Results 1 to 31 of 31
    Storing lock while riding
    How does everyone store their bike locks while riding? The old kryptonite U-lock (just exchanged it for the current kryptolock atb) I had used a slide in frame mount that wasn't bad at all. Made a little noise but worked fine. This new mount they have is completely unmountable due to how much space it wastes and I'm a bit leery of the strength of the design... I currently don't have a rack and would like to be able to ride w/o a backpack for short runs so a on bike mounting solution would be nice! Am I doomed to the velcro type mounts or carrying a backpack?
    Double-metric mtb man
    Reputation: Psycho Mike's Avatar
    Both my wife and I have racks on our commuters. She slides hers into the rack and I have a rack bag I use. If you don't have a rack and don't want to use a pack, there's always slinging it over the grips (handlebar through the U)...not visually appealing, but just make sure it won't interfere with anything if you go that route.
    As if four times wasn't enough-> Psycho Mike's 2013 Ride to Conquer Cancer Page
    Moran? Let your opinion be free -> F88me
    Quote Originally Posted by makeitso
    Yes u are. U can't have the best of both world...
    Good lock equal heavier lock. U don't want rack and no bag?
    U got to choose one.
    I got a grocery bic with front basket. I will dump the lock into it.
    If I am riding my hybrid bic which comes with no rack and front basket. I will carry a canvas bag which stores my repair kit and lock.
    Just spoiled by my old mount I guess. Maybe it's time to invest in a rack since the bike has the hardware to be all screwed in.
    I use a 3.5' chain lock that I just sling over my shoulder. I also carry a bag everywhere because cycling is my life.
    Just put the lock where you keep your tools, rain gear, extra layers...
    You could put it around your wrist depending on the size.
    A frame and saddle bag might work fine as well.
    Ride Responsibly
    Reputation: LWright's Avatar
    If you just ride from point a to point b, leave the big lock locked up at point b, carry a smaller one if needed for quick stops, or just keep the bike with you, no worse than a shopping cart.
    Intended use was for things like random jumps to say a local coffee shop or park to hang out with friends. One way being at most 5 miles so I don't need anything more than my small underseat pack for misc tools. Just wanted an easy way to throw on the lock as well w/o requiring the backpack. But seems like the rack is the way to go to increase mounting places.
    Reputation: Helmsdini's Avatar
    Interesting topic that I have recently grappled with myself. I have a 4lb On-guard U-lock that I use to secure my more expensive bikes. After trying everything under the sun and realizing that it simply will not fit well on my bike I have decided to start packing nearly every time I go out. This is usually not a problem since I can carry the lock in the back pack along with my street shoes and work clothes or something. The pack is also handy for shopping or even going out to eat as a place to store the helmets and so on.
    When I am doing longer touring type rides, I use a rack with a topeak rack bag and throw the rack in there with my shoes.
    Here lately I Have made a switch on my daily commuter beater bike and put a cable lock around the steer tube on the frame. For short trips around town on my less expensive bike I usually just trust the cable lock and park within view if possible. It has made my commutes much easier, but I have sacrificed a little security in the process. I still carry a pack, but without the U-lock it is much lighter.
    Reputation: Red Horn's Avatar
    Nov 2008
    Idea!
    I currently use this one; http://www.onguardlock.com/lockviewe...oil&model=5028
    They make another that is thicker at 15mm. I however do not have the need to keep my bike locked up more than an hour or so at a time. Therefor I can get away without a heavier U. The OnGuard I have came with a mounting bracket that I affixed to the seat tube. It works very well and is stable in transit. As previously posted a strong U at your destination where you spend the most time away supplemented with a lighter lock/cable to carry will often suffice.
    Nov 2007
    My backpack has criss-crossing elastic straps on the back. Lock goes there and a carabiner just to keep it from bumping too far up and out.
    No-Brakes Cougar
    Reputation: Gary the No-Trash Cougar's Avatar
    Just goes in my backpack, along with everything else. Don't want a bunch of crap hanging off my bike!
    R.I.P. Ronnie James Dio ~ July 10, 1942 May 16, 2010
    I also have a large On-Guard shackle and was using the bracket for a while until the lock popped out when I hit some railroad tracks. After that I decided to simply put it through my rear rack. I took an old innertube and cut it to the right length and tied a knot in each end. On one end I used 2 zip ties to make a loop. The fat knot at the other end is tucked between the rack and the lock and I stretch the loop end over the lock and hook it to the bottom bottom of the rack. It looks ghetto but it is fast and easy and never rattles.
    Live Free Or Die!
    Reputation: GCG199's Avatar
    Quote Originally Posted by Gary the No-Trash Cougar
    Yep, that is how I look at it too.
    Fisher Fan
    Backpack is the best way to go!
    Reputation: Killroy's Avatar
    Mar 2006
    I leave my lock at the rack at work.
    I'm SUCH a square....
    Reputation: bigpedaler's Avatar
    When I ran the 3' krypto chain, I wrapped it around the frame behind the head tube; now I have a separate padlock and a 9' cable as big around as my finger, so I just sling it on me like a bandolier.
    A bike is the only drug with no bad side effects....
    LCI #1853
    Reputation: PscyclePath's Avatar
    For coffee stops, etc. where I can keep a good eye on the bike, I have a cable lock that I use to keep the bike from wandering away. It rides in a handlebar bag or occasionally in the rack trunk. For serious, long term parking I carry either a Kryptonite 3000 or a Kryptonite chain. They ride on the rack trunk, though it's easier to simply wrap the chain around and wear it like a belt...
    OlTime XR500 JumpingChamp
    Reputation: CrystalBay's Avatar
    Dec 2005
    KryptoniteNYU + Rack + Trunck = no more sweaty back pack . It has made a world of difference , truly a better option for hauling all tools ,sundries and libations ....
    Try this:
    http://clevercycles.com/store/?c=web...roduct=LBFRAME
    http://clevercycles.com/store/?c=web...+Defender+lock
    Steve
    I've got a super cheap commuter bike with one of those coiled up cable locks with a combo on it. I just hook it around my stem/frame wherever I ride. Helps that I live in a pretty low risk community as far as bike theft goes and I'm not all that concerned if the bike does disappear.
    That was one of my big criteria for my commuter MTB - do I care if it gets trashed/rained on/snowed on/stolen? Not really. It's a commuter
    in a pannier
    u-lock in a back pack
    cable lock around the bars
    MTB Addict
    My Kryptonite cable has a seatpost clip mount. I store it there whenever it's not in use.
    those are Rollercams...
    Reputation: WTB-rider's Avatar
    Truly a wealth of useless information.
    http://blackdogadventureteam.blogspot.com/
    jrm
    jrm is offline
    Reputation: jrm's Avatar
    I leave mine @ work
    unless i know ill be making a stop on the way home then i use one of those racks that fits to the seattube.
    PCC
    PCC is offline
    I have an OnGuard Bulldog U-lock on my commuter bike. I used the mount that comes with it. It's the style that has the collar that is held on to the U piece with a setscrew and that collar has slots that fit into a slot in the frame mounting bracket. At first I felt that this design was stupid and there was no way to mount it to my bike because it ran into everything. Then I had a thought: why not loosen the setscrew and turn it so that I could put the mount at an angle compared to the frame. Doing this I was able to place the lock in a way that it straddles the bottom bracket and doesn't get in my way nor does it get in the way of the function of the bike.
    Attached picture tells more than a thousand words.
    Do any of you have a lock integrated into the frame? Thoughts on this...
    pro
    pro is offline
    Oct 2007
    Carbon cranks on a commuter! Damn!
    Since I ride a fixie, I've gotta do the true hipster thing. Put in on a belt loop, and just let it hang. If not that, than in the messenger bag it goes.
    fabric horse
    Made here in Philly from reclaimed materials:
    http://www.fabrichorse.com/index.php?page=shop
    pro
    pro is offline
    Oct 2007
    Quote Originally Posted by mcurtius
    I no longer need blow out loops! And here in philly too!!!!
    Thanks for the link!
    PCC
    PCC is offline
    Quote Originally Posted by pro
    Not exactly. It's carbon over aluminum. If I were to go to town on those cranks and grind off all that carbon then it would be a set of aluminum cranks. Same goes for the handlebar on that bike. Needless to say, both parts look trick but they're heavy and I got them for next to nothing so they're on my commuter bike.
