Page 9 of 10 FirstFirst ... 5678910 LastLast
Results 801 to 900 of 923
  1. #801
    Reputation: bikeguy0's Avatar
    Quote Originally Posted by JackP42 View Post
    If the connector is freely spinning and not unthreading, an internal part is broken/damage. There is a square shaft in a square hole that keep the piston from spinning when disconnecting the QD. Your options are send it in, or get new brake/mast assembly.
    So on one of my posts the connector is a bit tight to get out. I have to put a 8mm box wrench on it so I can wiggle it out. Can you thread back in? I would release all pressure from the post and remove the bottom with a cassette tool. This should allow you to back it out hopefully. Just make sure the connector is fully unthreaded first. Try that first before sending it back. The connector threads in to the brake shaft
    My Team: Feedback Sports Racing
  2. #802
    Hey. BTW donít try a snap ring like the one in first photo below. It gets hung up on the bottom nut. It has to be a style like in the second photo which is harder to find and called a "Constant Section" internal snap/retaining ring. I'm trying to source some just to make it easier to pull the brake when it is needed again.
    I used electrical cleaner from autozone and that worked great to clean the brake. The brake was contaminated with a ton of grease. I can't believe it worked at all.
    Post is as good as new now.
  3. #803
    Reputation: wvtrailbiker's Avatar
    How are people getting through to customer service for a ra number!?!? Left a couple messages last fall with no response. Have been running a dvo so i forgot about it over winter. Well a couple weeks a go i decided to try again. So far I have left a total of 6 messages and 2 emails with not one response. My wifes fall line post has never had an issue but mine has been nothing but problems have cleaned the break several times and replaced the seals. Still leaks and slips....worked for the first 2 weeks and that was it.
    Last edited by wvtrailbiker; 03-30-2018 at 08:13 PM. Reason: They solved the problem
  4. #804
    Reputation: SoCal-Rider's Avatar
    Quote Originally Posted by wvtrailbiker View Post
    I made contact with them thru the website a couple of weeks ago. They were very responsive and got back to me quickly. We had some back and forth emails and those were quick exchanges as well.
  5. #805
    My 175mm 9point8 lost air again after a "quick" rebuild, so I pulled it apart and decided to try upgrading the wiper seal at the top of the post.
    My problem seems to be that the grease all leaks out, the X-Wiper goes dry, and then the air starts to seep out. I was hoping that by upgrading the top seal to one with a garter spring I could keep the grease in.
    I ended up buying an AVX shaft seal, 25x33x7mm, from Amazon (more on that later*).
    I used a dremel and a sanding drum to remove the lip at the top of the seal head. There is still about 0.2mm difference in the ID vs. the OD of the seal, so you may want to remove a little more than this, or polish down the rubber on the outside of the seal.
    At 7mm thick the seal sticks out a little, and I opted to keep the metal washer that locks the bushing in place (even though it adds 1mm to the height). Another problem is that the garter spring is on the wrong side of the seal...I opted to put it "outside" instead of "inside" the dropper, since that's what most manufacturers do (and this is a double-lipped seal, so there will be a seal working on the inside too, it just doesn't have a garter spring).
    Anyways, easy project and so far it's fine. Time will tell. I'll update if it helps keep the grease inside. Worst case the difference between a rebuild kit from 9point8 ($53) and a rebuild kit that includes the v2 seal head ($67) is negligible, so you can easily revert.
    Lip ground down:
    9point8 Fall Line Dropper Post. Totally happy with mine!-img_20180326_195849.jpg
    Seal pressed in (I used two boards in a vice):
    9point8 Fall Line Dropper Post. Totally happy with mine!-img_20180326_201530.jpg
    9point8 Fall Line Dropper Post. Totally happy with mine!-img_20180326_201522.jpg
    * You can order the seal I used directly from the manufacturer here: Shaft Oil Seals TC25x33x7 I started a cart and didn't check out, so they emailed me the code "FreeShip" (not sure if there's a minimum) and "giveme5" ($5 off, unknown minimum). That said, there might be better seals out there...I haven't had time to go through SKF's catalog to find a similar spec seal, but I would have preferred that.
  6. #806
    Ride Fast Take Chances :)
    Reputation: alexbn921's Avatar
    Quote Originally Posted by Porch View Post
    Lip ground down:
    Nice work, keep us up to date. 9point8 are you out there? Why doesn't your post have a double lipped seal?
    Making shit harder than it needs to be isn't awesome, it's just...harder.
  7. #807
    Reputation: vikb's Avatar
    Quote Originally Posted by SoCal-Rider View Post
    Yup same here. Responses were usually same day. Sometimes they took 1-2 days to get back to me. All in all I'd say the CS was pretty solid for a small company.
    I bought a second 9.8 dropper recently so that says something.
    Safe riding,
    Vik
    www.vikapproved.com
  8. #808
    Lip ground down:
    Thanks for this, my posts generally hold air, but I have one that will always leak if there are temperature fluctuations, such as a warm day and then a cold night. Anyone else?
  9. #809
    Reputation: kitejumping's Avatar
    Quote Originally Posted by monts View Post
    Thanks for this, my posts generally hold air, but I have on that will always leak if there are temperature fluctuations, such as a warm day and then a cold night. Anyone else?
    Mine doesn't hold air more than a day, I need to lube it though
  10. #810
    I was in the habit of wiping down my dropper stanchion after every ride. I realised that 9.8 doesn't recommend that and it means more frequent relubing. So I've stopped. I use a Mudhugger rear fender so my dropper never gets really dirty even in winter.
    Safe riding,
    Vik
    www.vikapproved.com
  11. #811
    Lip ground down:
    This is outstanding work. Please keep us informed how it goes. For what it's worth 9.8 stepped up to the plate for me. I agree 100% the grease dries or slips past their proprietary wiper and then the X ring dries and leaks. I was to the point of having to replace the X ring every 2-3 weeks since I ride every day. I informed them their updates SSR didn't resolve the problem. They wanted me to send the post back again but I was over being without a post for 3 weeks. They sent me a second post so I could send mine back for evaluation.
    This second post has now held air for 3 weeks but I have had to grease it. I am very eager to see how your modification holds.
  12. #812
    I also bought a couple of x-rings (-214) and a seal head o-ring (32mm x 2mm) from theoringstore.com. I bought 10 o-rings and 4 x-rings for a total of $10/shipped.
    At some point I'll go through and figure out the sizes of all the o-rings in this dropper. So far my bushings have never really developed any slop, so I don't see the point in spending $60+ on the 9point8 rebuild kit.
  13. #813
    One question: did you abandon the X ring and relying on this as the air seal with this mod or is this more about just an improved wiper and taking a belt and suspenders approach to air retention?
  14. #814
    Quote Originally Posted by dodger View Post
    I kept the x-ring. Just hoping to keep the lube in the seatpost! Probably doesn't hurt with the air retention, though.
  15. #815
    Reputation: buddiesconfusion's Avatar
    I'll start by saying 9.8's customer service has been great but I send my 200mm fall line back for service due to the post not returning up consistently. I sent it back in November for a service and I've only ridden it 4 times since and I never had a ride where it worked for the whole ride. I'm now debating on selling it and buying a Bike Yoke Revive. I want a post that works and I feel like spending almost $500 should get me a post that at least works for a month before I need to maybe re-lube it. When it works I love the action and the wolf tooth remote is amazing. Any thoughts or ideas. Like I said 9.8 has been good on trying to help me troubleshoot my issues but I hate being without a post now for a few weeks.
  16. #816
    Quote Originally Posted by buddiesconfusion View Post
    ouch, shipping to 9point8 gotta be adding up
    2017 yeti sb6c turq x01 eagle
  17. #817
    I've had a few posts from them, they all eventually suffered the seal issue, but I have to hand it to them, at least they were cool and just mailed me some of those SSR kits so I can fix it myself and not be without the post during shipping.
  18. #818
    Quote Originally Posted by useport80 View Post
    No hats off to 9.8 they paid shipping both times. But the weather just got nice today and is supposed to good the rest of the week and Iím Stuck without a bike! Makes me wish gravity dropper makes a internal post with 175-200mm of drop.
  19. #819
    fuggansonofahowa
    Reputation: Hawseman's Avatar
    Currently riding my backup Lev Integra.
    My Fall Line (175mm) has lost it's holding power. I suspect that the contamination that I've been regularly cleaning from the brake chamber is seeping from the brake assembly itself. This was my suspicion when my first brake assembly slipped within the first 100 miles. 9p8 sent me a new one (bravo), but that one did the same. After about 6 cleanings, and using my floor pump to air up as suggested, it's now lost it's holding power. I'm guessing that there is not enough hydraulic fluid in the assembly to push the bladder anymore.
    I really like this post and I'm debating purchasing another assembly and giving it one more go. I haven't had any air issues, even after a couple of full maintenance rebuilds.
    I'm curious what others who have been battling contamination issues find.
  20. #820
    Quote Originally Posted by Hawseman View Post
    Can you description the slipping a little more? Mine would always hold in position but would lose its return speed i.e. when I wanted it to return to full extension it would take forever to do it or I would have to physically pull it all the way up.
  21. #821
    fuggansonofahowa
    It went up fine, but wouldn't stay up with my weight and hitting obstacles. A good cleaning of the brake would fix it.
  22. #822
    Reputation: pablobell's Avatar
    Oct 2013
    Why is a floor pump recommended over a shock pump?
  23. #823
    Quote Originally Posted by pablobell View Post
    The pump doesn't matter as long as it's clean. It's common for shock pumps to suck up air chamber lube and drip it into the next thing you hook up. I use my shock pump, but double check it's clean.
  24. #824
    Quote Originally Posted by alexbn921 View Post
    Can anyone give me any input on the setback seatpost, Like how is the clamp holding up does it feel any different than a regular dropper post. I need a setback sear post for my spot Mayhan this should be the final thing that allows me to dial in this bike! Thanks in advance !
  25. #825
    My post is leaking at the head. Under the seat clamp area. Not really sure what can be done since this piece does not come off. Has anyone been able to fix this without sending it back?
  26. #826
    Nov 2007
    Does the flange still align with the graphics on the lower tube, i.e. has the flange started to unthread?
    This should be covered under warranty so contact customer service and they can help you get the post returned and repaired.
  27. #827
    No it doesn't align, it's slightly off. I guess I'll contact them unless someone chimes in with a cure for the moment, I have a race this weekend.
  28. #828
    Reputation: Rootsboy's Avatar
    Mar 2013
    Quote Originally Posted by dgw7000 View Post
    I had a offset seat clamp ordered from the start, so I can't compare with the normal clamp.
    But I'm guessing it's the same, I have no issues with it.
    I needed to offset my seat, as I have a 32inch inseam, but riding a med frame, and I found my seat would always be pushed back past the safe point on the rails.
    Having the offset clamp solved that, and it still works in exactly the same way for easy access to the seatpost valve if needed.
    I have had mine for a year and a half now, and only just starting to get a little air loss which is rectified each or every other ride with a quick top-up.
    I have a v2 nut rebuild kit on the way which I am hoping will fix that.
  29. #829
    Quote Originally Posted by Rootsboy View Post
    Thanks for your input!! Just ordered 31.6 150mm with the 25mm offset, this should be the last thing I need to do for proper fit on my Spot Mayham 29er.
    Any one that needs service out of warr. highly recommend Mavericksuspension.com.The Flow Zone Ethan Franklin is a master at Dropper Post and all Front and rear shocks. Great prices and fast turn-a-round. He likes the 9point8 droppers!!
  30. #830
    Reputation: Wareagle's Avatar
    Jan 2009
    OMG, so glad I found this thread! I feel like I've found a support group that understands my suffering with this dropper.
    I'm at 2 years with my Fall-Line post and it's just been a constant annoyance for almost a year now. I've done the V1 to V2 nut conversion, changed seals, and lube on a regular basis, but I still get about 2-3 weeks of trouble free function before the return rate becomes slow, then I usually add a little lube to the upper which buys me another week, then I add air and start over.
    One thing that worries me though is the constant loosening and tightening of the seat clamp bolts has caused a situation where as I'm loosening them, they make a loud cracking type noise when they break loose and produce a slight burning smell. I've tried grease and anti-seize on the threads and under the heads, but it didn't help. I'm worried I'm going to break a bolt. Anyone else experiencing this?
  31. #831
    Quote Originally Posted by Wareagle View Post
    Yep, almost stripped the head. I definitely smelled the burn, but grease helped mine.
  32. #832
    Welcome to the club, i guess!
    I have the same issue with my bolt. I think it's just oxidation. But that is kinda besides the point because you shouldn't have to be regreasing and refilling every couple weeks.
    I'd suggest at the very least going to theoringstore.com and buying some "-214" x-wipers and trying to replace yours again. I've had mixed luck, sometimes an x-wiper replacement fixes all my issues and sometimes it starts leaking again right away. At least with these $2 wipers it doesn't matter too much.
    So far my AVX shaft seal (see post above) is working great, too.
  33. #833
    Jan 2009
    Okay, glad it's not just me. I wonder if this is a thing with titanium bolts. I don't think I have any other Ti bolts on my bike.
  34. #834
    Jan 2009
    I'll check that out. An earlier post mentioned McMaster Carr, but I couldn't find them on there, so I'll check out theoringstore. I saw the AVX mod, but not sure if I'm quite ready for something like that. Maybe if I get another dropper I might try it, as at least I wouldn't have to worry about messing it up (as it does at least sort of function most of the time now).
  35. #835
    Dec 2008
    I had the same issue and solved it with some thin stainless washers under the bolt heads
  36. #836
    Rocks belong
    Just did a complete wear item rebuild (V1 to V2 nut) on my Fall Line V1 after 2.5 years of service. Not that bad of a job, followed the YouTube video. Took 2 beers
    Couple of points of advice for anyone tackling this themselves:
    I didn't buy the Fall Line brake release tool, instead I went to Home Depot and bought an M7x1.0 - 80mm bolt for $0.97. I used a flat washer + 1/4" thick nut (I think it was 5/16" or 3/8", wide enough that it easily slipped over the shaft of the bolt) as spacers between the bolt head and the Park Tool cassette removal tool.
    Also, when they say use and elastic rubber band to hold the keys in the key pockets, you want that SOB tight. And you want it more on the top half of the keys. That was the hardest part of the rebuild!
    I like 'em long, low, slack and playful
  37. #837
    fuggansonofahowa
    Quote Originally Posted by 06HokieMTB View Post
    I see that 9point8 has a tool for the key install now. I wonder how it works. I agree that this is a pain. The foam ring takes a beating when you push the nut down to hold the top of the keys in place.
  38. #838
    The tool looks like it might work, there's a video on the site. I'd try anything over the rubber band method. horrible. I have a Bike yoke dropper that takes about 3 seconds to put the keys back in. so simple.
  39. #839
    fuggansonofahowa
    Yeah, Kindshock is simpler too. I do think the 9point8 has the least amount of play of all the droppers I have pissed money away on. I think the key-way design is a big part. I can't comment on the Bike Yoke dropper (assuming Revive).
    I've done droppers since the Pricepoint Sette post of the early 2K's (which I think still works). I've seen so much hype on this forum for every new dropper....then comes season 2. We'll see what happens with the Revive. I'm watching that one closely.
  40. #840
    Mar 2006
    I had this problem as well, and did round out the bolt eventually. It was a royal pain in the ass getting it out. And the stock hardware cost $30, probably better to replace with steel. I've used anti-seize and its been fine since.
  41. #841
    Jun 2010
    Has anyone experimented with installing a mechanical spring to replace the sir spring? I love so much about this post but the issues it has not holding air are making me start to look at other options. I really like how the post is user serviceable, light, good seat clamp, and the brake has been 100% reliable. I used to have a gravity dropper and that thing was totally bombproof, I can't help but think that if someone (or 9point8) would put in a mechanical spring it would be perfect.
  42. #842
    Slovakia (Europe)
    Reputation: PeterG's Avatar
    Puting mechanical spring inside would make the dropper too heavy and technically is not possible too, because there is brake inside so the stanchion inner surface must be smooth (not possible with operated spring inside).
  43. #843
    Reputation: Austin-nc's Avatar
    Apr 2018
    I've noticed I pretty much have to spray some wd40 or similar on a rag on wipe my post down every ride or it will function very and kind of step it's way up rather then smooth, do I just need to pull it apart and re grease?
    Sent from my SAMSUNG-SM-G935A using Tapatalk
  44. #844
    Quote Originally Posted by Austin-nc View Post
    Yes, it will then be good for 2 weeks 😀
  45. #845
    Apr 2018
    Eh I might just keep oiling it every ride haha, noticed it's worse when it's stores with the seat down it barely comes up. It came on the bike when I bought it used so not as annoying as if I would have bought it myself. Other than that it seems to work great I've added air to it only once. Deff gets a workout on this up and down NC single track
  46. #846
    Dec 2008
    Quote Originally Posted by PeterG View Post
    It might be possible to fit a spring below the stanchion inside the upper tube. Don't know if there is enough space though
  47. #847
    Dec 2008
    Be careful with that. If you overdo it with the oil, it could end up contaminating the brake and cause it to slip. Happened to me and I had to take the post apart and clean it. Best to grease the upper nut with the proper grease
  48. #848
    Slovakia (Europe)
    Quote Originally Posted by Skooks View Post
    There is no space below the stanchion when it's compressed - the reason why it is not possible unless you (and bike frame) accept at least 15 cm longer lower tube .
  49. #849
    Can confirm. I did a bunch of measurements to see if I could fit a spring in there and there is absolutely no room.
    The e13 dropper is only $250 new and i'm sure you can catch it on sale. It has a mechanical mechanism (though it's not truly "infinite", if i understand correctly) and uses a return spring instead of air. Their first year had a few issues but supposedly the current model is good. Rebuild kits are $30. That's where I will go once my 9point8 goes beyond repair.
  50. #850
    I own an Easton 150mm dropper and a Raceface 150mm dropper, both based on 9.8 tech, they both work pretty good overall, no leakdown while riding, lots of hours ridden in the three+ years I've had them, never rebuilt, used often while riding, no issues other than slow return at temps below freezing.
    Then I splurged for a 9.8, what a friggin nightmare! First I got one that was too long, my fault of course, but the return process and shipping cost was astronomical. I get that they are in Canada, but they get $40 just to accept the post back, plus shipping both ways, regardless of whether the post is used or unused. Then it's weeks of waiting.
    So I get the second post and it leaks down fast enough that I have to pump it up during a an hour long ride. I exchanged numerous emails, they seems to struggles with the idea that a new post could have a problem, so I finally got them to accept the post back, with weeks and weeks of downtime. In the meantime I got an E13 post... which was half the price and worked perfectly.
    I sold the replacement post as soon as it arrived at a loss, total cost of this mistake including shipping, return inspection fee, and loss at resale was ~$250. Your mileage may vary.
  51. #851
    Nov 2006
    I have an older Fall Line with the V1 nut. I thought my upper stanchion had "spun" but didn't know how that could happen without trashing the keyways. I am assuming since my seat is no longer aligned with the logo on the rear of the post that the head assembly has rotated. I am not getting any loss of performance as the post still works great. Never been rebuilt. I simply rotated the entire seatpost in the seat tube to maintain seat alignment. Any concerns?
  52. #852
    Quote Originally Posted by Andy13 View Post
    Hey mine did this and it was fine at first. But it took another hit and started leaking air. I had to send it back to 9.8 for repair, you can't do it yourself. Keep an eye on it, but I would not leave this post too tight in the seat clamp to avoid during a crash.
  53. #853
    Nov 2006
    I actually got a return phone call from 9point8 support from leaving a phone message. They called me back in less than a day and told me just what "Monts" posted. Keep an eye on it and if it does start leaking then it will need to be returned to them for re-torquing of the top piece. I am assuming that it will eventually start leaking air. Is there a seal between the two pieces or is it just locktited and torqued, anyone tried to do this themselves?
    Overall I am very happy with the performance of the seatpost. Many seasons of hard riding and this is the first issue I've had.
    TIA
    Andy
  54. #854
    Quote Originally Posted by gone_riding View Post
    Same here. It rotated on a fall two weeks after I got it. I straightened it then sent it in at the end of the season to be warrantied (as they suggested). I got it back last week.
    Just to be clear here, because this happened to me. The seat/head/rail assembly is screwed on to the post? So I can tighten it? I can turn mine back and forth - should I tighten it somehow, or just point it straight and that's the best I can do until I send it back to 9point8 ? Mine spins pretty easily now ... 2 different crashes seem to have really knocked it loose.
    thanks
  55. #855
    Quote Originally Posted by slcpunk View Post
    thanks
    Thatís pretty much where I was but check for leaking air. Either way I could not figure out a way to tighten myself,
  56. #856
    Reputation: reamer41's Avatar
    I received the following via email from 9point8 this morning:
    ďIf you are happy with your Fall Line seatpost and it is working well,
    then this email is not for you.
    But if you have a persistent air leak
    you may qualify for a FREE permanent repair.
    If you have a leak, start by compressing the post down to roughly one inch and remove it from your bike. Pump up your post to approximately 100 psi and fully submerge it in a bucket of water. Take note of any air bubbles that you see and contact support@9point8.ca
    If we determine that you have a leak at the primary seal, then you will qualify for a free repair and installation of the newly developed SSR: description below.
    Continuous engineering, development and testing in the pursuit of an ever-improving, more reliable dropper post has identified a potential air leak in some Fall Lines.
    The SSR has been designed provide better compression to the main seal, effectively stopping all leaks at the main seal.
    NOTE: The SSR is compatible with V2 collar nuts ONLY. If you have a Fall Line with a V1 nut and an air leak, contact Customer Service for support.Ē
    --Reamer
  57. #857
    I got it too. I had just emailed them about an air leak the day before too. Didn't realize it was for everyone.
  58. #858
    Reputation: KTMDirtFace's Avatar
    Love my 200mm fall line. Have not read through this thread, but I didn't know of any others with that much drop.
    Guerrilla Gravity Pedalhead XL
    Guerrilla Gravity The Smash XL
  59. #859
    Reputation: sooner518's Avatar
    I, too, got the email. My post has needed more air almost every ride for the last 9 months. Otherwise, it will come up, but will stop in the last inch or so of travel.
    Im glad they are wanting to fix it.... but what is the turnaround time of this gonna be? Am i gonna be without a post for a month while it ships, they fix it, and they ship it back?
  60. #860
    Quote Originally Posted by sooner518 View Post
    You can fix it at home in a couple hours if you want. It's just a normal overhaul [video on site] and instead of using an older part you use a new part [SSR = Seal Support Ring]. I'm sure they'd send you the part if you asked them and then your downtime is the one afternoon for the overhaul.
    Safe riding,
    Vik
    www.vikapproved.com
  61. #861
    They are sending me everything I need to upgrade the post at home including the brake tool and lube.
  62. #862
    ah. thanks for the heads up. That is much preferable. I need to actually do their underwater test and check for bubbles but im pretty sure mine will be leaking.
  63. #863
    FWIW - I had some leaks during the UW test. Opened up my head and relubed it being careful for how the seal was sitting and that got rid of the leaks without installing any new parts.
    Safe riding,
    Vik
    www.vikapproved.com
  64. #864
    Perfect
    Safe riding,
    Vik
    www.vikapproved.com
  65. #865
    Jan 2015
    Hi, my current post start leaking air only in the closed state, so with the saddle -up - it holds air just fine; however, when saddle is down - it takes few hours to completely loose air;
    I assume the problem is in top nut seals, since in case of an internal leak - it should lose air all of the time;
    The question is - will nut V2 fix following problem?
  66. #866
    Quote Originally Posted by Nick_M View Post
    When the post is up the seals face 25psi of pressure. When the post is down it's a lot higher. So leaks when the post is down, but not up are understandable.
    If you haven't re-lubed the dropper recently I would give that a whirl. It's fast and easy.
    Safe riding,
    Vik
    www.vikapproved.com
  67. #867
    Jan 2015
    Quote Originally Posted by vikb View Post
    post will not leak air in case it almost fully down (1 inch left ) also;
    Post was serviced properly month ago, so I assume there should be an appropriate amount of grease, probably there is something with last few mm of the post and seal that cause leaks; not sure how to fix that;
    Any air leaks are not acceptable,
  68. #868
    It will for a few weeks, it was pretty awesome to have a working post again after I rebuilt mine, now mine takes about 8 seconds to go back up.
  69. #869
    Jan 2015
    Bonking ... not feelin' well
    Quote Originally Posted by kitejumping View Post
    Correct if I'm wrong, that actually means that v2 is not fixing the problem since v1 with new seal stayed true for +-2 weeks;
    too bad, since that's the only dropper that allows the user to lift the bike by saddle as well as user serviceable
    Thanks for the quick reply;
  70. #870
    Both my 9.8's are holding air fine. Both are the V2 nut.
    Safe riding,
    Vik
    www.vikapproved.com
  71. #871
    Not sure if you saw the post above, but 9.8 is offering free seal upgrades. I don't know whether that works with the V1 nut or not, but I'd chat with them and see what the score is.
    Safe riding,
    Vik
    www.vikapproved.com
  72. #872
    I think it is completely random whether it works or not, my 175mm is still perfect after rebuilding it the same time as the 200mm. I rebuilt that one second though and crammed more p10l in than on the 200 so maybe that's the issue. Will likely relube the 200mm with tons of p10l like I did on the 175mm.
  73. #873
    I had a leaking issue on a freshly lubed 9.8. Opened it up and I had put so much grease in there the seal wasn't sitting properly. Cleaned it up and re-positioned the seal. No further leaks. Probably worth a look.
    Safe riding,
    Vik
    www.vikapproved.com
  74. #874
    Mine was the opposite, the one with more p10l seems to be holding air longer.
  75. #875
    Ah...sorry I misread. I would still open the leaking one up. The position of that seal is important. It may not be seated correctly.
    If you don't have that new seal ring from 9.8 that's worth getting installed as well.
    Safe riding,
    Vik
    www.vikapproved.com
  76. #876
    I have the V1 nut and I tested my post underwater, and air bubbles were coming out.
    I emailed 9.8 and told them I had a V1 nut version of the 150 post. he basically told me i have to buy a rebuild kit (which will contain a V2 nut and the SRS thing) since my post is so old. a bit disappointing but ive been putting off doing that service for a while so i bit the bullet and bought it.
  77. #877
    Jan 2015
    Just Ordered V2 version, will see how it will work, hope it will fix an issue for at least year;
    do not want to purchase IPF based droppers at all;
    Also is it possible to purchase seat post upper tube itself? in case of damaging original?
  78. #878
    Seat tube is available by itself.
    Just did the upgrade on my post last night. Overall it was a 5/10 job. Strap wrenches are you friend and you absolutely need a super tight rubber band to get the spring loaded guides back in place. PITA. Get a wooded dowel to lube the center of the tube as it's impossible to reach.
    The upper red seal is very low quality with dimples and mold flash still attached. I wish they use skf seals, as this would solve all their air and lube leaking problems. Hopefully they will change this over in the future.9point8 Fall Line Dropper Post. Totally happy with mine!-20180604_193408.jpg9point8 Fall Line Dropper Post. Totally happy with mine!-20180604_193708-1-.jpg
  79. #879
    There's a key install tool on the website now. It looks like it might work (there's a video), but you still have to use a rubber band and 10 tons of grease.
  80. #880
    Mar 2013
    I went ahead and did a service upgrading to the V2 nut. After 18 months of use I started to notice air loss, not much mind you, I would just top up with air every ride, and as it started to get warmer it seamed like I only needed to do it every two rides, or maybe it was to do with leaving more grease on the edge of the seal.
    Anyway I also noticed the quality of the new red seal to be not that great.
    I also got the key install kit, I can imagine this part of the job to be a bit tricky if just using a band.
    The only other bit I did differently to the video, was to use a lot more layers of inner tube when holding the shaft, the one layer in the video did not seam enough and I did not want to scratch the shaft at all.
    Only a week so far after service, so to soon to report anything, so seams to have gone well.
  81. #881
    Jan 2015
    18 month - not that bad, depending on conditions as well;
  82. #882
    Dec 2012
    I'm looking to upgrade from the 1x remote to something like the digit, but $70 seems crazy. Can you use a KS southpaw or other remotes?
  83. #883
    The digit is made by wolf tooth and they are the best of the best. Check out the dropper lever thread. Once u use a wolf remote nothing else is good enough.
  84. #884
    Jan 2015
    I would say that is a well spend $70;
    I had the same choice year ago and went with RF lever, mainly due to colorful option, it is good, however not that universal as WF
  85. #885
    Nov 2007
    The 9.8 Digit, Wolf Tooth ReMote LA lever, and the RaceFace 1x Hop Up lever are the only 1x levers that I am aware of on the market that have the leverage ratio and cable pull stroke needed for the Fall Line post. Other levers will be high effort, and may not have enough stroke to access the reset function.
  86. #886
    got 80% of my way through the rebuild. no problems at all until i got to the keys install.... how in the **** are you guys installing these things? im gonna have to take it to my shop becuase i just spent 2 hours failing miserably trying to get those things in there.
  87. #887
    I feel your pain brother.
    I about lost my mind trying to get those keys in. By the time I finally did, they were all mangled that it was a complete lost cause. Ended up sending the thing to Canada for factory service.
    Those keys !!!!!
  88. #888
    It's all about using a wide, strong rubber band wrapped as tight as possible over the keys. I struggled as well the first time. The second time I learned my lesson and it went very smoothly.
  89. #889
    Yeah it's a bitch. I had to get my wife to be my third hand and we finally managed to get it. I bought the 9point8 tool after that for the next rebuild.
  90. #890
    Mar 2013
    Yeah just get the tool, it's was suggested to my by the service place where I brought the service kit.
    He said it's doable, but on a few occasions it just becomes such a pain. The tool takes those issues away.
  91. #891
    fuggansonofahowa
    You need to use the collar to keep the keys from being pushed up and out of slots. The keys will press pretty deep into the foam ring. I try not to use too much force when pushing down the collar to avoid damaging the ring. I've never ruined one, but they are quite fragile.
  92. #892
    i wish id known there was a tool for that when i ordered the rebuild kit. add in shipping now and that tool costs $40.
    i had a really wide rubber band and i got it pretty tight on there. it just felt like whenever the rubber band would start getting pushed up the post, it would pull the tops of the keys up too, extending them past the grooves.
    i took it to my buddy in the LBS. hes done these before so hopefully he can get it done. the rest of the rebuild was a snap so far. except finding an M7 bolt was surprisingly difficult.
  93. #893
    Hard to understand why people keep buying this dropper post with all the maintenance and problems involved. Bike Yoke is years ahead, One up for $200 without the remote.
  94. #894
    My count so far is 3 brake failures, 3 X ring failures. The 9.8 guys are responsive and warranty items have been hassle free. They will send parts rather than demand the post back so you're not down for 3 weeks. But I'm nearing the end of my 2 year warranty and not looking forward to the expense. If Bike Yoke had a 200 I'd be all over it. That's the only reason I stick with 9.8...they're the only 200 game in town.
  95. #895
    I used one hand to aid the rubber band and keep the keys from sliding. I didn't know there was a tool available? I could not find an M7 is the US; fortunately 9.8 sent me the M7 release tool when I had a warranty issue.
  96. #896
    i bought it 2 years ago when it was seemingly the consensus top pick. i havent really had any issues with it until this. my buddy was able to get the keys in pretty easily he said. i got the post put back together but now it feels like theres a lot of friction when the post moves thru its stroke. and it wont come all the way back up. it stops like a half inch from the top....
    ill prolly take the nut off and put a bunch more grease in there. taking the nut off isnt that hard, but i have to use channel locks to get any grip on it. and now my new nut has a nice big scratch from where the channel locks gripped the post. why they dont make the top nut hexagonal so you can get at it with a wrench, i have no idea.
  97. #897
    If you watch the 9.8 service video they suggest a strap wrench. I have used one several time and there is no damage. Works very well. It's also pretty inexpensive.
    I agree wrench flats would be useful.
    Safe riding,
    Vik
    www.vikapproved.com
  98. #898
    Ditto
  99. #899
    change is good
    Sep 2004
    My Reviveís seat clamp head snapped off. I was lucky I wasnít going down chunder. Pretty quick turn around with remaining original parts. Puked oil into my frame after 4 rides. No biggy until I went to a slacker setup with longer reach. Now I want more drop than what my 150 Transfer offers. So I could put the 185 Revive back on or my 175 9.8. Based on past experience, both will fail in under 4-6 months. Current gen Reverb creaked like crazy. KS has a spotty CS rep. I want a 175 or even a 200 Transfer for my 35in inseam. Then again, my Transfers donít have many hours on them. But they do have good rep.
    Sent from my iPad using Tapatalk Pro
  100. #900
    Also being able to service them yourself at home is a big plus, the newer videos 9point8 uploaded have all the steps in detail. I think one can expect all droppers to fail after a while, at least the 9point8s are easy to service.
  1. Anti-fall line and fall line
    By pixy in forum Trail Building and Advocacy
    Last Post: 07-31-2018, 06:43 AM
  2. 9point8 new dropper post???
    By shirk in forum Components
    Last Post: 09-27-2015, 12:01 AM
  3. Replies: 25
    Last Post: 05-14-2015, 02:06 PM
  4. 9Point8 Pulse Dropper Post Review
    By GMONEY80 in forum Fat bikes
    Last Post: 06-25-2014, 09:27 AM
  5. Not totally happy with my 2x10.
    By Damitletsride! in forum Endurance XC Racing
    Last Post: 06-20-2012, 12:17 PM
Members who have read this thread: 266
