Is your frame alright?
  35. #535
    Soaked in PB blaster, tried light force, little taps, etc. Soaked more, rode it, more of the same, nothing...finally decided to use the pipe wrench. There was no way it was coming out any other way, even with the pipe wrench I had to apply a twisting upward motion to get it out. Believe it or not, the post still works fine and the frame is fine, I honed the inside out and greased everything and it's good. I sent some pics to Canfield (steel Nimble 9 frame) and to Sacki. They were both helpful through the process so I won't post the pics here, but there was some seriously nasty junk on that post when I got it out.
  36. #536
    There are different types of Anti-Seize available everywhere. Thought auto supply stores typically only carry one. Usually the aluminum variety. I bought a big jar of the copper type through amazon after seeing instructions (I forget for what) that specifically stated not to use the aluminum kind.
    That said, you would think that if a manufacturer called for a specific type, they would specify it in their manual.
  37. #537
    Jun 2014
    I just got a Revive in yesterday, first one I have had my hands on. I think it is a brilliant design and I look forward to using it. But it does seem that if it has a weakness, it is in the finish. Just from a quick test fit, basically sliding the post in and out of a carbon seat tube a couple of times, a little twisting for alignment and lightly clamping, there is some visible scratching in the anodization. It is minor and won't be an issue when the post is installed, but it still shouldn't be there. I have had other anodized posts in and out of the same frame many times with no visible marks at all. Whatever anodization process Bike Yoke is using, it ain't the best. Surprising for a post that seems to be hands down the best available in just about every significant category. But the bottom line for me will be reliability and performance and I still have very high expectations for this post.
  38. #538
    Slovakia (Europe)
    From my experience the anodisation is more durable the more "knurled" the surface is (typical example is Thomson Elite). The more polished the surface is, the worse is the situation. Maybe it's due to scratches are not so visible on knurled surface. I don't have Revive yet to judge but planning to order one before season starts.
  39. #539
    Jul 2013
    Hey sacki, I just wanted to say that I've been in the market for a new dropper over the last couple weeks, and just as I thought I had settled on a Fox Transfer, I discovered the BikeYoke Revive and I just bought it from Backcountry. And I have to tell you that one of the reasons that I bought it was that I found this thread and I'm impressed with the way you have been answering people's questions promptly and thoroughly. That goes a long way.
  40. #540
    Jun 2014
    The surface I noticed the scratches on is the textured surface similar to a Thomson or 9Point8 or many other posts, basically fine grooves in the machined surface. The scratches are small but there are shiny spots visible. Still, I wouldn't let this deter you, I would buy this post over anything else on the market if it were just coated in Sharpy ink. Dropper posts are probably the single most troublesome component of current bikes and I will take superior design over cosmetics any day. And actually this is a very good looking post, I don't care if there are some scratches hidden in the seat tube, I typically don't put anything on the small exposed lower section of a dropper anyway and if I do I will be careful. The one big caveat would be if the stanchion surface wears excessively, that could become both a significant cosmetic and performance issue in a hurry. Time will tell, and they have a 2 year warranty.
  41. #541
    Apr 2017
    Quote Originally Posted by gobbledegoo View Post
    Thank you so much for your kind words! It is always nice to hear, when people actually appreciate and value the support were trying to give!
  42. #542
    Apr 2017
    Quote Originally Posted by prosto_mtb View Post
    Id like to say a few words about this topic:
    I wonder, how you come to the conclusion, we SHOULD replace this post/tube under warranty. Neither have you seen the actual look of the post, nor do you have any information besided the ones from the customer. With all due respect, this is not something you can decide by hearsay without exactly knowing, what happend to the post. Maybe the user can post a picture, so we can see, what he is talking about.
    I have worked at Bionicon Bicycles for the past 7 years, and I have installed, serviced and worked on hundreds of bikes with dropper posts from Rock Shox over KS, to Fox, Race Face, Forca, etc.
    There were posts of each munufacturer, that looked like new after years, but there were also posts, that looked extremely worn just after a few months of use. In more than 99% of the cases, it depends on how you treat your bike and post. In the other cases, it might be weirdly reacting materials and or actual badly anodized parts (very unlikely).
    Id like to explain a little bit about our anodization finish:
    1. Our seatpost experiences the same anodization treatment as many other posts from other manufactuers, performed by the same, very renowned anodization factory. I am not saying, that there cant be a mistake in the ano-finish of some posts - for sure this can happen. However, we can say, that we have less than 10 reported cases (and this is less than 0,1% of all sold REVIVES as of now), where customers complained about the finish. Some of them used the post inside a steel frame, some of them attached something to the post, some used friction paste. One major difference between our post and some others is the our machining finish, while most other do have a shotpeened finish. This can make a difference, since our post in theory contacts on a smaller area. We will do some research and see, if shotpeened finish helps to reduce the rub. Then wed have to sacrifice our perfect machining finish.
    2. Friction paste (as well as anti-seize powder or paste) can cause the anodization to fade, as the particles can be very hard and micro-movements inside the tube will work basically like sandpaper. There are many different kinds of friction paste, and I can not rule out, that some of them are more aggressive than others to ano-finish.
    In the manual we do recommend to use friction paste, that is correct. We mention this, because we have found that it (unfortunately not rarely) happens to be, that seattubes are not properly reamsed and bigger than they should be. I have had a customer complaining, that he could not properly clamp his post inside the frame. It turned out, that the seattube was 31.4~31.5 instead of 30.9. This is terribly off of any tolerances. The frame make was an expensive one and not direct sales brand by the way.
    Personally I never used friction paste on my personla bikes - I always use grease, since this will help keep water and dirt away from the "gap" between post and seattube. But if we tell the customer, to use grease, then maybe a lot of posts will be slipping. But I can also not rule out, that some grease compounds will also attack the surface. Chemical reactions between steel and aluminum, carbon and aluminum, carbon and grease, water and steel, ... can not be foreseen, so it is just impossible to give a 100% recommendation of what to use.
    I will try to find some proper words and I think will updated the manual accordingly.
    If you can clamp your post properly inside your frame with heavy grease, while making sure, that the grease is not aggressive to any of the components, then grease should always be the best solution to apply on your post. This I am saying from personal experience, but I am not saying, that this is 100% correct or applies for every single combination possible.
    3. The upper tube and lower tube have totally different surface finishes/treatments:
    Upper tube is hard anodized and lower tube is just anodized. Hard ano-layers are much thicker and harder than just "normally" anodized surfaces.
    4. Anything that is attached to an anodized surface (no matter if rubber or not) will be able to collect dirt and mud and water and this willl eventually get between the two and rub off material = anodisation layer.
    5. Steel frames do cause corrosion, especially, if the inside of the frame is humid/moist or wet. Anodized tubes (no matter if hard anodized or anodized) are pretty resistant to water and corrosion, but when corroding steel frames get in touch with aluminum seatposts, they can add oxidation layers to the post or attack the anodization. This does not come from the post, but from the steel frame.
    I hope I did not forget anything (or too much), but please feel free to ask, if you have more questions - also about other issues.
  43. #543
    Slovakia (Europe)
    I'm glad to hear, that Sacki's experience with greasing the seatposts meets exactly my experience. I would just add another 2 cents: if someting must be attached to the seatpost (rear light or so), it's always good to put clear 3M helicopter tape (or similar) underneath to prevent rubbing the anogization (i.e. simply wrap around the seatpost with piece of clear tape ...).
  44. #544
    Jul 2014
    I see that some people have had this dropper for some time, sounds like this is the dropper to get. What can anyone say after having it for over 6 months or more ? I have had very bad luck with droppers and I need to buy a new one very soon. I have had a reverb (longest lasting and favorite of the ones I have) easton haven (JUNK) e13 TRS (to big 150mm stock on my capra and only 3 position not very good.
    If this is the post to get I have no issues putting down the money... but I don't want to get one and have issues in 3 months.
    I have read a lot of the posts on here, most seem great....
    2016 Motobecane Bullet
    2015 TREK REMEDY/BUILD
    2014 Trek Fuel EX9 FRAME/REAR SHOCK FOR SALE
    2013 Trek Domane 2.3
  1. BikeYoke DeHy Reverb conversion
    By Andeh in forum Components
    Last Post: 03-20-2017, 10:57 AM
  2. Bikeyoke Came Through
    By Jayem in forum Components
    Last Post: 01-25-2017, 08:04 AM
  3. BikeYoke for the Enduro - but what shock?
    By Porch in forum Specialized
    Last Post: 10-17-2016, 08:49 AM
  4. How to revive the Passion
    By OttawaTom in forum General Discussion
    Last Post: 03-06-2013, 06:50 AM
Members who have read this thread: 560
