Results 1 to 37 of 37
    I'd rather be on my bike
    Reputation: TenSpeed's Avatar
    Feb 2012
    What is your cutoff temp?
    I know a lot of you commute all year round. What about those that don't? What is your cutoff temp to not ride? I know some of us live in colder climates, and others in warm climates, so post up both.
    When I started this, I swore it would be 40 as the cutoff. If it was under 40, I wouldn't ride. Now it is 30, as long as it is 30 before I leave for work, I will ride. When the summer rolls around, I am not sure what it will be. Showering at work is an option, although it is not an easy one.
    The pedals turn, not just the left one, but the right one too.
    Don't have a cut off temp
    Moderator Moderator
    Reputation: mtbxplorer's Avatar
    Dec 2009
    Quote Originally Posted by TenSpeed View Post
    I find the 20's are better for biking than the 30's (F), because it is less slushy and wet out there (although salt affects this also).
    Reputation: newfangled's Avatar
    When I started I swore it would be 30F - I'd just ride through the fall, but would take the bus in the winter. But that quickly slid to 15F - I'd just ride through the easier parts of winter, but I was honestly going to bus when it was really cold. But the bus never happened, and I'd much rather ride at -26F (my record) than stand at a busstop.
    I don't have a cutoff temp. Coldest I've ridden in is probably about -10F.
    Oh noes. I'm going to drink the Kool-Aid.
    since 4/10/2009
    Reputation: Harold's Avatar
    I also prefer riding in subfreezing temps than when it's just above freezing. the slop is a factor sometimes, but I find that 32-45 or so is the most difficult temp range to gear up for. It's so easy to overheat by overdressing, but you have to be very careful about underdressing in those conditions, too. throw in cold rain...eh.
    What's that ? I'm from new England HTFU. Pedaled at 4F once, the gatorade
    freezes solid at that temp.
    Reputation: shiggy's Avatar
    Dec 1998
    Have not found it yet, if there is one.
    So far this year I have commuted in a range from under 10F to over 110
    mtbtires.com
    Fat!Drunk!Slow!
    Reputation: JordyB's Avatar
    Oct 2007
    About -25 and i'm not really having much fun below that. I would need so much gear I wouldn't be able to move very well.
    Reputation: Texan-n-Fla's Avatar
    Sep 2013
    Quote Originally Posted by jeffscott View Post
    This. I don't have another option for getting to work, other than waking up the wife and kids to bring me in, and that's more of a hassle than it's worth. Ever dealt with an autistic 6 yr old at 5 am? I'd rather ride behind a semi in a downpour than deal with that mess.
    Bourbon: Because no good story ever started with "So, there we were eating salads".
    Reputation: BrianMc's Avatar
    Absolute Zero would definitely be a non-starter. Done -5. Cold enough. Locals thought me completely nuts. Not like Edmonton, the Yukon or Alaska or Montreal when the Arctic air masses hit.
    weirdo
    Reputation: rodar y rodar's Avatar
    So far haven`t had any temps in my area that prevented me from commuting, but when it gets up into the upper 90s, the commute is just about all the riding I do.
    Recalculating....
    Reputation: ghettocruiser's Avatar
    Although I've never missed a commute due to cold weather, my one-way distance is no more than 10-20km and is mostly urban roadways and wooded valleys.
    There is road group here that heads out into the county to do 100+ km at minus 10C and colder.
    No thanks.
    The above statements have not been evaluated by the Food and Drug Administration
    Feb 2012
    I am pretty weak. I think that having Reynaud's really hurts my cold weather riding.
    psycho cyclo addict
    Reputation: edubfromktown's Avatar
    I've ridden 50 miles at 104 F and as long as I have water, I could tolerate hotter.
    On the cold side, somewhere around 10-15 F on a breezy day is where I draw the line. If I am riding in a heavily wooded area, maybe a bit lower temp.
    【ツ】 eDub 【ツ】
    CB of the East
    Reputation: bedwards1000's Avatar
    I occasionally get Reynaud's too but not during a ride. My record is -20F. I'm with JordyB, it gets less fun. But 35 degrees warmer at 51F, that's fine. As long as my hands and feet are warm I love winter riding. Especially on the trails & lakes.
    When the base posts amber road conditions and does not allow bikes to ridden on base.
    Fat-tired Roadie
    Nov 2007
    Never found it. My mountain bike could handle worse road conditions than my Ranger, so I never found my cutoff road conditions either. Now that I have a less crappy car, I might stop riding when the roads have churned up ice mounds. Those are really hard to hold a line on.
    For me the issue is safety. Once the roads get crud on the sides and the bike path is frozen up I'll be on the train. I also ride progressively slower as the temperature drops.
    When I lived in Fairbanks -20F was my cut off. Frostbite starts being a real issue about there. Same for nordic skiing, it just wasn't fun. I don't have to worry about sub zero temperatures here in Utah now.
    Bedwards Of The West
    Oct 2007
    I haven't had the opportunity to find mine yet... I've done a few commutes in single digit negatives... only gets colder than that here rarely.
    (no excuse for that either)
    Apr 2005
    Another Reynaud's sufferer here. I havent found my low yet. This is my first year round attempt. So far my lowest is 5F. This week I will see how I do below 0F. But I am lucky that all of my trips are <10mi. My regular trip is about 5mi each way. So when it is really cold I just "overdress" over a good baselayer and go slow so I dont sweat too much. It takes a lot longer but it is the only way I can be out in the cold. I have found the windchill to be more discouraging at times than the air temp.
    Feb 2012
    If I can keep my hands and feet warm, I can ride. That is my biggest issue, aside from the conditions. I don't have a bike for the snow, and I try to avoid the rain/sleet. I may have to look into dedicated winter SPD boots/shoes. I know that Specialized makes some, but they are about $200. I don't know if I want to get that involved in it.
    I ride the shimano MW 81 good winter boot...I also ride that boot in the sides and ine the mountains as well....
    Good from about 10 C down and good till -35C with thick socks.
    weirdo
    Don`t write off insulated hiking boots with BMX pedals as an option.
    Recalculating....
    Reputation: WiTrailRunner's Avatar
    Mar 2011
    Ditto.
    My cut off temperature would be different if my commute were shorter. But with a 33 mile round trip, I bailed in late November when it was in the 20s in the morning. I'm good for about 45 minutes and then I become miserable. I am okay with being a seasonal commuter.
    since 4/10/2009
    Quote Originally Posted by rodar y rodar View Post
    this is one of the bigger reasons I use platforms on my commuter. I wear hiking boots when it gets cold enough.
    I do want some winter boots for mtb riding, though.
    Aug 2005
    My commute is 43 miles round trip. I'm more concerned with the wind than the actual temp. If it's cold and clear I'll ride in the 20's. If it's a stiff north wind and in the upper 30's or 40's I'm probably just gonna drive. I commute twice a week because I enjoy it. If it's not going to be an enjoyable ride, screw that. I'm out.
    weirdo
    Quote Originally Posted by WiTrailRunner View Post
    I would probably have come kind of cutoff if my commute were longer!
    33 mi RT in the 20s is inspirational- my hat is off to you
    Recalculating....
    Fat-tired Roadie
    Nov 2007
    Re: What is your cutoff temp?
    I do this too, if it gets cold enough and I'll be riding for a while. Right around freezing, I've been known to just ride the same setup as always.
    Reputation: connolm's Avatar
    I don't have a lower limit - I've ridden down to -2F in Boston. But i gotta second Natehawk's post (it was Natehawk right?): I'm more likely to bail when it's 33F and rainy than anything else. That's just miserable.
    Below freezing and everything solidifies. Snow bounces off my clothing. Puddles are frozen and bikepaths - if cleared - will stay clear down to bare asphalt. If I can stay dry, I stay toasty. Cold rain soaks into everything and just makes me wet and cold.
    Sadly, like so many others, I really don't have much of a bail-out option when I don't feel like riding. The bus adds at least 45 minutes to the commute if I wait for it.
    I have ski goggles and a full face balacalavcalava thinga-majig to cover my fave. (You know what I mean.) I nest gloves like russian nesting dolls. Dress in layers.
    Reputation: blockphi's Avatar
    Mar 2012
    My lowest temp to this point is -20 F. I'm actually looking forward to going lower. So far this year I've ridden at -15 F as well as -5 with a 15MPH wind for a really cold ride. For me anything under -10 really seems all the same - dam@ed cold!
    You guys with longer commutes are well justified. I have 9 miles one way and multiple options to get on the train if I chicken out.
    There's a guy in my office that has a 9 mile ride too and he was riding even in the horrible smog and single digits last winter. I asked him if he had brass balls or what his secret was one day. Turned out he was only riding to the train station and back, about 1.5 miles! haha I was walking that.
    Reputation: Spatialized's Avatar
    Haven't found the cut-off yet. Did -4F last winter and 105F this summer, and truth be told, like the cold better. Luckily the commute is only 5 miles each way so it's not a huge trip.
    Sounds like 135.8 degrees is the cutoff here on earth. It also sounds like you'll need a preheater to breathe without freezing your lungs.
    Antarctica Hit Record Cold Temperature So Ridiculously Low It Hurts Just Hearing About It
    I have been in < -40 F or -40 C (Ottawa, Canada). That was hard enough to breathe.
    Feb 2012
    Weather has been crappy here. I don't have the bike to handle the conditions, so I haven't ridden to work in about 2 weeks now, or close to it. Mid 20's during the day, teens at night, and the roads are just slick. We have had this light mist mixed with snow and a touch of rain that just makes everything slippery. I don't see myself riding a skinny tire bike to work in that. If it were to dry up, I would do it, because the temps are not that bad without the wind.
    Reputation: phirebug's Avatar
    wasn't sure what my cutoff temp was until i caved and got a ride yesterday. -9 with a wind chill of -28 did the trick.
    Don't buy all the lies that they feed ya.
    Dec 2004
    Being a former CNY resident, I feel for many of your dedication. Now I can't imagine it getting below 55 so that's my cutoff. I will not peddle to work below 55. It's all about standards people.
    Aloha
  1. What is the cutoff for a clyd?
    By Dung Hopper in forum Clydesdales/Tall Riders
    Last Post: 08-27-2013, 11:04 AM
  2. Soggy Bottom cutoff times.
    By rio in forum Alaska
    Last Post: 07-21-2013, 12:22 PM
  3. Replies: 20
    Last Post: 09-19-2011, 07:55 AM
  4. Niwot ridge/cutoff trail
    By bpk013 in forum Colorado - Front Range
    Last Post: 09-05-2011, 08:35 AM
  5. temp screen
    By bnelson in forum GPS, HRM and Bike Computer
    Last Post: 02-10-2011, 09:56 AM
