Results 1 to 5 of 5
    150mm x 30.9 dropper with shortest insertion
    I have ~165mm in the frame for the post, another 20-30mm for the mechanism (if internal), and ~ 25mm of "pull out/non insertion".
    If an internal 150mm dropper is a no go, I'd take a 150mm external dropper over a 125mm dropper.
    Frame is a Lenz Fatillac.
    damned rocks...
    Reputation: Aglo's Avatar
    Dec 2014
    Take a look at the BikeYoke Revive 160mm internal.
    From your numbers, and if I'm not misunderstanding anything, it should fit.
    Have one for a couple of months almost 700km on it and it's still flawless.
    Aug 2015
    Also the ks lev integra 150mm
    Sent from my SM-G930V using Tapatalk
    Reputation: Lone Rager's Avatar
    Dec 2013
    Yeah, you gotta look at total length extended (rails to end of post) and length from rails to bottom of the post's seal collar at full extension and make sure both will fit at your saddle height.
    Do the math.
    I did some figuring last night using a 125 ext Reverb. Fit was just about perfect, sadly the issue is short seat tube insertion, so I'm stuck with a max total length of ~375mm. Best I can do is a 125mm dropper.
  1. Replies: 31
    Last Post: 01-20-2017, 02:40 PM
  2. 27.2 X-Fusion Hilo Dropper minimum insertion?
    By offrhodes42 in forum Components
    Last Post: 11-08-2016, 10:25 AM
  3. Covert Dropper Question - Insertion Depth
    By travman in forum Transition Bikes
    Last Post: 05-06-2015, 09:24 AM
  4. Dropper Post Insertion Depth
    By TwoNin9r in forum General Discussion
    Last Post: 04-24-2014, 07:30 AM
  5. going from 150mm to 160mm or just keeping it at 150mm??
    By alfonz212 in forum Banshee Bikes
    Last Post: 02-15-2013, 04:10 PM
Members who have read this thread: 13
