Results 1 to 3 of 3
    ONe less gear
    Reputation: bugly64's Avatar
    thinking about a change
    I am thinking about changing my frame from a mtb to a cyclocross one. I just wonder if I can use my XT drivetrain on a cyclocross. Any suggestions?
    Which way? Uphill.
    Reputation: nepbug's Avatar
    Sep 2004
    If you go flat-bar, sure, otherwise you will have to get some 9-speed STI road levers.
    You might also want to investigate the largest chainring your front derailleur can handle (assuming the clamp and pull will work on the cyclocross frame), though you might still be able to make it work beyond spec.
    Blog
    Just keep spinning. Just keep running. Just keep paddling.
    Just keep moving forward.
    Reputation: kvojr's Avatar
    Apr 2005
    You don't need STI, you can get a set of downtube or barend shifters. Nothing says you can't mount your flat bar shifters to the top of the drop bars either.
    1993 Barracuda A2R - 1x7 Beater
    2007 Redline Monocog 29er
