Results 1 to 16 of 16
    Glorified Hybrid Owner
    Dec 2005
    Recommend a disc-only 26" mtb frame that fits 700x42 tires
    Can anyone recommend a disc-only 26" hardtail frame that will fit a 700x42 in the rear stays?
    jrm
    jrm is offline
    Reputation: jrm's Avatar
    Only one i can think of
    is the Salsa Ala Carte.
    Dec 2005
    Quote Originally Posted by jrm View Post
    I think I've read that before and forgot, thanks for mentioning it.
    Dec 2005
    I have a feeling that the newer Treks or Fisher 26" frames may because they don't have seatstay or brakestay bridges, but don't have one to test.
    Reputation: SpiderMike's Avatar
    Seen it done to a Surly 1x1. I think the Surly Troll has the same amount of room.
    Did I catch a niner+?
    The Troll should easily be able to do it.
    Dec 2005
    Quote Originally Posted by SpiderMike View Post
    Neither are disc-only, but I know they fit a lot of tire.
    Dec 2005
    Any reason it has to be a 26" frame? Wouldn't a 29er frame be easier.
    Dec 2005
    Quote Originally Posted by Lewy View Post
    I already have a rigid 445mm fork I'd like to build this around and wouldn't mind the shorter wheelbase of a 26" bike and I think they are more flickable. I have run a few of my 26" hardtails with 700x28 and 700x32 tires for years and love 'em.
    The only 29ers that I know would work with this 445mm fork would be the early Raliegh XXIX (heavy frame) or an OS Blackbuck (not cheap).
    Besides, I figured a used 26" hardtail are less desirable and hence "should" be cheaper than a 29er.
    One Colorful Rider
    Reputation: Normbilt's Avatar
    Surly 1x1 with 29x2.1 slash 700x54 tires with disc Brakes
    Tuesdays Ride by normbilt, on Flickr
    weirdo
    Reputation: rodar y rodar's Avatar
    Quote Originally Posted by rockhound View Post
    If you happen into a steel frame that fits your other needs, you can move the bridge up and out of the way. To completely skip the bridge sounds kinda crazy to me, but I`m not an engineer.
    Dec 2005
    Quote Originally Posted by rodar y rodar View Post
    I have a Werks Haro Werks SS that I could do this to but I'd have to wait for an Alfine wheel.
    if it were brazed and not tig welded I might have already.
    Reputation: Jeff Stevens's Avatar
    Mar 2011
    I have a 1x1 that I have done 700c 37mm tires but I thought the bike handled funny with that set up. I prefer it with 26" tires.
    One Colorful Rider
    Mine did not ride weird. I like the fact that it was a lower center on gravity.
    But then I found this bike true Identity meet the Joker
    New Sneakers and Post by normbilt, on Flickr
    Outrunning zombies
    Reputation: 9erfreak's Avatar
    That is sexy...
    GF/Trek HiFi | Hardrock Sport Disc 29er
    If you don't eat **** every now and again, you aren't riding hard enough!
  1. Replies: 6
    Last Post: 07-27-2011, 08:40 AM
  2. Replies: 13
    Last Post: 07-25-2011, 06:11 PM
  3. Replies: 9
    Last Post: 07-25-2011, 01:29 PM
  4. Recommend a frame, and 3/4" versus 5" ?
    By dieselcruiserhead in forum General Discussion
    Last Post: 09-13-2007, 01:41 PM
  5. Recommend me a 6" travel frame.
    By FISHLEG in forum Downhill - Freeride
    Last Post: 07-12-2004, 12:35 PM
