Page 1 of 3 1 2 3 LastLast
Results 1 to 25 of 64
    A Theist
    Reputation: bikeCOLORADO's Avatar
    Sep 2003
    Wrist pain dang it
    1,300 miles behind me in 16 weeks straight commuting.
    Riding a flat bar bike (Orbea Carpe 3.0). I think the hand position is bugging my wrists. Both left and right, It really hurts to twist my forearms and when I pick up things with even a little mass.
    Looking for comfortable bar ideas. Butterfly? Drop? Bull?
    Phillipians 2:3-8 "...but (Christ) made himself nothing, taking the form of a servant..."
    Reputation: mtbxplorer's Avatar
    Dec 2009
    Sorry to hear that. It sounds pretty severe if it is hurting not just when you're riding, but off the bike as well. Hate to say it but you may need to rest it a while and maybe have someone take a look at it before continuing the high miles with new bars. Aside from that (perhaps unwelcome advice, I haven't tried anything other than flat or riser bars. In general, whether riding or typing, a straight wrist rather than a bent one is preferred ergonomically.
    A Theist
    Sep 2003
    Not cycling is not an option. Yes, I am being stubborn and probably stupid.
    weirdo
    Reputation: rodar y rodar's Avatar
    Bar ends?
    And good luck. Hopefully they`ll straighten themselves out if you work up the mileage more gradually- carefull!
    Faster than a spotted salamander.
    I find drop bars to be uncomfortable, myself. The drop on most frames is so huge that it hurts my back.
    By far, I prefer bullhorns or bar ends, if the bike allows for it.
    Squeaky Wheel
    Dec 2005
    I prefer drop bars. You get several hand positions on top of the bars as well as a drop position for riding into the wind. I rotate hand positions a lot when I ride. I use bars with a shallow drop, they are not as aero as a standard drop but more comfortable to ride in when I need to use the drop position.
    If you want to stick with flat bars, try some bar ends.
    100% commuting this year (5700+ miles) with no hand or wrist pain.
    Good luck.
    weirdo
    Quote Originally Posted by wschruba View Post
    Does take getting used to, and you can loose that "used-to-ism". I find that my back gets "unaccustomed" after a long period of little riding, just like legs, butt, neck... If I drop my bike time way down over the winter, I end up raising my bars (with achey-breaky lower back) after that first long spring ride. Also worth noting that a taller stem (you didn`t buy into that threadless headset business, did you?) or more spacers (and didn`t chop your steerer, if you did go threadless?) can raise the bars reguardless of the frame, as can a shallower drop, like Woodway brought up. Not trying to convince anybdoy who really prefers a different style bar, but keep in mind that bars can usually be raised a bit on any given frame. And you still might not like them.
    Quote Originally Posted by woodway View Post
    I100% commuting this year (5700+ miles) with no hand or wrist pain.
    Yay, me too! Um, the percentage, NOT the miles.
    Nor the elevation.
    jrm
    jrm is offline
    Reputation: jrm's Avatar
    Try something with
    more sweep. the additional sweep will give you a more natural hand position.
    the bontrager satellite, on one freegle or mary
    "Neo cracker"
    A Theist
    Sep 2003
    Just ordered a pair of these:
    1 Pair Rubber Mountain MTB Bike Bicycle Cycling Lock on Handlebar Grips Ends W | eBay
    If they don't alleviate the pain...I will try a bar with a bit of sweep. The on-one fleegle bar looks good (and pretty affordable).
    Reputation: vaultbrad's Avatar
    Oct 2007
    Those look like a good first step. Hope they help. Other options include altering position on the bike. Raising bars a bit will take pressure off of wrists and hands as will moving your saddle back, down and uptilt just a smidge in each direction to put more weight on your butt and keep the same leg extension. One should never make huge alterations all at once. Just a bit at a time to see how your body reacts.
    Jan 2011
    Big sweep, bar ends, and Ergon grips helps a lot with wrist issues.
    Mark Farnsworth
    http://febikes.wordpress.com, Raleigh, NC
    Nov 2012
    I had the same problem. Ergon grips helped a lot--I got the model meant larger hands although I actually have smaller hands. I also switch my grip around as I ride. Gripping the grips, keeping closed fists and leaning my knuckles against the grips, or leaving my hands open and pressing my palms against the grips with my wrists rotated to whatever angle is comfy. Downside, of course, is that I could get my hands knocked off the bars when hitting a large bump, so I only do it on familiar routes.
    I've broken bones in both wrists and this strategy helps avoid pain. 200-300 miles/week.
    Reputation: junior1210's Avatar
    It might help if you buy some wrist support bands (not to be confused with sweat wrist bands) to wear especially while riding. I was having some wrist pains that I believe mostly came from bad habits, and the wrist supports (don't restrict movement but offer a little extra resistance) helped to keep my wrists straight. The supports are only about $5 each at Wally World. Keep in mind that this will only help if your problems come from bad riding posture/wrist position and not something more serious.
    The ridiculousness of cycling clothes increase exponentially in relation to the distance from your bicycle.
    I <3 29ers
    Reputation: AndrewTO's Avatar
    Mar 2005
    There could be a number or reasons why your wrists might be sore. Poor cockpit positioning, whether yours or that of the components', along with your physical conditioning, amongst many other factors blahblahblah ...
    I say check your grips first. I find it makes a huge difference if I have popular brand lock-on grips (even ones with a thicker more "cushy" design) or my ESI Chunky grips. I am a big fan of foam-based grips. Started years ago with Bontrager foam grips and evolved from there. Tried road bar grip tape too but just can't wrap it right on a non-road bar (figures, eh?!?!).
    That and the bar material. I gotta have my carbon. Period.
    Of course neither are a match for when i've been overdo-ing it with the nachos ... and beer ... and rum and cokes ... and chocolate cake. Anatomy fact - the tummy is in between the hips and wrists.
    Oh, and the grips would be easier to change than everything you already have set up (if you're the lazy type ).
    I ..... need ..... DIRT!!!!!
    ... and cookies. :D
    Reputation: newfangled's Avatar
    I feel your pain (literally).
    I've moved away from straight bars - now use a bullmoose (flat with a bit of sweep) and a Carnegie and a Mary (both sweepy "alt" bars). I prefer them to risers, but can still have issues.
    For me personally it feels like wrist pain, but I've discovered that the root of it is actually my thumb/indexfinger. I've used wrist braces and supports, but found they didn't help. Ergon grips feel comfy but they didn't solve the longterm problem. My wrists can be sore just because of one stopsign on the way to work. So I pay a lot of attention to how I'm holding the bar, and how I'm using my brake levers. I spent a lot of time thinking it was my wrists but didn't really see progress until I started focussing on my thumb/finger. But that is just me.
    No Stranger to danger....
    Reputation: Tone's's Avatar
    OP, Look i dont wanna derail the thread to much but id like to ask you what you are getting up to in your free time.
    To much mastorbation can be very bad for your wrists, im speaking from experience here, you need to start using both hands n spread the load a bit more.
    Its a common occurrence for bike riders to blame their bikes, ive seen this phenomenon hundreds of times....
    Maybe even think of giving it a rest for a few weeks or investigate other methods where the wrists are not used to much.
    I had a mate that had to have a shoulder reconstruction because he wore down his rotator cuff from years of spanking the monkey with his right hand, over those years he was always complaining about his sore right shoulder n wrist, i told him to share the load with his other hand but no, he wouldnt listen..
    Anyway i didnt wanna put you on the spot to much OP, but just have a think about it mate, cheers....
    Part time Gimp, and extreme water sports lover..
    A Theist
    Sep 2003
    Quote Originally Posted by Tone's View Post
    LOL. I really don't spank much, my wife is great at "releasing my steam". I should ask her if her wrists hurt much...
    Unhinged Aussie on a 29er
    Reputation: hunter006's Avatar
    Funny guys. I work in IT, ride at least 250 miles a week and I use butterfly bars after drops were too painful to continue using from the beginnings of carpal tunnel due to excessive time at a keyboard. Had a PT massage them regularly (every 2 weeks) and did daily exercises to strengthen and break up tissue build up - back of hands against the underside of desk and pull up, flexing and massaging the wrists every hour or so... a month off the bike and keyboard finally solved my problems. Hopefully you don't have to go through that too.
    Anyway, when I looked in to it, I saw a few options to alleviate wrist pain:
    TT Bars - useful if you're not climbing too much - moves the stress from your wrists to your forearms and elbows. Downside is it puts you in a more aggressive position which is poorly suited to MTB's (too much seat tube angle).
    Butterfly bars - What I went with. Multiple hand positions available. I keep mine relatively flat, so they're like wide, higher up TT bars. Most people have a higher and a lower position, but because the issue was pressure on my hands, I kept mine flat and had a fore and aft position. Biggest downside is now the weight is shifted to my sit bones, and I don't have a good seat.
    Jones H Bars - similar to Butterfly bars in principle - large amount of sweep, lots of places to grab hold of. I would say these are likely to be the biggest hammer to smash any sized nail that you need - they're also really freakin' pricey.
    On-One Midge bars or Salsa Fargo bars - Drop bars are 23.8mm in diameter, and MTB bars are 22.2 mm in diameter. Thus you can put road components on road bars and MTB bars, but you can only put MTB components on MTB bars. These work ok, but the compatibility with existing parts was a deal breaker for me.
    Moustache Bars - Similar in every way to the butterfly bars. I believe these take road components though.
    In addition to this, there are some companies that produce ergonomic grips. Whether they work or not is a whole different story, but I have no experience in that. I can't remember the name of the company that produces them though.
    jrm
    jrm is offline
    yeah, i started shaving the palms of my hands
    just to get my gloves to fit. And i cant see shlt
    "Neo cracker"
    A Theist
    Sep 2003
    IT GEEK COMMUTER PRIDE!
    I will see how the bar ends work, it might require some time off the bike. I hate the thought of it. It's hard enough for me to lose weight even while cycling all the time.
    Quote Originally Posted by bikeCOLORADO View Post
    Don't focus on weight. The scale doesn't tell the whole story. Use progress pictures or find a way to measure body fat %.
    I have plain risers and I can feel the wrists from time to time....
    I installed barends inboard of the shifter and brake bracket....
    I use them to either get out of the wind or change up the hand position.
    What helps the most is the reverse prayer pose
    You start with the hands and arms just behind the back, and grab the opposite elbows.
    Yoga: Reverse Prayer Pose (Paschima Namaskarasana) - YouTube
    The easy way In tadasana, join your hands behind you in reverse prayer position. If your shoulders feel tight, grab your elbows or interlace your hands behind your back. Draw your shoulder blades onto your back and toward one another. Move the top or the “head” of each arm bone toward the back plane of your body. These actions will stabilize your shoulders and help you open up the front of your chest more fully.
    Flat bars are problematic.....make a move of some sort....sooner than later.
    A Theist
    Sep 2003
    Quote Originally Posted by Sanath View Post
    My scale tracks BF%. I'm at 37.5% as of this morning. My metabolism adapts. I really didn't work out for two years. I put on 40lbs eating all kinds of crap. I've been bicycle commuting for 16 weeks and eating much better, tracking calories and nutrition. I initially lost 12 lbs. I've been stuck at 208lbs / 37-38%bf for the last three weeks.
    The scale is probably estimates BF% low.....
    When you stck at a weight.....you have to really up the exercise....or moderately reduce diet.
    Are you drinking fruit juices, gatorade???
Hot Deals
Contests
Latest Mountain Bike Articles
