Results 1 to 7 of 7
    more beers, lees gears.
    Reputation: mattKHS's Avatar
    tail light with a rear rack
    So i have a seat post mounted rack, with a large-ish rear trunk. All of my tail lights are post mount.
    i have a similar set up to this. Only with a post mounted rack
    What do you guys do to get a tail light on the back? i know my bag has reflective strips and logos, but we all know that does no good.
    A burrito is a sleeping bag for ground beef.
    If the rack has a flat center plate, one easy solution is to bolt a piece of seatpost-sized wooden dowel to the underside of the rack's center plate, then mount your taillight on the dowel. The attached photo illustrates the idea with a piece of small dowel. If you don't have any dowel, go buy a spool of thread and use the spool
    Great Idea!
    Actually, to take it a step further, (because I fear that dowel coming loose, or splitting out over time / water) I am going to use a 1" PVC, with some washers. I will run a bolt through my rear rack, and into the 2" long PVC with the washers on the bottom to hold it.
    Thanks! I'll post a pic when i have it just to share.
    Bedwards Of The West
    Oct 2007
    My post-mount taillight uses a clip to attach itself to the post-mount...so when it's removed from its mount it still has a little clip on it that you can use to clip it onto a backpack, etc.
    I would sew a little loop of webbing/fabric on the back of the trunk/bag, and clip the light to that. I wouldn't be surprised if it even already had a loop that would work.
    (no excuse for that either)
    yeah, i have a similar cat-eye tail light with the belt clip. No loop on my bag for some reason. I have just opened the rear zipper and hooked it there, but it leans downward too much.
    LCI #1853
    Reputation: PscyclePath's Avatar
    I run a Delta rack on the back of my commuters, and there's a little flat plate hanging vertically across the back. A little work with a drill, and I bolted a tail light mount back there to hold a Superflash or a Cateye EL-1100... depending which bike ;-)
    Oct 2007
    Quote Originally Posted by mattKHS
    You could put a bungee around the bag and hook it on there to avoid the droopy effect.
